#9941 |
Drives: 2014 GT86
Somehow most of those 1M views & 585 pages of posts seems simply due long wait, repetitious loads more then year long by many in queue, inquiries of place said queue and so on. I hardly would be proud of that and view that as being awesome, as there seem to be no signs for such sad state of things with availability to ever change. Yes, this is very interesting product, yes, it does wonders .. but for every happy owner there are probably 10 or more others that still waiting or gave up after long time of said waiting or gave up initially once found out average delivery time. I'm thinking that ESC is the future (especially if accompanied by recuperation of exhaust energy by another turbine with electric generator), hence keeping reading this thread from time to time for interest sake .. but majority of posts is just that, related to long wait in different forms.
#9942 | |
Drives: 2013 GT86
Looks like I need to be on the international list then. Whats the issue with international/RHD anyway? I mean, surely fitment is the same? |
#9943 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Length of dump cables effect the motor significantly. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#9944 |
Drives: 2013 GT86
Why would the dump cables be different? The RHD has the batteries on the opposite side but I wouldn't think the cables need to be much or any longer since the ESC sits in the middle of the engine bay?
#9945 | |
The dump motor cables are way longer on RHD. I'm not a master on RHD setups but I believe the two guys running the setup needed to increase the size of wire significantly for the runs. Sent from my iPhone using Tapatalk
#9946 | |
Drives: 93'Camry, 82'Corolla, 76' Celica
Total engine output is about the area under the curve in a dyno plot of torque and hp. The peak is a neat number, but is only part of the story. I have calculated the numbers for a conventional supercharger that produces the same or slightly higher peak engine output on the FA20. The ESC system should make about 5-10% more total power output, with the same peak. The problem with torque, on both front and rear wheel drive platforms, is hooking it up to produce acceleration numbers from a stop. I had a 1978 Mustang II, with a 302, V-8 and 4spd. manual transmission, back in the 1980's. It did 0-60 in about 8.5 seconds when I got it. I fixed the terrible engine/emmissions fixes of the time, got about 6.5 seconds. (open differential no traction control). Added dual exhaust, higher compression heads, cam, 4barrel carb. I then got about 5.5 seconds. Only ran the car in final form at the local track to get a 13.2 sec. 1/4. at 108 mph. Traction, traction, traction, especially on those older street tires, was terrible, and it wasd so hard to launch a car that just wanted to do teenager, cool burnouts all the time.
#9947 |
Drives: 2013 frs; 1988 porsche 944s - > 948
latest list from page 558
just caught up on the forum and was concerned cause my name wasn't on the list but then found out the list that was just reposted was from page 500.
This is the most recent list from fenton that i know of from page 558 and last i knew Shinobu's smile received his in the january batch which i outlined in red below which seems to be the latest confirmed shipment. Hope that helps. TOP 10: Hopefully these will go out in the next couple months: Bigbadvoodooguru MmmmHamSandwich og25491 Necric JoonPrime Silent_Dan vfrqqq joez28ls1 Sunrise161 zc06 kisstherain The Rest: Moletheus rhythmM Indy FRS predator800 Thako TwoFourFive Shinobu's Smile brilthor k.houan Lakingkhun rdub-S dpgfunk Brady68usa Deslock phrosty Caspian ShadowTS mglasgow jtree JimmyMac buckseventysix iConformed R3NIK Joshwahhhs ImBatman Andrew025 onetime4 cawith tyrantcf propulsion1 BillyStrato shellslinger R2 NAISU86 Wolfdogelite stevo585 Yoda SilverFRS Njmarkc Cop isnotmyfault blackforge Aussie Dustin2Jz LucidMomentum Trunksse Studer21 cdq85 jzimmer801 Talus1 silverbullet m111 Phantobe Saturn10 qitorr btoast soon... Ingen jflBRZ P5yk0t1c dlux Gutterboy triethyl xsnapshot Motoarge Siby_86 Windex73 Infidel86 xuimod Tectoniic BBDGriptonia swarb Huge kid_wh Cypher009 focobrz dreamwonder apaull ajcarson11 BRZ Fanboi iJeff can't stop spinning Psnguyen F3RGY68 Lrk322 mikool Lord09 FatFree mythhelios Mrrksturr svuong SuperJimmyK Fever ajcarson11 Norkoastal Aztec International: Trying to get more information for you guys. The RHD issue is a big one(from production stand point). Ill work on getting a answer from Rob on the LHD guys in Europe, as far as i can tell shipping costs will be very high though, if there were any issues that require shipping back and forth things will get very pricey. Benz s2d4 LazyZed keen as reneezak90 gtfapollo Thobjo Pistol reignerabellera killy GT86meMR2 S555plf[/QUOTE] |
#9948 |
Drives: 2013 FRS
update on list progress
I'm four down from Shinobu and I got mine a couple weeks ago. By the way, it rocks.
#9949 |
Drives: 2013 GT86
why is my name no longer on the list? Last time I asked it was:
FatFree mythhelios Mrrksturr svuong SuperJimmyK Aztec Fever Norkoastal MugenReplica RamCro chezzy79 Kpage gmanvilla1 Flow tzbang jackblack21 illmatic_frs kritch huhuei2008 soulreapersteve Johnrvd Bluehwy I should be on the RHD list anyway. Why don't the RHD kits just get shipped out without batteries? Most of us can source them locally. |
#9950 |
Drives: 2002 V7 Bugeye STI/2014 BRZ limited
Is it still possible to get on the list for this? I have PM'd both Rob and Fenton with no response.
#9951 | |
They are usually good about adding people to the list even if they don't message you.
#9952 |
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Because of a change in circumstances, I am seriously considering trading my BRZ in for a WRX. If I do, I would be looking to sell my ESC 1.5 dump pack and OFT. Just putting out feelers to see if there would be any interest in buying it, as interest/lack thereof might sway my decision on the trade.
FYI: Installed in May 2014. Has about 20,000 miles on it. Working as new when I removed it last week so I could take the car in for servicing on Friday. This is the first time I've had the ESC off since install. The car really feels flat and gutless without it.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe 2006 Saab 9-3 2.0t 1997 Honda Accord Coupe 1995 Honda Prelude VTEC |
#9953 |
it's been a slice and i wish the rest of you the best on the ESC
tax return made it too tempting after a fellow person on the list pointed out to me that after i sell my tomei uel header its pretty much the same cost to go straight to the speedbydesign stage 1 turbo.
as a result my handle can be officially removed from the list. i still can't wait to see an ESC installed near me to look at the installation in person and feel what it does for electric boost. Wish you all the best Rob on future development and many more kits. ![]() Maybe a V3 compressor wheel on a 4battery 48V system to get to 10 PSI? A man can dream.... Thanks fenton for all updates and numerous q & a.
#9954 | |
Good luck bro. Wish you the best of luck with the turbo.
| The Following User Says Thank You to Sojhinn For This Useful Post: | Gutterboy (04-09-2016) |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
