#15 |
I thought you were done?
![]() Stock camber is not adjustable and is anywhere from 0-1 degree, most of the time very near 0. For handling purposes in our sports car, camber is good. For a daily driver, 1.3-2.0 is a good starting point. Ideally you want more camber in the front than the rear. Your rear probably has 1.5 or so from lowering, while the front is less. You should also get a side skirt to hide that scratch I see in your pic on the right side of the car. And a front lip to match.
#17 | |
Drives: Scion FR-S Black
#18 | |
Smoke/semi smoked side markers would look really nice on your black car too.
| The Following 2 Users Say Thank You to swarb For This Useful Post: | Cole (03-04-2016), MisterSheep (03-04-2016) |
#19 |
Killed Scion
Drives: 2013 FR-S Whiteout
Poor guy wanted to tell us he's basically done with his "build"... and we're being assholes and telling him to buy more parts
the mod bug is addictive.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#21 | ||
None of your mods are "major" and they are all "unneeded". Swarb already clearly told you what it will do and why you should do it. It is a relatively cheap and easy thing that will improve the car. Why only do part of the job and call it good enough when for a little more you can finish it and call it done right?
#22 | |
http://www.phasteksport.com/2013-FRS...mber-81305.htm Basically, when you lowered the car, the camber will be off (because the OEM camber bolt is "fixed") therefore the suspension geometry will be "off". The fix is to put a different bolt in there, so as the camber can be adjusted a bit. You're almost "done" ...... a couple of bolts and an alignment and you're good to go ..... humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (03-05-2016) |
#23 |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
need moar tint
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
| The Following User Says Thank You to Aztec For This Useful Post: | Marco_86 (03-05-2016) |
#24 |
Takeshi
Drives: 2014 FRS Whiteout
You're not done
"Be kind whenever possible. It is always possible." Dalai Lama ![]() ![]() |
#25 |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Heh, like all has already said. You're never ever "finished" with a build.
10k+ now and I thought I was done for good after all the exterior tS parts... Now I'm going to have to do some more under the hood and then work my way inside the interior... You're NEVER finished.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#26 |
#27 | ||
This is two.
#28 | |
![]() This is a good review: http://www.ft86club.com/forums/showthread.php?t=25001 For your DD, I'd suggest you just ask the alignment shop to put the front and rear within spec ..... maybe the camber a little on the negative side of the range. humfrz |
| So I just finished detailing my car... | Phantobe | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 01-09-2015 08:43 PM |
| WTB: OEM Tails Finished RED | dizzario | Want-To-Buy Requests | 5 | 09-01-2014 04:01 AM |
| Finished My Stereo Install! | michaelahess | Electronics | Audio | NAV | Infotainment | 14 | 08-02-2012 12:36 AM |
| just finished this photoshop | dieselstation | BRZ Photos, Videos, Wallpapers, Gallery Forum | 19 | 03-30-2012 06:34 PM |
