Old 07-03-2013, 12:40 AM   #1
darthwong1138
Drives: Raven FR-S
Need more camber from HKS Hipermax Coilovers
I am currently running HKS Hipermax IV coilovers for my FRS and even with the camber plates maxed out i am only getting -1.7 degrees of camber up front. I would really like to get up to -2.5 to -3 degrees of camber. Should i get camber bolts(SPC or Whitline)to help me get additional camber? I noticed some people are getting up to -3 degrees no problem with other coilovers. Is it just because their camber plates have more adjustability? Thanks in advance!
darthwong1138 is offline   Reply With Quote
Old 07-03-2013, 12:56 AM   #2
ayau
Drives: Some rust bucket
Make sure your camber plates weren't installed backwards. You can add additional camber by adding a camber bolt or the OEM crash bolt into the top slot of the strut.
I was able to get over -3 with the OEM crash bolts and camber plates set to max.
Old 07-03-2013, 01:01 AM   #3
darthwong1138
Drives: Raven FR-S
Camber plates are labeled on the top with "L" and "R" markings and i verified that they are on the correct side. What Coilovers are you running? Thanks!
Old 07-03-2013, 01:09 AM   #4
ayau
Your camber plates can probably turn 180 degrees. See if that will net you more camber. Maybe taking a picture of how the plates look like might help.
I have Eibach R2 coilovers. They come with camber plates.
Old 07-03-2013, 01:27 AM   #5
darthwong1138
Drives: Raven FR-S
Here is a pic of the passenger side camber plate
Old 07-03-2013, 02:23 AM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
How low can you go in the front adjustment-wise? A standard MacPherson strut camber is set by the camber plates, and also limited (to some extent) by how much you can lower the car via suspension.
If you can't slam the car you can't get the camber you want.
-alex
Old 07-03-2013, 02:58 AM   #7
darthwong1138
Drives: Raven FR-S
Here is a pic so you can get a general idea of the ride height of the car. The rear is as low as it can go but the front can still be lowered more. Ill try to take a better side profile pic of the car when i get a chance.
Old 07-03-2013, 08:17 AM   #8
troek
troek's Avatar
Drives: 2012 Toyota 86
nice garage
Old 07-03-2013, 12:18 PM   #9
Hotchkis
Hotchkis's Avatar
We've seen different coilover kits that will inherently give more or less negative camber based on the way their lower upright mount is designed.
Like ayau stated, I'd suggest installing the subaru crash bolts and max those to full negative. Then use the upper camber plates to fine tune the camber. Both may need to be maxed out if you are looking for -3° though.
Good Luck!
Hotchkis is offline   Reply With Quote
Old 07-03-2013, 09:13 PM   #10
darthwong1138
Drives: Raven FR-S
Just ordered some crash bolts. Thanks everyone for the replies!
Old 07-05-2013, 10:13 PM   #11
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
i have -5 up front, looking for ways to get more
SLICVIC is offline   Reply With Quote
Old 07-19-2014, 07:12 PM   #12
Mr.Frs
@mr_frs
Mr.Frs's Avatar
Drives: Release Series 1.0 #1382
Hey I just got a set of these and have a terrible clunk in my rear driver side. Have you had any clunking issues? Can't figure out how to get rid of it.
Instagram: @mr_marlongamez
Crew: @lowweezyana
Mr.Frs is offline   Reply With Quote
Old 07-20-2014, 08:18 PM   #13
darthwong1138
Drives: Raven FR-S
thats odd. i never had any noise issues when i had these coilovers installed.
Old 07-20-2014, 08:46 PM   #14
mrk1
Drives: Sterling BRZ Ltd
Mine are not maxed out and I can eye ball it and see its more then 1.7 degrees. What is your ride height like?
I second the no clunks with these.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
megan racing street series coilovers w/front camber plates 256brz2013 Brakes, Suspension, Chassis 33 07-01-2013 09:39 AM
HKS HIPERMAX IV GT - Under $2200 from TAP Auto! TAP Auto Parts Brakes, Suspension, Chassis 5 06-06-2013 04:26 AM
