go_a_way1, MisterSheep
Old 02-20-2016, 11:32 AM   #13049
Brayden_23
Drives: Asphalt 2015 FRS
Originally Posted by zeal86 View Post
If it bothers you any, this is what I did to conceal the bracket that supports the 3rd brake light.
Thanks! I actually went a different route though; I stuck that support under the headliner and just notched the headliner so it would lay smooth.
Brayden_23 is offline   Reply With Quote
Old 02-20-2016, 11:53 AM   #13050
zkahle
zkahle's Avatar
Drives: 2013 Scion FRS Asphalt
After weeks of staring at my headers I finally had a chance to install the TOMEI UEL's. They sound great paired with my Berk axel back. It may be a bit too loud but YOLO...
Hook Em'
zkahle is offline   Reply With Quote
Old 02-20-2016, 11:58 AM   #13051
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
Got tired of running badge-less so opted for JDM flavor.
Grimmspeed hood struts, because hood struts.
No more missing trunk carpet.
And these bolt cover thingys. I'm told they're good for 5HP each? I'm on my way to 222HP NA!
Kestrel is offline   Reply With Quote
The Following 3 Users Say Thank You to Kestrel For This Useful Post:
Mr.Impreza (02-20-2016), stevesnj (02-20-2016), wulfstan (02-21-2016)
Old 02-20-2016, 12:01 PM   #13052
Lorico
Drives: 2015 FRS
Originally Posted by johan View Post
Wrapped one of my A-pillars in Alcantara from Overland Designs. I don't usually do well with arts/crafts projects, but with some great advice from @Figo (thanks!) and a slow / steady approach - it turned out perfect. Super stoked.
how did you glue it on? spray or brush?
Lorico is offline   Reply With Quote
Old 02-20-2016, 07:17 PM   #13053
stevesnj
stevesnj's Avatar
Finally installed my steering wheel. Need to clean up the transition points. I may just take it to an upholstery shop to make it look good...
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
bumppinKota (02-20-2016), sdwagonjp (02-20-2016)
Old 02-20-2016, 07:35 PM   #13054
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
The Following User Says Thank You to ZOMFGAARON For This Useful Post:
SmartedPanda (02-22-2016)
Old 02-20-2016, 08:00 PM   #13055
S84kam
S84kam's Avatar
Drives: FBRZS
You should really buy an aftermarket steering wheel if your going to keep throwing money at this project.
Here's an idea. Buy a fisher price steering wheel and practice on that!
S84kam is offline   Reply With Quote
The Following User Says Thank You to S84kam For This Useful Post:
Old 02-20-2016, 08:50 PM   #13056
stevesnj
stevesnj's Avatar
I have no idea what you mean?
Old 02-20-2016, 09:02 PM   #13057
Lorico
Drives: 2015 FRS
I think he means it looks horrible.
C'mon we're giving you negative feedback only because we think you can do better. I'm sure if you tried again it would look better.
Old 02-20-2016, 09:08 PM   #13058
stevesnj
stevesnj's Avatar
I respect your opinion, and I agree it's not professional and was done in my kitchen. Please guide me on how to make a carbon fiber flat bottom wheel. I am a novice and this is my first CF job.
Old 02-20-2016, 09:32 PM   #13059
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
It's a better job than I would have done. I would have looked at the project half way and then freaked out, contemplated buying an aftermarket, and then tossed the half baked project. lol
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 02-20-2016, 10:09 PM   #13060
bumppinKota
Drives: FRS!!!
I like it. I wouldn't do it just because I like the factory wheel the way it is but I like that you did it and it came out well.
bumppinKota is offline   Reply With Quote
The Following User Says Thank You to bumppinKota For This Useful Post:
Old 02-21-2016, 12:45 AM   #13061
johan
Drives: '14 981CS, '99 NB1
I used this: http://www.homedepot.com/p/DAP-Weldw...0107/100195615
Has brush built in. Worked -reallllly- well and very easy to apply. Hardest part is just making sure you get everything aligned right before committing to placement. I found a small plastic object in my house to practice on first to get the hang of it.
johan is offline   Reply With Quote
Old 02-21-2016, 12:48 AM   #13062
Baymax86
Baymax86's Avatar
Drives: Whiteout Monogram
Wrapped the lower part of the front bumper. Also tow hook plug for fun with some leftovers. Up close you could tell my brother and I are no professionals so best to admire from afar.
Sent from my Nexus 5X using Tapatalk
Shameless Instagram plug : @BaymaxGT86
Baymax86 is offline   Reply With Quote
