Old 08-25-2015, 09:40 AM   #99
churchx
churchx's Avatar
Drives: 2014 GT86
I prefer looks of these to those of Rally Armor ones. But these look like made of hard plastic. Given low car's ground clearance i sometimes use fact, that rear is higher then front, and go over some higher obstacles like when parking over curb, in reverse.
Question to owners of these stock mud guards from their experience - if driving over curb in reverse will or won't break these plastic mud guards? Rally Armor ones at least look flexible on that account.
Old 08-25-2015, 10:11 AM   #100
Originally Posted by churchx View Post
...- if driving over curb in reverse will or won't break these plastic mud guards? Rally Armor ones at least look flexible on that account.
If you scrap the OEM ones in the rear in reverse you are going to have bigger issues than the mud guards. The OEM ones are about level with the tailpipes as I recall.
churchx (08-25-2015)
Old 01-24-2016, 09:51 PM   #101
isolato
Drives: 2015 Subaru BRZ; 2001 Mazda Miata
Thanks for the DYI! Installed the FRS mudflaps on my BRZ today. I jacked up the rear and removed the wheels for the real flaps and just turned the steering wheel to full-lock to do the fronts. Went on super easy. It occurred to me while doing the install that it may be possible to do this without taking off the rear wheels.
You could use either the "melt the hole" method or use a handheld drill chuck like this with a stubby drill bit to create the hole for the extra screw pin.
[ame="http://www.amazon.com/dp/B012H070NK?psc=1"]Keyless Drill Chuck - Universal 3/8-in 24 UNF Thread - Holds 1/32-3/8" 0.8-10mm 1/32-3/8" Bits - - Amazon.com[/ame]
... which you could then screw in with one of those stubby finger-bit deals like this:
[ame="http://www.amazon.com/Cal-Van-Tools-908-03-Finger-Driver/dp/B0066PI4GA/ref=sr_1_2?ie=UTF8&qid=1453687122&sr=8-2&keywords=finger+screwdriver"]Amazon.com: Cal-Van Tools 908-03 Finger Bit Driver, (Pack of 3): Automotive[/ame]
isolato is offline   Reply With Quote
Old 02-21-2016, 06:53 PM   #102
jg7
Drives: 2016 Scion FR-S
Thanks for the great directions.
I added these and they look nice plus add some protection to the paint. Got them from Amazon. I pulled the wheels off, so it took a little more time, but made getting to everything easier. Plus, it was a way of double checking the torque on the wheel lug nuts.
jg7 is offline   Reply With Quote
Old 03-06-2016, 01:35 PM   #103
Peaty
Scooby***s Guy
Peaty's Avatar
Drives: 2019 Impreza Sport - MT
Thanks for the install page, it was a snap. Just installed them on my 2016 BRZ, it's exactly the same as expected. I got mine from Amazon too about 60 bucks, OEM Toyota parts. Surprisingly the US Post delivered them on Sunday to my door!
Peaty is offline   Reply With Quote
Old 03-15-2016, 07:24 PM   #104
STEWARDORNG
Drives: 2016 BRZ
Thumbs up Thanks
Thanks for doing the write up easy install mine came with no instructions if you have access to a right angle drill it makes it even easier. they look great just what I was looking for!
STEWARDORNG is offline   Reply With Quote
Old 03-31-2016, 03:08 PM   #105
AFewBricksShy
AFewBricksShy's Avatar
Drives: 2015 WR Blue BRZ
Same here for my 2015. Thanks for the writeup.
AFewBricksShy is offline   Reply With Quote
Old 04-03-2016, 07:47 PM   #106
ARTBRZ
Aloha!
ARTBRZ's Avatar
Great write up.
I started to notice rock chips after installing MPSS. Decided to to install this oem mud guards. If this wasn't mentioned already, you don't need to take off the wheels. Just turn the wheels and you'll have enough room in the front. Instead of drilling in the back I decided to use a screw to fasten the one that requires drilling.
I think it's the manufacturing process but the fitment for he driver side is also off on mine. If I were to do it again I would trim it a little before installing.
ARTBRZ is offline   Reply With Quote
Old 10-04-2016, 11:35 PM   #107
Sean_IRL
Sean_IRL's Avatar
Drives: Toyota 86
Has anyone installed these on a lowered frs/brz/86? I wasn't able to order them on the car from the factory as I already chose to have her lowered. Is there a problem with ground clearance with these mudguards if your car is lowered an inch?
Sean_IRL is offline   Reply With Quote
Old 10-05-2016, 09:29 AM   #108
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
No concerns for me. Still plenty of clearance.
Old 10-05-2016, 03:20 PM   #109
Sean_IRL
Sean_IRL's Avatar
Drives: Toyota 86
Thanks! Good to hear
Old 12-12-2016, 02:38 PM   #110
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I don't suppose anyone has tried these on a 2017 BRZ? I just ordered a set so I guess I will find out. Most everything is the same on the cars so I don't expect any issues...
justinco is offline   Reply With Quote
Old 12-28-2016, 12:17 PM   #111
TMXSTAR
I'm bad at English
TMXSTAR's Avatar
Drives: Subaru BRZ 2016 M/T
Will this work if you got a STI sideskirt?
Sent from my SM-G900F using Tapatalk
TMXSTAR is offline   Reply With Quote
Old 12-28-2016, 12:57 PM   #112
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Well they work fine on a 2017 too. Used this DIY to install mine
[ame="https://www.youtube.com/watch?v=vR9McA67ptU"]BRZ mud flaps install - YouTube[/ame]
I wouldn't think so since the skirt covers the area where the mud guard would go.
The Following 2 Users Say Thank You to justinco For This Useful Post:
DocWalt (12-28-2016), TMXSTAR (12-28-2016)
flaps, guard, mud, mudflaps, rally armor
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 03:27 PM
Mud Guard Question geb2391 BRZ First-Gen (2012+) — General Topics 36 03-01-2013 06:37 PM
Opti guard in or near oklahoma? Flako Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 10-22-2012 07:00 PM
Opti Guard ExWhyZer0 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 10-10-2012 03:22 PM
'13 BRZ | Opti-Guard fun! michakaveli Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 09-02-2012 05:50 PM
