Old 02-24-2016, 09:22 PM   #1
ckellykcco
Link
Drives: 2015 Scion FR-S
Over pipe taps subframe
Hey guys. I recently installed the isr performance over pipe / front pipe combo and the over pipe doesn't have enough clearance and taps the sub frame on initial take off or left turns. Been trying to find a solution! Anyone else get rattle from their over pipe and fix it? Still running the stock header.
ckellykcco is offline   Reply With Quote
Old 02-24-2016, 10:00 PM   #2
Cole
Not a troll
Cole's Avatar
You could try loosening booth ends of it and adjusting so that it sits nicely in the middle of the gap. Otherwise, it could just be poor fitment of the part.
I have a no name eBay over pipe and I haven't had a problem with it. I just took the time to line it up nicely when I installed it
Cole is offline   Reply With Quote
Old 02-25-2016, 07:36 PM   #3
AlexWood
Drives:
Stiffer motor mounts would do the trick...
AlexWood is offline   Reply With Quote
Old 02-26-2016, 12:10 AM   #4
Wire that sucker over with baling wire ........
Find an old coot at the hardware store ... he will fix you up with the proper wire.
The redneck way would be to stick a crowbar up there and bend it over so it don't want to go back that way.
Cole (02-26-2016)
Old 02-26-2016, 09:17 AM   #5
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
If the problem is purely part fitment wrapping the over pipe in a header wrap would help reduce the noise as well.
Gear_One_Performance is offline   Reply With Quote
Old 02-26-2016, 09:31 AM   #6
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Thats Odd I dont have any issues with my ISIS(ISR) overpipe. I guess it depends on header and front pipe placement as well.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Fuse Taps for Fog Lights Bergen23 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-17-2014 01:08 AM
Reinforced subframe brn12345 Tracking / Autocross / HPDE / Drifting 1 06-03-2014 04:14 PM
REVIEW | DC Sports rear subframe brace / rear subframe lateral brace mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-10-2014 09:59 PM
FS: Wire taps + resistors (for LED turn signals) Laika Exterior Parts (Aero, Lighting, Etc.) 0 01-13-2013 10:50 AM
Crawford Performance at FRS release event - taps into ECU ! NorCalRider Engine, Exhaust, Transmission 49 12-09-2011 02:13 PM
