Old 02-19-2016, 06:42 PM   #1
Patsully3
Drives: 2014 scin frs
Code p0420
I went to the gas station today and filled up and after I did the check engine light came on I checked the fuel cap it was tight I went to auto zone they wernt much help only gave me the error code anyone have ideas? I replaced the headers and exhaust stock front pipe and over pipe
Patsully3 is offline   Reply With Quote
Old 02-19-2016, 06:48 PM   #2
stevesnj
stevesnj's Avatar
Thats a bad downstream O2 sensor, the one after the cat. It's catalyst inefficiency code if I remember correctly. Someone will chime in for correct diagnoses on that code.
My 2016 Build thread
Old 02-19-2016, 07:06 PM   #3
Patsully3
Thank you where is that o2 located so I can change it out?
Old 02-19-2016, 07:31 PM   #4
JB86'd
JB86'd's Avatar
Drives: JAWS
you replaced the headers as in...you have aftermarket headers?
JB86'd is offline   Reply With Quote
Old 02-19-2016, 08:39 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You got catless headers and didn't know this code would appear? I think you should've done more research, you need to get a tune to get rid of the P0420 code or do a spacer trick....
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
JB86'd (02-19-2016)
Old 02-19-2016, 08:40 PM   #6
FRSBRZGT86FAN
He has catless headers, and he didn't do any research into what happens when you install them...
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
JB86'd (02-19-2016), stevesnj (02-19-2016)
Old 02-19-2016, 09:05 PM   #7
Patsully3
Yea I got grupee headers form someone on here and a invidia n1 exhaust
Old 02-19-2016, 09:06 PM   #8
Patsully3
Where in Chicago would I get a tune?
Old 02-19-2016, 09:06 PM   #9
Patsully3
I've also had them both installed for a lil over a month now and didn't see this issue til now
Old 02-19-2016, 09:13 PM   #10
FRSBRZGT86FAN
You have to buy something like OFT and get a off the shelf stage 2 tune, you shouldn't have installed them without knowing the ramifications
in retrospect the Gruppe-s are the best headers on the market for the price.
Also time of when it was installed doesn't matter it's going to come on more and more frequently now, also you'll fail emissions with them without a tune, not only that you're not gaining all the power you can from them without a tune.
Old 02-19-2016, 10:13 PM   #11
Patsully3
Yea I'm a noob to this but I'm Keaton and trying but I appreciate the I put and help by any chance know where I can get what I need to make everything alright and work efficiently?
Old 02-19-2016, 10:41 PM   #12
FRSBRZGT86FAN
Yup no problem:
http://www.openflashtablet.com/shop/oft-frs-brz-gt86/
It should generate the tune files when you plug it in, mine did but I deleted them so I could edit my tunes personally, but yours should be fine, its $499 and tunes are free
Old 02-19-2016, 10:50 PM   #13
Patsully3
So it comes with all the tunes? It's pretty much plug and play?
Yup no problem:
Old 02-19-2016, 10:52 PM   #14
Patsully3
Is there any other way I mean I'll pay the money if I have to but I'd thought I'd ask and c if there was a cheaper way
QUOTE=FRSBRZGT86FAN;2554642]Yup no problem:
It should generate the tune files when you plug it in, mine did but I deleted them so I could edit my tunes personally, but yours should be fine, its $499 and tunes are free[/QUOTE]
Another CEL code whitefrs Forced Induction 20 11-27-2019 11:27 AM
OFT Disable P0420 Cat Efficiencty livingambition Software Tuning 2 06-18-2015 09:18 PM
P0420, stock exhaust with muffler delete Kwaziekeller Issues | Warranty | Recalls / TSB 3 06-26-2014 02:59 AM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 01:27 AM
p0420 brichard0625 Issues | Warranty | Recalls / TSB 11 08-04-2013 09:24 PM
