#15 | |
| The Following User Says Thank You to Kostamojen For This Useful Post: | Chase1996 (02-26-2016) |
#16 |
Drives: 370z
The extra roll is probably from the lowering springs. One thing to try would be roll center adjusters, and/or raise the car back up.
What wheels did you get? are they significantly heavier than stock? lower bump travel, better tires, and more unsprung weight all need more spring. You might be bottoming out on your suspension which is really bad for traction. |
| The Following User Says Thank You to totopo For This Useful Post: | Chase1996 (02-26-2016) |
#17 |
Drives: Scion FR-S Black
To try and answer as many questions as I can...
Size of my tires is 225/40/18 but I have eibach sport line, with Michelin pilot super sports on 18x8.5 rims. I got my car aligned at a professional dealer but everything was not put on at the same time...I have rear lower control arms because when I put on the springs my car would not align properly without them so I had to get them. I am seeing her it looks like a strut bar/sway is not the answer. And it seems to be something else...I might take it to Toyota and get it aligned what specs should I get them to get it too? Everything is new also. I have had the rims and tires for going on 3 months. The springs and stuff less then a month. Below is a picture of my alignment specs Lord hoping it uploads. The speed at which I'm taking corners depends...at about a 60 degree angle it starts skidding around 65 give or take |
#18 |
Picyure
#19 |
looks like it might be the rear toe
#20 |
Drives: 2015 CWP BRZ Limited
Yeah, the Sportlines don't give you enough bump travel. Sticky tires will increase roll and combined with not enough bump travel, you're finding the bottom of your suspension travel in hard turns. You could certainly use a little more camber front and rear, but the setup you have *should* favor understeer, if anything.
Also, where are you turning 60 degrees at 65MPH? That's a little brisk for the street. EDIT: Not to say that I'm blaming the Sportlines for loss of grip, necessarily. Just pointing out a potential issue with the setup. Last edited by jawn; 02-26-2016 at 11:21 PM. |
| The Following User Says Thank You to jawn For This Useful Post: | Chase1996 (02-26-2016) |
#21 |
#22 | |
#23 |
Custom User Title
Drives: Asphalt FR-S MT
So I'm going to point out the elephant in the room. Can you drive? Everything you mentioned in the first post says you don't actually know how to use your brake pedal, steering wheel, and gas pedal properly. Suspension, tires, whatever; none of that matters if you are clueless behind the wheel.
| The Following 3 Users Say Thank You to boredom.is.me For This Useful Post: |
#24 | |
#25 |
Custom User Title
Ok, just checking. I wasn't trying to be rude or offensive.
| The Following User Says Thank You to boredom.is.me For This Useful Post: | Chase1996 (02-26-2016) |
#26 |
#27 | |
Looking st everything you've mentioned now, its going to have to be the springs and potentially blown shocks as well. You need to read up on what other people are using. |
#28 |
I'm pretty sure my shocks aren't blown...not sure what I described that would make you think that? Also, I have brand new springs?
| Corners, corners, corners :-) | Artalos | BRZ Photos, Videos, Wallpapers, Gallery Forum | 4 | 06-23-2015 12:27 AM |
| losing traction? | sskillzz12 | Engine, Exhaust, Transmission | 4 | 03-24-2015 09:51 PM |
| Losing Control. | Asterisked Accolade | Other Vehicles & General Automotive Discussions | 18 | 04-01-2013 10:39 PM |
| Been on a losing streak with my car lately...help | sa1126 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 04-01-2013 10:18 PM |
| Lowered Car, Losing traction while getting off drive ways | 86_ZN6 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 10-26-2012 10:02 AM |
