#1961 | |
Drives: 4 wheels
#1962 |
STX 188
No one with a FRS/BRZ ran 18" at Nationals.
#1964 |
Drives: 2014 FR-S
I would be remiss to not give Justin kudos as well. You guys both did great.
| The Following User Says Thank You to Silverspeed For This Useful Post: | tigermack (02-15-2016) |
#1965 |
APEXHNTR
Drives: 10 Series FR-S #1867
Any general consensus on brake pads? I daily drive my car but also run 70-80 AutoX runs a year and maybe a track day or two...want kind of a jack of all trades brake pad?
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#1966 | |
Drives: '22 BRZ
I'm going to use OEM pads for autocross (maybe try Stoptech's street pads or Carbotech 1521s when I wear out OEM) and I'll be stepping up to Carbotech XP12s for track use. |
| The Following User Says Thank You to DocWalt For This Useful Post: | strat61caster (02-22-2016) |
#1967 | |
Drives: '13 FRS - STX
If you're easy on track a hybrid pad might be able to do it all, but if you're confidently threshold braking or using the ABS consistently you'll probably fade them within a session. I have XP10's for the track and I can't keep them bedded in for the street unless I can get them up to temp once a week, which I don't feel comfortable doing on public roads. They were great for AutoX but too loud for me to run them daily. Currently I cheaped out and got PMu NS400's (~$60 cheaper than HC800+) for DD/autoX usage, not sure if they'll hold up to the local big course which should have at least one hard third gear to second gear braking zone per run, which case I'll probably upgrade to the HC800+ or DS2500 for DD/AutoX. Maybe Winmax if a couple ringing endorsements pop up around here for a particular compound. |
#1968 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
HC+800 is cheaper than almost every comparable compound too. |
| The Following User Says Thank You to finch1750 For This Useful Post: | strat61caster (02-22-2016) |
#1969 |
STX 188
Before I upgraded to the Stoptech BBK, I thought the OEM was plenty good for autocross. I didn't have issues with them.
| The Following User Says Thank You to tigermack For This Useful Post: | strat61caster (02-22-2016) |
#1970 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Sent from my A0001 using Tapatalk |
#1971 |
APEXHNTR
So seems like the HC800+ is the pad.
As for my need for a "track day" pad, I think it will be fine. Last track day I ran all day on OEM brakes and noticed some fade and vibration towards the end but they held up surprisingly well. NJMP Thunderbolt is fairly easy on brakes from what I've experienced too...
| The Following User Says Thank You to Silver Ignition For This Useful Post: | strat61caster (02-23-2016) |
#1972 |
Drives: 2013 Satin White Pearl BRZ
Quick question. What classes are for the 86... I know. Cs, STX, I don't know whats next.
Thanks. Sent from my SAMSUNG-SM-G900A using Tapatalk |
#1973 |
Drives: Many
CSP, SM.
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
