Old 06-11-2013, 04:51 PM   #1
kaybee123
Drives: Scion FR-S
Injectors installation
Is it me or is there absolutely no information on how to install injectors on our car?
Is it just really simple so no one is making a guide? I've looked all over for it!
kaybee123 is offline   Reply With Quote
Old 06-11-2013, 06:03 PM   #2
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Super simple, as soon as visconti sends me my tune i ll install them and i ll do a diy
Silverdub is offline   Reply With Quote
Old 06-13-2013, 10:53 AM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Here is my simple guide:
Passenger Side:
1. Unbolt injector driver ECU
2. Unbolt metal sound deadening cover
3. Unbolt fuel rail
4. Unclip injectors
5. Remove injectors
6. Install new injectors
7. Bolt fuel rail back down (depending on injectors, might require spacer as well)
8. Clip in injectors (depending on injectors, might require wiring adapters)
9. Reverse of removal
Driver Side:
1. Disconnect both fuel lines with a fuel line removal tool (will be smallest one available at local parts store and is a plastic tool that goes in the end of the fuel line)
2. Disconnect the fuel vent hose which is held on with a standard clip
3. Unbolt metal sound deadening cover
4. Unbolt fuel rail
5. Unclip injectors
6. Remove injectors
7. Install new injectors
8. Bolt fuel rail back down (depending on injectors, might require spacer as well)
9. Clip in injectors (depending on injectors, might require wiring adapters)
10. Reverse of removal
The Following 2 Users Say Thank You to King Tut For This Useful Post:
charged86 (06-13-2013), Dream20b (03-07-2016)
Old 06-16-2013, 01:09 AM   #4
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Are you asking about the port injectors or the direct injectors...?
pheoxs is offline   Reply With Quote
Old 06-16-2013, 01:36 AM   #5
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Someone got a guide for both port and direct injectors?
Darryljr11 is offline   Reply With Quote
Old 06-16-2013, 07:56 AM   #6
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Direct injectors will require a special tool
Old 06-16-2013, 11:05 AM   #7
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
Which is what?
Old 06-16-2013, 11:15 AM   #8
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
It will require a special tool to replace seal.
Why would u replace DI?
The only ones to replace are Port with bigger injectors
Old 06-16-2013, 12:01 PM   #9
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Which is what?
I ll try to take a picture of it tomorrow!
Old 06-16-2013, 01:09 PM   #10
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
To upgrade to higher flow injectors/ direct injection leaking
Old 06-16-2013, 01:25 PM   #11
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
There is no higher glow Direct injectors
But there is port injectors
Old 06-16-2013, 09:00 PM   #12
kaybee123
Drives: Scion FR-S
Watch out when you reinstall the injectors & their power connector.
My problem was that one of the power connectors was rubbing on the side so it short circuited and the car wouldn't start.
Old 06-16-2013, 09:53 PM   #13
Dezoris
Dezoris's Avatar
Also the direct injectors have 3 different part numbers based on their stratified flow number. So they need to be removed for inspection before ordering and replacing which makes it a total bitch when their is a 30-60 day lead time to get parts
Old 09-20-2015, 03:54 PM   #14
dj2020
I asked this on the DT flex fuel thread but thought I would put the question here as well:
Need some advice here: I'm installing the DW700cc injectors along with my DT flex fuel kit. I upgraded to the fuel injector adapters that connect between the DW injectors and OEM connectors. But now I can't fit the drivers side metal cover over the injectors because the adapters are in the way. Is it okay to leave the the metal cover off? Should I trim the metal cover (which would be a bitch I imagine)? Or have I angled the injectors incorrectly. I feel like I tried every combo. The passenger side metal cover was a tight fit but I managed.
dj2020 is offline   Reply With Quote
So what exactly will aftermarket feul injectors do to my frs Frsexxxy Engine, Exhaust, Transmission 8 03-10-2013 12:28 PM
Deatschwerks Injectors - Released FT-86 SpeedFactory Engine, Exhaust, Transmission 0 09-08-2012 04:20 PM
Deatschwerks BRZ/FR-S Fuel Injectors! RallySport Direct Engine, Exhaust, Bolt-Ons 2 09-07-2012 06:29 PM
