#4075 | |
The Stig's German cousin
I tried not to daily drive my competition wheels/tires but it happened more than once, sometimes for a month or two (after the end of the season and not motivated enough to bolt on something with less grip). I ran an 8mm spacer front and rear, zero issues. Do make sure you have extended studs. For that matter if you change your wheels with any regularity it's a good idea as the stock studs suck. |
#4076 |
Drives: 2015 CWP BRZ
Yes extended ARP studs are a must.
#4077 |
Drives: 2015 FR-S
Just got back from getting my alignment. I have Koni inserts, TRD springs, and OEM crash bolts.
Front Left Camber: -1.35° Front Right Camber: -1.38° Rear Left Camber: -1.89° Rear Right Camber: -1.94° I also had them zero the toe on the front and rear.
#4078 | |
Drives: Raven 6 speed Manual FRS
SCCA Solo C Street Discussion
I hope that included the new required stepped washers on your Koni's. If so, then that probably explains your lower negative camber. Everyone else's numbers will be coming down as well. Edit: just saw that you have the inserts, not full replacements.
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel. |
#4079 | |
Drives: '22 BRZ
![]() edit: You edited at the same time I posted
#4080 | |
Yup, read too fast. Went back and noticed he said inserts. I haven't got my stepped washers and alignment yet, but I'm guessing -1.3 is about where I'll be as well
#4081 |
Drives: '22 BRZ
Are you guys using all of the tricks to get front camber? Jacking up under the balljoint to force maximum camber while you tighten the bolts, loosening other bolts and shifting things around, etc?
#4082 | |
Drives: 2015 FR-S
He did tell me he loosened up everything in the rear to try and pull in the rear to get rid of some of the negative camber.
#4083 |
Drives: frs
i am, it got me to 1.4 both fronts with cusco full replacements. my RR is way off from the factory and was able to drop it from 2.6 to 2.3 by loose and pry
#4084 |
Drives: 2013 Satin White Pearl BRZ
Do you know if they loosened up the rear subframe and tried to get it closer to right
Sent from my SAMSUNG-SM-G900A using Tapatalk |
#4085 |
Drives: frs
no that didnt move it any, the upper controll arm moved it the most. one side of the upper was in farther. two of us with a long pry bar moved it
#4086 |
Drives: '22 BRZ
#4087 |
Drives: 2015 Scion FR-S
Where is everyone getting their Koni strut washers from? Do we just call up Koni tech support as mentioned in the article simpleisbest posted a while back or ....?
#4088 |
Custom User Title
Yes
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
