Old 03-03-2016, 09:36 AM   #57
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
Originally Posted by weederr33 View Post
If it comes undone after the threadlocker, I may just invest in the actual JDM shortshifter.
I put loctite on the bolt, after reading this thread, a few months ago and still seems to be holding up well. How is yours holding up?
TruRace is offline   Reply With Quote
Old 03-03-2016, 09:45 AM   #58
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
It's holding up fine. I caked the bolt with red loctite so it shouldn't come undone.
MS, CSCS, TSAC-F, CPT
Old 03-03-2016, 09:58 AM   #59
jcw99
Drives: swp mt '14 brz premium
Bingo. I struggled like hell with one just like it. Finally gave up customizing the customization. It's an atrocious design relying on completely unrealistic goals for tolerance. Throw that POS in the trash or demand a refund. If you must have a short shifter, get the JDM actual lever.
...or the kartboy.
Sorry. The entire line of people allowing that thing to go to market should be fired.
What shifter are you using now and what do you think of it?
jcw99 is offline   Reply With Quote
Old 03-03-2016, 10:25 AM   #60
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Originally Posted by KevinA View Post
Does anybody know if the TRD quick shifter kit will fit a RHD GT86
Thanks
I believe Japanparts.com sells the whole shifter assembly.. which should work on a RHD gt86. I believe the USDM quick shifter should work as well because the transmissions are similar.
Instagram: trevor.parque
Old 03-03-2016, 10:34 AM   #61
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I find it interesting that quite a few of you had issues with the bolt backing out. Had mine for about a year now with no issue, and I didn't use any loctite. (knock on wood). I went this direction because it was said it was cheaper and better than the JDM short shifter. It also didn't lower the shifter at all. Only thing better would be to upgrade to the CAE shifter.
Old 03-03-2016, 01:08 PM   #62
I'm on the oem but I'm also modifying a second one to actually shorten it. I'm integrating the reverse lockout with the knob itself. It's half finished on my workbench. -___-
jcw99 (03-03-2016)
Old 03-03-2016, 03:47 PM   #63
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Mine took a little over a year/15k miles to start coming loose. Good luck!
JohnJuan is offline   Reply With Quote
Old 03-03-2016, 04:18 PM   #64
What don't you like about the JDM unit? I was under the impression it was just like the OEM but with a longer arm below the spherical joint.
MisterSheep (03-03-2016)
Old 03-03-2016, 04:26 PM   #65
DustinS
DustinS's Avatar
I didn't get it. Just the first post that I remember reading when I was in the market for a short shifter:
"I've heard the opposite feedback about the TRD jp one. It's $600 or so, and the feedback from someone local that has it, said its barely any different. I was all keen on it, till he told me not to bother."
The guy skipped the JDM and bought the TRD Quickshifter and loved it. I have 0 complaints about my Quickshift, and as I said previously, the only thing I could see being better is the CAE Motorsports Shifter.
Old 03-03-2016, 05:28 PM   #66
Holy exchange rate, Batman, I had no idea! Half that is still way too steep.
I don't wish the epic fail I experienced on anyone. Loctite has its place but the idea of slathering glue onto a fastener to keep it from backing out of a cockeyed joint insults my sensibilities. Just being honest about strictly that point. I'm glad some (maybe most?) of you guys have had success with it. When it's tight, it feels great.
Sportsguy83 (08-24-2016)
Old 03-03-2016, 10:19 PM   #67
jcw99
Sounds cool!
Old 03-03-2016, 10:35 PM   #68
weederr33
weederr33's Avatar
Where are the pics?!
The Following User Says Thank You to weederr33 For This Useful Post:
Ultramaroon (03-04-2016)
Old 03-04-2016, 12:45 PM   #69
I promise I'll share when I'm ready to assemble even if it turns out to be a flop.
Old 04-03-2016, 05:30 PM   #70
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
I had a TRD Quick Shifter for almost a year before ditching it for the Kartboy. It's hard to explain, but the Kartboy feels much better than the TRD. Maybe it's smoother? If you can cough up the extra dough for the Kartboy and don't mind the high rpm rattles, it's worth every penny over the TRD Quick Shifter.
xxBrun0xx is offline   Reply With Quote
trd quick shifter ? vibration noise Pcharliep04 Issues | Warranty | Recalls / TSB 5 08-01-2014 02:42 PM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
TRD quick shifter (sold) lovebeingbleu98 Transmission and Driveline 13 04-09-2014 06:25 PM
trd quick shifter? tjohnson104 Engine, Exhaust, Transmission 6 01-26-2014 02:37 PM
Quick Release or Quick Lock Steering Wheel and Theft defense too? 1086 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-24-2014 04:50 PM
