#15 | |
Drives: HKS
The thing that makes the springs creak is vibration or movement between the spring and the spring perch. Two things come to mind that could be causing that. One is, if the spring was truly loose when you installed it, then it could be moving when you go over a bump. The other, and the more likely, is that you have the car too low. Too much compression on the spring can cause it to bind, so when you go over a bump and the spring moves, it is binding on the perch. Make sure that if you have made adjustments to the ride height you do so by turning the shock body and *not* adjusting preload on the spring. |
| The Following User Says Thank You to Torry@HKSUSA For This Useful Post: | Bach415 (03-04-2016) |
#16 | |
Drives: Whiteout FRS
When I got the coilovers brand new from the box, the springs on the front were completely loose. You were able to move the springs up and down ~2 inches between the lock and the camber plate and spin it. I had turn the lock perch that the spring sits on so that the spring is fit snug and doesn't move and lock with the 2nd perch. Also after installing and letting the coilovers sit in, I noticed that the fronts were higher than the rears at stock. I did lower it more but I still have about 1-1.5 inch gap from the tire(stock wheels) to the fender arch for the front. The sound was there even before I even lowered the car. |
#17 |
Drives: Sapphire Blue ‘23
I had a shop install them but I think the readjusted preload to compensate for lowering slightly more than how they came out the box. Endlink wise, I put back on my whiteline adjustable front endlinks to get rid the binding
| The Following User Says Thank You to Jdogg88 For This Useful Post: | Bach415 (03-05-2016) |
#18 |
Inactive
Drives: .
Mine were all set with the same measurements the instructions say they shipped them with, I double checked all the preload, measured the thread length and everything checked out down to the millimeter, if yours were loose out of the box then someone forgot to set them or whoever was selling them may have messed around with the set to see how the quality was.
#19 | |
#21 | |
Drives: HKS
| The Following User Says Thank You to Torry@HKSUSA For This Useful Post: | Bach415 (03-07-2016) |
#22 |
Drives: HKS
Preload on the springs should not be adjusted to change the ride height. Ride height should be adjusted by threading the shock body into the mounting point, not adjusting preload.
#23 | |
Amazing Member
Drives: 2014 Whiteout FR-S
Currently I'm lowered at about 39mm, with a bit of rake in the back (the back being about 5mm higher than the front). The HKS manual recommends not lowering the car more than 42mm in the front as these are MacPherson struts. This translates into 17mm of free thread between the locking spring and the locking bracket. It does sound like you're ride height setup is in line with this, but I can take a photo of the manual and the above info for you if you would like. One thing that does bother me about the coilover package are the spanners that are shipped with them. At first they looked solid and well made but I soon realized that they didn't fit all that well over the locking perches / rings, and tended to chew away at them, which made me a bit annoyed as these are brand new coilovers, and having to fine tune the ride heights a number of times took some of the lustre away from them. I finally remembered that I had some old spanner wrenches from another coilover set lying around, and they fit like a glove. I'm not sure what HKS was thinking with their spanners. Wish I could get some new locking brackets for my rear (I cleaned them up and touched them up with paint, but they're still not NEW and I'm anal about this sort of stuff)... Last edited by [YOYO]; 03-07-2016 at 01:43 PM. |
| The Following User Says Thank You to [YOYO] For This Useful Post: | Bach415 (03-07-2016) |
#24 | |
#25 |
Drives: HKS
If you're looking for the installation manual, please see attached. The second half of the book is in English.
#26 | |
Amazing Member
#27 |
Drives: 2013 10 Series FR-S
Just got a set of the Hipermax IV sp, I've installed them without any changes to the coils but still seem to be getting that creaking sound from the front. Any help?
#28 |
The creaking sound never went away for me for the fronts despite changing ride height, preload, and re-installing the whole fronts. I'm just thinking it's probably the stiffness of the springs that is causing the creaking noise. I ended up just switching to another set of coilovers which eliminated the possibility of it being the end links (still running the same end links that came with the HKS suspension).
| Passenger seat height adjustment? | cbf | BRZ First-Gen (2012+) — General Topics | 36 | 09-05-2022 06:32 PM |
| Seat Height Adjustment | Norman Tyler | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 11-30-2014 07:26 AM |
| FS: HKS HiperMAX GT IV Coilovers | RyanITV | Brakes, Suspension, Chassis | 16 | 11-27-2014 01:06 PM |
| Need more camber from HKS Hipermax Coilovers | darthwong1138 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 07-22-2014 05:48 PM |
| Clutch pedal height adjustment, just do it | Suberman | CANADA | 0 | 10-24-2013 06:00 PM |
