Old 02-20-2016, 06:36 PM   #141
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
Originally Posted by power_of_ra View Post
Hey everyone,
total newb here trying to quiet my cold start rev a bit so i took my stage 2 UEL 91 tune and changed the post ignition timing start values to -6.99 from -15. saved it as a new .bin and compared - looked all good.
when i tried to upload to my OFT, i get this error [see attached image].
B00C cal ID using B00C .bin and .xml from OTS 2.074. What am i doing wrong?
when you saved the file did you put .bin at the end? it will not do it for you.
oldgunfan is offline   Reply With Quote
Old 02-20-2016, 06:41 PM   #142
power_of_ra
power_of_ra's Avatar
Drives: 2014 BRZ Limited CBS
yep. as a test im trying to see if it'll add tunes from previous OTS releases and thats not working either.
power_of_ra is offline   Reply With Quote
Old 02-20-2016, 06:45 PM   #143
oldgunfan
oldgunfan's Avatar
I would uninstall open flash manager and reinstall see if that works.
Old 02-20-2016, 06:49 PM   #144
oldgunfan
oldgunfan's Avatar
When my OFM 1.24 updated today my antivirus gave me crap and tried to delete OFM.
Old 02-20-2016, 07:00 PM   #145
power_of_ra
that seems to have done it! yea i updated mine today.. maybe that messed up the installation somehow. thanks for your help! if this works, i'll probably try some slight knock correction next since i'm using cheap/crappy 91 fuel
Old 02-20-2016, 07:04 PM   #146
oldgunfan
oldgunfan's Avatar
cool
The Following User Says Thank You to oldgunfan For This Useful Post:
power_of_ra (02-20-2016)
Old 02-29-2016, 10:09 PM   #147
akyp
Drives: 2012 86
Load limit for P&L 4-1 EL catted (WIP):
Before:
http://datazap.me/u/akyp/20160221-st...zoom=1626-1779
After:
http://datazap.me/u/akyp/20160229-st...zoom=6120-6267
The first thing I wanted to address is the lean spikes which contributed to tip-in knock. With more time I can make the AFR plot flatter, but I'm leaving it for now as it took me enough time to reach this point (car is not DD). Currently using "v97.US.Lean Stg2" MAF scale from the spreadsheet linked in OP but I took the liberty to modify the value at 3.2v from 64.60 to 68.00 as it looked out of place.
Thanks @Wayno for this excellent guide. The load limit is just the beginning. It is my eventual goal to dial in AVCS maps (with vgi's tool) for this particular header.
akyp is offline   Reply With Quote
Old 03-01-2016, 12:24 AM   #148
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Yeah 68 is the value to use if you want to flatten out that area, though it doesn't make it look much less weird compared to the rich scale. I just use 1.0 below 2400 now because the ace header doesn't need workarounds like that. Good that you used the guide as intended to work out your own values you need.
The Following User Says Thank You to Wayno For This Useful Post:
akyp (03-01-2016)
Old 03-05-2016, 07:48 PM   #149
JB86'd
JB86'd's Avatar
Drives: JAWS
Just wanted to post a little BEFORE and AFTER here of my OFT Stage 2 tune with JDL UEL header, results from using this guide by Wayno.
My current Load Limits, and MAF scale (compared to the standard OFT maf scaling):
Before- OFT stage 2 tune, 91 oct with no modifications.
http://datazap.me/u/joshbustos86/jdl...zoom=1592-1718
After- OFT stage 2 tune, 91 oct with custom OL maf scaling/ Load Limits and modified DI/PI tables based on Wayno's modifications.
http://datazap.me/u/joshbustos86/jdl...4&zoom=609-733
JB86'd is offline   Reply With Quote
Old 03-05-2016, 08:55 PM   #150
Wayno
Wayno's Avatar
I run the original port injection ratios above 5k now, just in case Toyota has them there to keep the intake valves clean. I haven't seen any proof that running 100% direct from 5k to 7k is safe long term and I haven't seen any evidence that it produces more power, only that you can run about 2 degrees more advance with 100% DI, which may not necessarily mean more power if some PI thrown in produces a better mixture.
Old 03-05-2016, 09:31 PM   #151
JB86'd
JB86'd's Avatar
Drives: JAWS
Okay, if I go to the original DI/PI ratios is that simply going to change my LTFT there? Shouldn't affect the MAF or AFR right?
Old 03-06-2016, 04:14 AM   #152
freerunner
freerunner's Avatar
Drives: GT86
Shouldn't affect it, but if it still does, it's easy to fix with altering the global scalar.
I'm on vacation right now and don't remember the name of the table.
Refer to the pi:di thread for further information and how to do it.
Steve99 has it pretty much nailed down in this thread.
freerunner is offline   Reply With Quote
The Following User Says Thank You to freerunner For This Useful Post:
JB86'd (03-06-2016)
Old 03-06-2016, 06:21 PM   #153
Wayno
Wayno's Avatar
Yes just copy the tables from stock or ots petrol roms. Ltft will change but afr won't.
JB86'd (03-06-2016)
Old 03-06-2016, 09:23 PM   #154
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
^ It would be a good idea for those of you messing with the load limits to log the cam timing as well to better determine whether the lean spots are caused by scavenging effect. The valvetrain noise caused by aggressive overlap may also contribute to knock, or rather "knock". (in quotations because this may not be real knock)
Before:
After:
Intent > Content
The Following 2 Users Say Thank You to solidONE For This Useful Post:
akyp (03-07-2016), Hyperblue302 (05-03-2016)
Maximum weight in the trunk? djmm Scion FR-S / Toyota 86 GT86 General Forum 20 08-13-2015 12:40 PM
“Maximum Attack” Scion FR-S stugray Scion FR-S / Toyota 86 GT86 General Forum 13 02-01-2015 09:45 PM
PA: Rays Gram Light 57 Maximum 5x100, 17x8, +43 (Price Reduced!) Needs more cowbell Wheels and Tires 20 02-22-2013 11:03 AM
MAXIMUM you would pay for a TRD Supercharger installed? FRiSson Forced Induction 24 11-04-2012 01:08 AM
MR-S Effect... Dimman CANADA 11 09-06-2011 12:49 PM
