Old 02-25-2016, 09:57 AM   #1
jlugo711
Drives: 2014 GT86
Glass Cleaning
Wanted to know what products you guys use to clean your glass. I live in FL and we have hard water down here so after a car wash there are hard water spots on the glass. It seems that no matter what I try to do I can't get those tough water spots off the glass and it's starting to get aggravating! I know the best way is polishing the glass but, in between full details there's just not much time for that..
Any recommendations on product or process?
jlugo711 is offline   Reply With Quote
Old 02-25-2016, 10:59 AM   #2
Mini&aVette
Drives: 2015 FR-S 1.0 very yellow
I live in FL and use autoglym window polish. It's just as easy as windex and you use so little I've had this bottle for 4 years. Look it up on Amazon.
Mini&aVette is offline   Reply With Quote
The Following User Says Thank You to Mini&aVette For This Useful Post:
jlugo711 (02-26-2016)
Old 02-25-2016, 11:11 AM   #3
czechm8
520
czechm8's Avatar
Drives: Series 10 Fr-s #520
I had issues with glass cleaner leaving streaks and fogging no matter what cloth or wipe I used. Found Sparkle Glass Cleaner on a recommendation........awesome stuff.
You may want to clay bar the windscreen to remove any debris, or use #0000 steel wool.
czechm8 is offline   Reply With Quote
The Following User Says Thank You to czechm8 For This Useful Post:
Old 02-25-2016, 11:12 AM   #4
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Honestly after a car wash you should just keep a microfiber drying towel and dry off the car (or at least the glass) to avoid the spots. Takes a minute or two for a car this small.
murdoc is offline   Reply With Quote
Old 02-25-2016, 11:36 AM   #5
tobin
tobin's Avatar
Drives: '13 BRZ
Any auto glass cleaner is fine. I like [ame="http://www.amazon.com/Stoner-91164-Invisible-Glass-Cleaner/dp/B0007OWD2M"]Stoner Invisible Glass[/ame]. The key is to use plain (non-glossy) crumpled up newspaper instead of paper towels. Always do a final polish with a new, clean piece of newspaper.
tobin is offline   Reply With Quote
The Following 2 Users Say Thank You to tobin For This Useful Post:
Createddeleted (02-26-2016), jlugo711 (02-26-2016)
Old 02-25-2016, 11:40 AM   #6
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I normally spray all my windows with an glass cleaner I picked up at the automotive store, after every wash. Clean inside and outside. Go in a top to bottom motion for outside and then a side to side motion on the inside, that way you can see where you have leftover streaks that need to be wiped out.
Instagram: trevor.parque
Old 02-25-2016, 12:54 PM   #7
Originally Posted by tobin View Post
Any auto glass cleaner is fine. I like Stoner Invisible Glass. The key is to use plain (non-glossy) crumpled up newspaper instead of paper towels. Always do a final polish with a new, clean piece of newspaper.
Yep, the Stoners product, along with a microfiber towel works for me.
A claybar may remove hard water stains already there.
Old 02-26-2016, 07:12 AM   #8
jlugo711
Drives: 2014 GT86
It's more or less these nagging water spots that seem to always be on the glass no matter how much I wash/dry the car or what method I use.
I appreciate all the recommendations, I'm going to try each one until I find which one I like the most.
Old 02-26-2016, 12:35 PM   #9
You might try some vinegar or some ammonia or some acetone or some of that bathroom cleaner (Lime away) that claims to clean off hard water deposits.
......and...... there is always hydrochloric acid .......
Ultramaroon (02-26-2016)
Old 02-26-2016, 12:57 PM   #10
stevesnj
stevesnj's Avatar
I had bad fogging and streaking issues. I finally tried ethyl alcohol. Worked amazing. May have to do it a few times but it gets deep down dirt and grease off the glass. Use a microfiber to polish it after.
My 2016 Build thread
Old 02-26-2016, 01:43 PM   #11
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
[ame]http://youtu.be/q4WwOrkgXlc[/ame]
The Following User Says Thank You to ZOMFGAARON For This Useful Post:
humfrz (02-26-2016)
Old 02-26-2016, 07:22 PM   #12
Teseo
Drives: frs
What to use to clean the inside and cristals are tinted?
Old 02-27-2016, 12:59 PM   #13
radroach
Drives: car
If you're getting water spots on the glass then you might want to start waxing your glass. Other than that, just be quicker and wipe the water away with your drying towels before they can leave any deposits.
For interior glass, the Stoner's Invisible Glass reach-and-clean tool is excellent, especially for getting in corners and for cleaning the rear glass:
[ame="https://www.youtube.com/watch?v=5KLsaasDBHY"]Stoner Invisible Glass Reach and Clean Microfiber Tool Mop Demo - YouTube[/ame]
I keep the glass towels in a plastic bag and keep them separate from all my other detailing supplies so that they don't become contaminated.
Old 03-01-2016, 03:32 PM   #14
edigeek
Drives: 2014 White BRZ Limited
Invisible glass, it does magic
edigeek is offline   Reply With Quote
Crack in the glass.. Miss_Red Scion FR-S / Toyota 86 GT86 General Forum 54 02-27-2013 01:06 PM
Glass polish? SubarooMike Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 11-08-2012 01:33 PM
What's wrong with the glass? mashal Scion FR-S / Toyota 86 GT86 General Forum 31 08-23-2012 03:05 AM
