Sam Strano
Old 03-09-2016, 03:35 PM   #4075
renfield90
The Stig's German cousin
Originally Posted by RMP View Post
I'm also running the Kosei's and have a set of 3mm and 5mm spacers since I could not find one off the shelf at 8mm.
Do you stack spacers to fine tune widths? I'm wondering if there are any safety and reliability issues for competition use only.
Amazon is your friend. You can find just about any spacer thickness you want.
I tried not to daily drive my competition wheels/tires but it happened more than once, sometimes for a month or two (after the end of the season and not motivated enough to bolt on something with less grip). I ran an 8mm spacer front and rear, zero issues.
Do make sure you have extended studs. For that matter if you change your wheels with any regularity it's a good idea as the stock studs suck.
The Following 2 Users Say Thank You to renfield90 For This Useful Post:
DylanFRS (03-10-2016), strat61caster (03-09-2016)
Old 03-09-2016, 09:55 PM   #4076
bslate3
Drives: 2015 CWP BRZ
Yes extended ARP studs are a must.
bslate3 is offline   Reply With Quote
The Following User Says Thank You to bslate3 For This Useful Post:
Old 03-10-2016, 12:03 PM   #4077
86_Freak
86_Freak's Avatar
Drives: 2015 FR-S
Just got back from getting my alignment. I have Koni inserts, TRD springs, and OEM crash bolts.
Front Left Camber: -1.35°
Front Right Camber: -1.38°
Rear Left Camber: -1.89°
Rear Right Camber: -1.94°
I also had them zero the toe on the front and rear.
86_Freak is offline   Reply With Quote
Old 03-10-2016, 12:06 PM   #4078
AlanLGuy
Drives: Raven 6 speed Manual FRS
SCCA Solo C Street Discussion
Looks like my FR-S is on the lower end of negative camber from what I've seen others have gotten.
I hope that included the new required stepped washers on your Koni's. If so, then that probably explains your lower negative camber. Everyone else's numbers will be coming down as well.
Edit: just saw that you have the inserts, not full replacements.
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel.
AlanLGuy is offline   Reply With Quote
Old 03-10-2016, 12:06 PM   #4079
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
His key word was inserts. Using OEM strut housings I'd hope he'd be legal
edit: You edited at the same time I posted
Old 03-10-2016, 12:08 PM   #4080
AlanLGuy
Yup, read too fast. Went back and noticed he said inserts. I haven't got my stepped washers and alignment yet, but I'm guessing -1.3 is about where I'll be as well
Old 03-10-2016, 12:15 PM   #4081
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Are you guys using all of the tricks to get front camber? Jacking up under the balljoint to force maximum camber while you tighten the bolts, loosening other bolts and shifting things around, etc?
Old 03-10-2016, 12:23 PM   #4082
86_Freak
86_Freak's Avatar
Drives: 2015 FR-S
I didn't hover over the guy doing my alignment. He is well-known in the KC area to get race alignments and almost everyone that races their car takes it to him. He even gives a 10% racer discount!
He did tell me he loosened up everything in the rear to try and pull in the rear to get rid of some of the negative camber.
The Following User Says Thank You to 86_Freak For This Useful Post:
DocWalt (03-10-2016)
Old 03-10-2016, 03:01 PM   #4083
ryan t
Drives: frs
i am, it got me to 1.4 both fronts with cusco full replacements. my RR is way off from the factory and was able to drop it from 2.6 to 2.3 by loose and pry
ryan t is offline   Reply With Quote
The Following User Says Thank You to ryan t For This Useful Post:
Old 03-10-2016, 03:03 PM   #4084
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Do you know if they loosened up the rear subframe and tried to get it closer to right
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 03-10-2016, 03:14 PM   #4085
ryan t
Drives: frs
no that didnt move it any, the upper controll arm moved it the most. one side of the upper was in farther. two of us with a long pry bar moved it
jbailey8748 (03-10-2016)
Old 03-10-2016, 06:03 PM   #4086
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
That won't do anything, everything bolts to the subframe, that would just change the angle of the shock in the control arm.
Old 03-11-2016, 12:09 AM   #4087
ButteR
Drives: 2015 Scion FR-S
Where is everyone getting their Koni strut washers from? Do we just call up Koni tech support as mentioned in the article simpleisbest posted a while back or ....?
ButteR is offline   Reply With Quote
Old 03-11-2016, 12:25 AM   #4088
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Yes
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
