Old 02-25-2016, 09:34 PM   #15
raven1231
Originally Posted by Chase1996 View Post
So, if i was to get of OFT/OFH I would be in really good condition? ALso, when putting a header on, what other modifications need to be done? I know the check engine light will come on, is there anything else that might happen?
Also, if you know how to get that light to go off.
The ots tune will take care of it
Old 02-25-2016, 09:43 PM   #16
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Here's what you need to know, the check engine light comes on due to a P0420 code that appears called catalyst inefficiency or something like that. The OFT Stage 2 UEL tune disables that so no light will appear, you have nothing to worry about if you get the combination.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
steve99 (02-26-2016)
Old 02-25-2016, 09:57 PM   #17
JB86'd
JB86'd's Avatar
Drives: JAWS
If you're going UEL header, you should read some more reviews on this forum. Generally Borla is not highly regarded here, and I'm not sure about the FT86sf header.
What I do know firsthand that the OFH sounds and performs great, bang for the buck is high there. Also JDL UEL sounds and performs, lifetime warranty, just a bit more pricey. (I've owned both)
I've also read good things about the Tomei/Gruppe S header (pretty much same thing).
Regardless of your header choice, the OFT off the shelf tunes will work for you. You can read up on customizing your own tune as well to suit whatever header/fuel you're running. It's also got super helpful features such as real time display and datalogging.
Oh also, I wouldn't bother with the front pipe/overpipe unless you're going for every single last bit of HP. From what I've heard, for a daily driver it's a lot more noise/rasp, and not a huge power gain.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
Old 02-25-2016, 10:23 PM   #18
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
This will be solved very soon with a new front pipe that is in development by a certain company
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
The Following User Says Thank You to Mr.Impreza For This Useful Post:
JB86'd (02-26-2016)
Old 02-26-2016, 09:43 AM   #19
jegglz
Drives: 2013 frs
Recently put a gruppe-s UEL and Berk catted frontpipe on my frs, Noise is pretty manageable. Got the car with the trd catback already on it. 6th gear cruising is really quiet.
Edit: i would not be too worried about the custom tune, i am running on the openflash stage 2 and it seems pretty sorted out.
jegglz is offline   Reply With Quote
Old 02-26-2016, 09:46 AM   #20
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I am a little late to the party but I have a borla UEL and it works but its nothing fancy. quality is less then what I expected from them, but I bought mine when they first came to the market. As far as tunes go find a good E tuner and get it done that way. Thats what I did and I could not be happier. I would also recommend the JDL header if you want quality
Chase1996 (02-26-2016)
Old 02-26-2016, 12:35 PM   #21
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
I want something louder/lighter than my Perrin CBE without the FP rasp that the Perrin tames. Any details?
Luftwaffel is offline   Reply With Quote
Old 02-26-2016, 12:39 PM   #22
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
The company making it is a very high quality company
http://www.ft86club.com/forums/showthread.php?t=101471
Old 02-26-2016, 03:53 PM   #23
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I speak from experience, on my 6th,(and last!) header.
The only reason to get a catted header is if your racetrack requires it, since even an aftermarket catted header is still illegal in all 50 states. Just hang onto your stock header and front pipe and reinstall it every two years. I have been tuning with the OFT for years, and I finally got a UEL header. Hands down, get a UEL for a daily driver. It gives better part-throttle acceleration than an EL header. After all, you can't drive full-throttle everywhere, can you? I got the Tomei Expreme UEL, which is exactly the same as the Gruppe-S UEL, but I paid more. I would suggest buying the OFT, and the Gruppe-S UEL and over-pipe combo, http://www.ft86club.com/forums/showthread.php?t=81839 , and I'll send you my latest "Shredder" OFT tune for free.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
The Following User Says Thank You to KoolBRZ For This Useful Post:
Old 02-26-2016, 04:13 PM   #24
FRSBRZGT86FAN
Originally Posted by KoolBRZ;2561555 [B
I'll send you my latest "Shredder" OFT tune for free.[/B]
Shredder tunes? What has been modified in them that makes them special? Are the Cal Ids compatible with autos more specifically D00D?
Old 02-26-2016, 05:04 PM   #25
Chase1996
Drives: Scion FR-S Black
Why the Gruppe-S UEL over the OFH?
Chase1996 is offline   Reply With Quote
Old 02-26-2016, 05:19 PM   #26
KoolBRZ
KoolBRZ's Avatar
Just sent you a PM. I'm trying not to hijack this thread. My point was that instead of spending money on a tune designed to work best with one Intake/Exhaust setup, instead get an OFT and a good quality header/over-pipe combo. Then re-tune for free with the OFT for any other change you might make to your Intake/Exhaust setup.
Old 02-26-2016, 05:25 PM   #27
KoolBRZ
KoolBRZ's Avatar
I personally spent more $ on a Tomei Expreme UEL because I like the cast collector much better than any other welded collector. I feel it offers less restriction and a better reflection point for harmonic tuning. Unfortunately I didn't find out that the Gruppe-S UEL is the same but cheaper until after I bought my Expreme UEL header. It's like I'm giving you money telling you about this.
CEL issue after dyno tune reyruiz191 Software Tuning 10 07-29-2016 08:50 PM
Need a dyno tune in sydney brz961 AUSTRALIA 10 06-19-2016 07:57 AM
What a dyno tune can do for you. jonbonazza Software Tuning 9 03-14-2015 11:53 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
Dyno tune near CNJ? Craig NY / NJ / CT / PA 2 01-31-2013 06:57 AM
