Old 09-20-2015, 05:34 PM   #15
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by whitefrs View Post
There is no higher glow Direct injectors
FA20DIT ones...
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-20-2015, 11:12 PM   #16
dj2020
Originally Posted by dj2020 View Post
I asked this on the DT flex fuel thread but thought I would put the question here as well:
Need some advice here: I'm installing the DW700cc injectors along with my DT flex fuel kit. I upgraded to the fuel injector adapters that connect between the DW injectors and OEM connectors. But now I can't fit the drivers side metal cover over the injectors because the adapters are in the way. Is it okay to leave the the metal cover off? Should I trim the metal cover (which would be a bitch I imagine)? Or have I angled the injectors incorrectly. I feel like I tried every combo. The passenger side metal cover was a tight fit but I managed.
Never mind. I ended up sucking it up and just notching the metal covering on one spot for the passenger side and two areas on the driver's side for fuel injector adapter clearance. I probably went through 4 dremel attachments. It was a bitch but it's done. If the metal covering exerts any pressure on the adapter/fuel injector combo, you get a spray of fuel all over the place. Don't ask how I know!
dj2020 is offline   Reply With Quote
Old 03-07-2016, 12:04 AM   #17
Rinzler_ft86
Rinzler_ft86's Avatar
Drives: 2013 brz limited edition
Any pics on what you were looking at?
Sent from my SM-N920P using Tapatalk
Rinzler_ft86 is offline   Reply With Quote
Old 03-07-2016, 12:45 AM   #18
NahumCC
Drives: 2013 FR-S 10 Series
Originally Posted by Dezoris View Post
Also the direct injectors have 3 different part numbers based on their stratified flow number. So they need to be removed for inspection before ordering and replacing which makes it a total bitch when their is a 30-60 day lead time to get parts
This is something that irks me. Why can't that have that tied to the VIN number so when you need to order them they could have just looked up your car to see what was installed. Ugh........
NahumCC is offline   Reply With Quote
Old 03-07-2016, 02:31 AM   #19
dj2020
I'll try and take some pics of the 'notched' metal fuel injector covers tomorrow.
Old 03-07-2016, 02:52 PM   #20
dj2020
Sorry! I just looked and I don't think can take any good photos showing the notches I made. On the passenger side metal covers, the DI ECU is blocking view of the notches I made. I'll post a picture of the driver's side which shows the one notch I made but it's not a very good picture. Basically the the DW injector/adapter combo sticks out too far. Simply cut into the metal covers so that the injector/adapters clear. Once you have injectors installed on the fuel rail, it will be very obvious where the metal covers are fouling the injectors.
Old 03-07-2016, 02:58 PM   #21
Rinzler_ft86
What dw pump did u put in?
Old 03-07-2016, 03:43 PM   #22
dj2020
I actually went with a Denso 260lph from Chris over at Speed By Design. It's technically not approved for e85 but I wanted OE reliability.
Old 03-07-2016, 04:03 PM   #23
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
I left my driver side cover off. I only reinstalled the passenger side because it holds the injector controller.
NotSoJDM is offline   Reply With Quote
Old 03-07-2016, 10:50 PM   #24
Rinzler_ft86
Gosh im not looking forward to doing this. Just bought dw injectors and pump
Old 03-07-2016, 10:54 PM   #25
Trust86
Drives: 2016 Halo FRS
I took both off because they are heavy as hell, but the injector controller can still be held in place without it!
Trust86 is offline   Reply With Quote
Old 03-08-2016, 09:12 PM   #26
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I left both of my covers off. I then cut the passenger side cover that also holds onto the ECU to not cover the injectors and still hold onto the ECU. I'll post a picture for you in 5mins.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 03-08-2016, 09:23 PM   #27
GsxrMe
GsxrMe's Avatar
The factory covers would rub and hit like mad. This was 1 of the many cutting completed to get my turbo kit to install. I don't want to talk about how much I had to cut into the factory HID headlights to get the pipe from the inter-cooler to intake to fit.
If that cover is applying ANY pressure your better off cutting it entirely vs causing it to rub and short while driving it. The last thing you need is the damn wires to shorting out when driving. No one likes tow trucks.
2014 Subaru BRZ
Old 03-08-2016, 09:26 PM   #28
dj2020
Any cons with leaving the metal fuel injector covers off?
So what exactly will aftermarket feul injectors do to my frs Frsexxxy Engine, Exhaust, Transmission 8 03-10-2013 12:28 PM
Deatschwerks Injectors - Released FT-86 SpeedFactory Engine, Exhaust, Transmission 0 09-08-2012 04:20 PM
Deatschwerks BRZ/FR-S Fuel Injectors! RallySport Direct Engine, Exhaust, Bolt-Ons 2 09-07-2012 06:29 PM
