Old 03-02-2016, 11:05 AM   #1
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Crickets and oil temps
Hey guys. I found when my oil temps sit around 190F crickets are no where to be found, however when I remove the thermostat from my oil cooler and the oil gets up near 212F the crickets come back without fail. Could oil temps possibly have something to do with crickets? Has anyone else with an oil cooler noticed this.
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
lupindub (03-02-2016), Riftur (03-02-2016)
Old 03-02-2016, 11:20 AM   #2
Riftur
Riftur's Avatar
I would love to know if this is true. I see the same thing when I monitor it in my torque application. The crickets usually start when my oil hits 205-210. I am going to monitor it much more closely the next few days to get an exact temp.
Riftur is offline   Reply With Quote
The Following User Says Thank You to Riftur For This Useful Post:
go_a_way1 (03-02-2016)
Old 03-02-2016, 11:45 AM   #3
lupindub
Drives: Scion FR-S
Yep you nailed it freindo. My commute to work is approximately 10 minutes and I never get crickets since my oil temp. never gets to operating temperature. However, on the weekends when I go on longer drives and let the car get to operating temp., the crickets return. Crickets are definitely affected by oil temp.
lupindub is offline   Reply With Quote
The Following User Says Thank You to lupindub For This Useful Post:
Old 03-02-2016, 12:12 PM   #4
ハチロク
ハチロク's Avatar
Drives: 2014 Ultramarine FR-S
Unfortunately you guys have fallen into the trap of believing that correlation implies causality. It could be that oil temp affects crickets or that some other factor that happens to correlate with oil temp. Like for example rising temps in the high pressure fuel lines or some ecu mapping that kicks in after the engine has heated up. Can't really draw any conclusions unless there's a way to isolate the variable, in this case oil temp.
ハチロク is offline   Reply With Quote
The Following 5 Users Say Thank You to ハチロク For This Useful Post:
go_a_way1 (03-02-2016), humfrz (03-02-2016), lupindub (03-02-2016), Tan (03-04-2016), zc06_kisstherain (03-02-2016)
Old 03-02-2016, 12:14 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
This is true haha!! We need some science all up in here stat
Old 03-02-2016, 12:23 PM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
some people will buy oil cooler because go_a_way1 and vendors should pay him for marketing. j/k
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Old 03-02-2016, 12:33 PM   #7
stevesnj
stevesnj's Avatar
The High Pressure Fuel Pump is driven by a lobe on the camshaft. The pump valve has a stem like an intake and exhaust valve and has a valve spring. So yes oil temp could affect the Pump noise.
My 2016 Build thread
The Following 3 Users Say Thank You to stevesnj For This Useful Post:
go_a_way1 (03-02-2016), Riftur (03-02-2016), zc06_kisstherain (03-02-2016)
Old 03-02-2016, 12:52 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
LOL People should buy stuff just because I run it anyways.
All jokes aside I 100% believe anyone who drives their car more then 75% would greatly benefit from an oil cooler.
Decay107 (03-02-2016), zc06_kisstherain (03-02-2016)
Old 03-02-2016, 01:09 PM   #9
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I don't know, It's pretty hard to heat soak on the street. Of course, an oil cooler should be installed well before even looking at a track.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
Old 03-02-2016, 01:14 PM   #10
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
I used to hit 260F on the street with little effort. Now granted that could have been easily avoidable if I changed my driving habits
Old 03-02-2016, 01:27 PM   #11
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Curses! Foiled again!
Now I cannot go around claiming that ambulances are the most dangerous vehicles on the roads.
That is because over 80% of the passengers that ride in ambulances end up in the hospital...
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
Old 03-02-2016, 01:27 PM   #12
Decay107
Decay107's Avatar
I never saw over 240 and I was absolutely railing on it. Even then it stabilized quickly after I let up.
Old 03-02-2016, 01:34 PM   #13
justatroll
justatroll's Avatar
Then there is something wrong with your car or you drive like mad max on the street.
I could not get my temps above 240 in 20 minute track events (not full blown race, and street tires).
Old 03-02-2016, 02:17 PM   #14
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Really?? I was also measuring temps right at the filter if that matters? and I was driving a little more aggressive then I should it was also a hot day with a mix of open roads and traffic.
N/A typical oil temps JB86'd Engine, Exhaust, Transmission 13 12-16-2014 01:42 AM
Oil temps with JR SC and JR oil cooler dp1 Tracking / Autocross / HPDE / Drifting 87 11-14-2014 01:35 AM
Oil Temps Fish Eagle AFRICA 13 07-22-2014 06:53 PM
Intake air temps mrk1 Engine, Exhaust, Transmission 2 07-10-2013 08:56 PM
