Old 03-10-2016, 11:20 AM   #2031
nisti
nisti's Avatar
Drives: BRZ & XV
For those wanting to use the SPC LCA or continue using, here is a link to purchase it with legal STX bushings:
SPC LCA w/ DIF Bushing
Or replacement bushing:
DIF Rear LCA Bushings
This information was farther back in the thread, and took me a little to find it.
So I wanted to resurface it since it's being talked about again.
nisti is offline   Reply With Quote
The Following 5 Users Say Thank You to nisti For This Useful Post:
GeorgeJFrick (03-10-2016), renfield90 (03-10-2016), Shneegle (03-10-2016), strat61caster (03-10-2016), Wepeel (03-30-2016)
Old 03-10-2016, 11:41 AM   #2032
Wepeel
Drives: '13 BRZ Ltd
If you're looking at V3s for auto-x, you really should check out our RCE Tarmac 2s. Based on KW Clubsport 2 ways, but custom valving and springs. Still built by KW and with a lifetime warranty. A bit more serious than KW V3.
- Andrew
This. Especially since the V3 comes with some very soft spring rates now, so you have to factor the price of a new pair of springs into the V3. 230/280 F/R I believe. Too soft for STX.
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
Racecomp Engineering (03-10-2016)
Old 03-10-2016, 11:55 AM   #2033
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
I have on numerous occasions attempted to read this whole thread with no luck. One of these days, I'll make it through. Thanks for pulling the info up the stack. Now to see if I can still edit my post.
GeorgeJFrick is offline   Reply With Quote
Old 03-10-2016, 12:10 PM   #2034
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Been with this thread from the beginning. Forgotten most of what has been discussed
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 03-10-2016, 03:46 PM   #2035
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
You will be fine. The whitelines are legal.
Mike, Bill and I look forward to more competition
Originally Posted by GeorgeJFrick View Post
Hey guys,
** This post has been edited to reflect data gathered from other members so it reflects my best known current LCA listing for STX interested members **
I'm trying to determine exactly which LCAs are stx legal? My list and understanding is as follows:
SPC - Legal configuration available. By default, bad bushing material and additional metal. Legal with bushing swap (FR.Sport Part No. 10594)
Whiteline (newer model) - Legal
Truhart - Stated to have been run at nationals by Scooby South*, so legal?
Velox - Stated "legal" configuration available.
RacerX - Stated "legal" configuration available.
Cusco - Not legal due to spherical bearing. But there are people stating to use these in STX**?
RS*R - Legal.
Agency Power - Not legal due to spherical bearing.
Buddy Club - Status not known.
I'm pretty confused. From my reading of the rules, any of them with a bushing is legal as long as the bushing has no more metal in it than stock. That seems like something difficult to really assess?
The Whiteline and SPC would both appear to be legal.
I have the Whiteline on order and planned to run them at Miller Park; so I'm feeling a bit worried here. In closing I want to be clear I did attempt to read the rules myself, and by my understanding plan to run the Whiteline.
*http://forums.nasioc.com/forums/show...postcount=1377
**http://www.apexjunky.com/featured/ap...stx-brz-build/
2superblus is offline   Reply With Quote
Old 03-10-2016, 04:12 PM   #2036
GeorgeJFrick
He's alive! We'll see. I go to Lake Country Alignment on the 18th; the car should be fully dialed in by April 1st. We'll see if the driver is ready.
Old 03-10-2016, 04:23 PM   #2037
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
I am always lurking. I have just been working on things for this season. Things and stuff!
Old 03-10-2016, 04:30 PM   #2038
cjd
cjd's Avatar
Drives: 2017 BRZ
Competition is why I'll still make the trip up to Miller Park. Hoping to pick up the pace this year, we'll see!
Old 03-11-2016, 03:27 PM   #2039
GeorgeJFrick
For STX I assume you can change the stereo, but I remember having a discussion at an event and the person was arguing you couldn't.
Can I change to a single-din stereo?
Old 03-11-2016, 03:29 PM   #2040
jbailey8748
Can't remove it or any speakers but I'm pretty sure they can be changed out
The Following User Says Thank You to jbailey8748 For This Useful Post:
ryan t (03-11-2016)
Old 03-11-2016, 06:25 PM   #2041
Blue Gt
Blue Gt's Avatar
Question Longacre gauges for a Twin
Has anyone in the STX group here installed this electronic gauge console?
If so where did you get the sensor adapters or did you use an oil cooler routing plate under the filter as the input source? TIA, DP
Blue Gt is offline   Reply With Quote
Old 03-11-2016, 06:28 PM   #2042
cjd
cjd's Avatar
Drives: 2017 BRZ
I did, though I have dash cam monitors in the space that opened up (which is why I made the change in the first place.) Have to go dig up the relevant rules (or lack therein) now.
Old 03-11-2016, 09:06 PM   #2043
48Spoons
Drives: Ultramarine FR-S
Should fall under the comfort and convenience section. As long as you're replacing it and not just taking out the weight it should be fine.
48Spoons is offline   Reply With Quote
Old 03-13-2016, 12:22 PM   #2044
xwd
Has anyone tried running a 18x9 with the 265/35/18? There are almost no wheels out there but I did see Enkei is going to start selling the GTC01RR in the US, it has an 18x9 +40 version. Unfortunately it's also $550/wheel.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
