Old 02-15-2016, 08:02 PM   #1961
justint5387
Drives: 4 wheels
Originally Posted by Silverspeed View Post
I have always wanted to test a 255/35-18 as I think this could be a great set up especially for nations type courses. Narrow sidewall, wider tread and larger diameter. Based on what I saw at Nats last year I think the 2nd place finisher used that set up. The cost is prohibitive though, and added weight. Tough to find a lightweight set of 18x9 wheels for less than a kidney.
He was on 245/40/17
justint5387 is offline   Reply With Quote
Old 02-15-2016, 08:20 PM   #1962
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
No one with a FRS/BRZ ran 18" at Nationals.
tigermack is offline   Reply With Quote
Old 02-15-2016, 08:27 PM   #1963
Silverspeed
Drives: 2014 FR-S
I stand corrected. Phenomenal run at Nats. Especially on the east course. Congrats on 2nd place.
Silverspeed is offline   Reply With Quote
The Following User Says Thank You to Silverspeed For This Useful Post:
tigermack (02-15-2016)
Old 02-15-2016, 08:49 PM   #1964
Silverspeed
Drives: 2014 FR-S
I would be remiss to not give Justin kudos as well. You guys both did great.
Old 02-22-2016, 04:03 PM   #1965
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Any general consensus on brake pads? I daily drive my car but also run 70-80 AutoX runs a year and maybe a track day or two...want kind of a jack of all trades brake pad?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 02-22-2016, 04:31 PM   #1966
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
That alone kills the "jack of all trades" nature of a pad. I can daily my XP10s easily (they have great bite even dead cold in single digit temps) but they get noisy once the bedded in pad wears off and they always dust like crazy. You won't get away from the noise and dust with any pad that's actually suitable for hard track use. If you're just puttering around you could run something like Ferodo DS2500s or something, but why even go to the track then?
I'm going to use OEM pads for autocross (maybe try Stoptech's street pads or Carbotech 1521s when I wear out OEM) and I'll be stepping up to Carbotech XP12s for track use.
The Following User Says Thank You to DocWalt For This Useful Post:
strat61caster (02-22-2016)
Old 02-22-2016, 05:54 PM   #1967
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I asked in the CS thread a few months back, I came to the conclusion it's probably best to have a dedicated set of track pads and then hybrid pads for street/autox. Shortlist is Ferodo DS2500, Carbotech AX6, and Project Mu HC800+ for the more aggressive street compounds, Winmax probably has a competitive pad but I'm not sure if it'd be W2/3/4. And I've heard such mixed reviews on Hawks that I'm staying away, although some people love 'em and they are usually a bit cheaper (plus grassroots support with contingency programs and series sponsorships)
If you're easy on track a hybrid pad might be able to do it all, but if you're confidently threshold braking or using the ABS consistently you'll probably fade them within a session.
I have XP10's for the track and I can't keep them bedded in for the street unless I can get them up to temp once a week, which I don't feel comfortable doing on public roads. They were great for AutoX but too loud for me to run them daily. Currently I cheaped out and got PMu NS400's (~$60 cheaper than HC800+) for DD/autoX usage, not sure if they'll hold up to the local big course which should have at least one hard third gear to second gear braking zone per run, which case I'll probably upgrade to the HC800+ or DS2500 for DD/AutoX. Maybe Winmax if a couple ringing endorsements pop up around here for a particular compound.
ineedyourdiddly
Old 02-22-2016, 06:07 PM   #1968
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I love the HC+800. Great for DD even when its cold on my way to work. I have also driven on Carbotec XP8 and Winmax W3. Both were OK but not as good in the morning and not enough initial bite for my liking. I'd probably like the W4 or W5 but doubt I could keep the bedded/not feel sketchy in the morning plus they cost a fair amount more.
HC+800 is cheaper than almost every comparable compound too.
Old 02-22-2016, 07:44 PM   #1969
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Before I upgraded to the Stoptech BBK, I thought the OEM was plenty good for autocross. I didn't have issues with them.
The Following User Says Thank You to tigermack For This Useful Post:
Old 02-23-2016, 06:53 AM   #1970
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Echoing all the recent posts. Running HC800 and RBF660 last season and on the courses up here no issues have arisen. HC800 on the track, however, do fade in the 2nd hot lap for me. Perhaps not enough to warrant dedicated track pads? We'll find out this season
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 02-23-2016, 08:52 AM   #1971
Silver Ignition
APEXHNTR
So seems like the HC800+ is the pad.
As for my need for a "track day" pad, I think it will be fine. Last track day I ran all day on OEM brakes and noticed some fade and vibration towards the end but they held up surprisingly well. NJMP Thunderbolt is fairly easy on brakes from what I've experienced too...
#1867 of 2500
The Following User Says Thank You to Silver Ignition For This Useful Post:
strat61caster (02-23-2016)
Old 02-23-2016, 01:01 PM   #1972
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Quick question. What classes are for the 86... I know. Cs, STX, I don't know whats next.
Thanks.
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 02-23-2016, 01:12 PM   #1973
e1_griego
e1_griego's Avatar
Drives: Many
CSP, SM.
e1_griego is offline   Reply With Quote
Old 02-23-2016, 01:40 PM   #1974
jbailey8748
Ty
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
