Old 03-05-2016, 11:59 AM   #3277
dj2020
Originally Posted by HaloFRS View Post
And what catch can do you guys use?
I'm running a Mishimoto PCV catch can. I change my oil every 4000 miles or so and I can pour maybe 1/8" worth of oil from the can at those intervals. No track days, just spirited on ramp and highway pulls.
I don't have a can for the CCV breather side though as Mishimoto does not make one. However, when I run my finger inside the intake tract and throttle body opening, I don't seem to be getting a film of oil. Maybe heavily tracked cars would show otherwise. YMMV.
dj2020 is offline   Reply With Quote
The Following User Says Thank You to dj2020 For This Useful Post:
HaloFRS (03-05-2016)
Old 03-05-2016, 09:19 PM   #3278
CSG Mike
CSG Mike's Avatar
So for daily (spirited mountain) driving afr is the only gauge you'd recommend?
What catch can are you guys using?
No catch can; we watch our oil level carefully and monitor our charge pipes.
I'd recommend temperature over AFR, if you REALLY want a gauge, but you don't need gauges at all with the JRSC.
Bykov (03-05-2016)
Old 03-05-2016, 09:39 PM   #3279
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Got a p172 code today. The idle was all messed up. Read earlier about the MAF sensor being the culprit. Bought some crc cleaner and problem solved, runs like a champ so far.
ApolloSki is offline   Reply With Quote
The Following 2 Users Say Thank You to ApolloSki For This Useful Post:
CSG Mike (03-05-2016), Lonewolf (03-06-2016)
Old 03-07-2016, 12:21 PM   #3280
axelthrasher
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
Always inspect the MAF extension cable as well. I had the same thing, and it kept happening - turns out it was one of the wires coming out of the MAF extension harness. Replaced it, never had an issue since! :-)
axelthrasher is offline   Reply With Quote
The Following User Says Thank You to axelthrasher For This Useful Post:
CSG Mike (03-08-2016)
Old 03-08-2016, 02:09 PM   #3281
Ak1m0to
G20 Guru
Ak1m0to's Avatar
Drives: Infiniti G20 / FRS
Send a message via AIM to Ak1m0to
I've been getting the same issue with the P0172 - Running too rich code and cannot figure what's causing this? Below is my set up, I've tried cleaning the MAF, the car will run ok for a few days and the problems/CEL will come back. Car will hesitate sometimes going at a constant speed. Coming to a stop or giving it a little throttle from a stop, the car will sometimes want to stall and does every now and then. My gas mileage has dropped to about 20 mpg and the back of my exhaust is covered in black soot. Some days the car will drive better and then a few days later, the problems will come back. I've brought this up to Mike at MotoEast and he's using my current tune on a few cars as a base map with no issues.
2014 - Auto
JRSC - C30 kit with engine oil cooler
Crawford AOS
Omni MAP sensor
ECUTEK - Motoeast
Slowmatic Drfiterz, from P to D in a heartbeat.
Ak1m0to is offline   Reply With Quote
Old 03-08-2016, 05:07 PM   #3282
Bykov
Drives: 2014 Monogram FR-S Whiteout
2014 - Auto
Crawford AOS
Omni MAP sensor
ECUTEK - Motoeast
I feel like I have read about this issue more than once on the competitor thread but I do not remember the solution. How does the O-ring look for the MAF? I think swapping it out would be a great place to start. Then checking for leaks.
Bykov is offline   Reply With Quote
Old 03-08-2016, 09:46 PM   #3283
CSG Mike
CSG Mike's Avatar
2014 - Auto
Crawford AOS
Omni MAP sensor
ECUTEK - Motoeast
You have no other mods; have you considered running the CARB tune instead?
Old 03-09-2016, 12:40 PM   #3284
Ak1m0to
G20 Guru
Ak1m0to's Avatar
I've tried cleaning the MAF several times, also replaced it with an OEM one.
Also inspect the tubing on the MAF and intake side, looks fairly clean.
Old 03-09-2016, 12:44 PM   #3285
SoCalArgento
Drives: 2014 Argento FRS
Not to hijack or stray, would switching to a Speed Density system such as the one utilized by Delicious completely eliminate the problem of the MAF getting dirty or not sealing properly?
SoCalArgento is offline   Reply With Quote
Old 03-09-2016, 12:45 PM   #3286
Ak1m0to
G20 Guru
Ak1m0to's Avatar
Only other engine mod would be a UEL FT86 Speed factory catted header, Motiv ceramic coated Over and catted Front pipe, with an Invidia Q300 Exhaust.
Only other thing I can think is maybe the 2nd O2 sensor is acting up, but it hasn't given me a CEL for the sensor yet.
Old 03-09-2016, 12:46 PM   #3287
Ak1m0to
G20 Guru
Ak1m0to's Avatar
I was actually thinking about that too, or having Moto-East send me a SD tune.
Old 03-09-2016, 01:58 PM   #3288
CSG Mike
CSG Mike's Avatar
The better question is, how do you prevent your MAF from getting dirty?
Answer: Catch can/AOS.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Bykov (03-09-2016), dp1 (03-09-2016), SoCalArgento (03-09-2016)
Old 03-09-2016, 04:46 PM   #3289
Bykov
Huge shout out to CSG Mike for working very hard with me and putting up with my PayPal nonsense and getting me the JRSC C38 with JROC! It has been an absolute pleasure to work with you and David as well as your ever-patient sales team. Looking forward to doing it again (except without all that PayPal nonsense) as you have earned my business for absolutely everything CSG carries! Btw, my refund from PayPal came through yesterday and my kit will be at my door tomorrow!
The Following 5 Users Say Thank You to Bykov For This Useful Post:
*LongFella (03-10-2016), Binary_fission (03-09-2016), CounterSpace Garage (03-09-2016), kevin.nguyen (03-09-2016), ScionOfHorus (03-09-2016)
Old 03-09-2016, 04:59 PM   #3290
Yoda
Drives: Crystal Black BRZ(Sophia)
Lucky guy.
Yoda is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
