Old 02-23-2016, 02:46 AM   #1
shayangh
Drives: 2015 Brz
moving from CA have some questions about emission testing in Northern VA.
Due the passing of my father I will be moving from CA to VA to be closer to my uncle and will be driving my Frs over so I was wondering what the emissions laws are like? Is it as restricting as it is in the CA? will i able to pass emissions with a turbo?
shayangh is offline   Reply With Quote
Old 02-23-2016, 06:45 AM   #2
rns294
Drives: 13 BRZ
If you're legal in CA then you should be alright in VA from what I know. NOVA does have emissions tests required every two years.
VA can be strict on things like lights, tint, exhaust noise, etc. but so far I haven't experienced that in NOVA as much as I did in middle of nowhere southwest VA.
Some other people may be able to provide more input. I have been afraid to change my tails and header so what do I know
rns294 is offline   Reply With Quote
The Following User Says Thank You to rns294 For This Useful Post:
shayangh (02-23-2016)
Old 02-23-2016, 10:44 AM   #3
shayangh
Drives: 2015 Brz
I havent put the turbo on but I'm pretty sure from what I heard it won't pass in CA
Old 02-23-2016, 10:46 AM   #4
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
If it doesn't throw a CEL, it'll depend on your inspection station. Some places are more strict about their visual inspections.
If it throws a CEL, you will fail.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Old 02-23-2016, 12:11 PM   #5
shayangh
Drives: 2015 Brz
Thank you very much
Old 02-23-2016, 01:48 PM   #6
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Now you can also pass emission inspection in Nova without going to a station. They put up emission measuring equipment on the roads, you just drive by within some time before your registration is due to expire, then you go online, pay the $16, and you good. Disclaimer - I haven't used it yet, so I don't actually know if it works as advertised
mdm is offline   Reply With Quote
Old 02-23-2016, 01:48 PM   #7
jawn
jawn's Avatar
Indeed. I've been meaning to try it.
Old 02-23-2016, 09:14 PM   #8
rns294
Drives: 13 BRZ
Is that what those stations on the side of the exit ramp are?!?! I had no idea. I thought they sent you tickets in the mail if you drove by and failed...
Old 02-23-2016, 09:18 PM   #9
jawn
jawn's Avatar
There's actually two systems. There's an older one that would send fix-it tickets, and there's the new one that'll send you notices if you pass emissions.
Old 02-23-2016, 10:02 PM   #10
mdm
not a twin owner
mdm's Avatar
Here are the details of the system I was referring to
https://www.rapidpass.org/VaPublic/
Old 02-24-2016, 08:04 AM   #11
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Depending on where you live also plays a role. County i live in does not have emissions so fully catless!
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
Old 02-24-2016, 11:15 AM   #12
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
So, would is standard procedure for emissions? Do they do a visual check first or go straight to sniff/smog test? Im wondering since I have a OFH which is catless and Im due for an inspection in the summmer. Would I have to take off the OFH and install the stock one and then re-install?
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 02-24-2016, 11:41 AM   #13
mdm
not a twin owner
mdm's Avatar
He mentioned "Northern Virginia", and by one definition of NoVa the entire area requires emission testing (counties: Arlington, Fairfax, Loudoun, Prince William, Stafford; cities: Alexandria, Fairfax, Falls Church, Manassas, Manassas Park).
Wider definitions of NoVa include additional counties further from DC like Spotsylvania, Warren, Culpeper and more, and these AFAIK do not require emission testing.
I think that in modern cars they just scan OBD for codes. The new on-road emission program (which measures actual tailpipe emissions while you drive by) is an optional alternative. Inspection stations would measure actual tailpipe emissions only in old cars.
More here: http://www.deq.state.va.us/Programs/...SystemFAQ.aspx
and here: http://www.dmv.org/va-virginia/smog-check.php
Also, I was wrong about $16, I think it's $28, $16 is for safety inspection which is yearly and mandatory in all VA.
The Following User Says Thank You to mdm For This Useful Post:
ap5512 (02-24-2016)
emission testing CARBONGT86 CANADA 10 10-26-2015 04:27 PM
EURO STANDARDS emission testing with catless header tato.valverde Engine, Exhaust, Transmission 2 05-22-2015 01:35 PM
Moving to Northern Ontario, Only 91 Octane available GloriousJ Scion FR-S / Toyota 86 GT86 General Forum 22 05-14-2013 10:28 AM
emission standards? rainmonkey Northern California 10 04-23-2013 08:50 PM
Emission and noise restriction in DMV guy Mid-Atlantic 6 11-14-2012 01:30 PM
