SupaSter
Drives: 13' BRZ
So I bought a set of fortunes off another guy, and they came in the 6k/7k setup which feels too soft for me. A little back story, I previously had FA500s before I went air about 2 years ago, with 8k/7k spring rate and loved it. The current 6k/7k set is almost on full max dampening and I feel that the car feels too floaty still. I'm dropped about 1.5"-2" now. Anyway, would I be able to upgrade to swift springs in 8k/8k without any problems, or would I need it re-valved?
#2 |
You best bet is to contact them directly. Try them softer and see how it works out. If you add spring rate, floaty feeling will turn into bouncy. Make sure they aren't blown and the preload is set correctly.
#3 |
Amateur Drifter
Drives: '13 FRS
You shouldnt have to get them revalved.
#4 | |
Drives: Evo
![]() Regards, Jenson Fortune Auto |
#5 |
SupaSter
Drives: 13' BRZ
Thanks, since youre a rep. of Fortune, can you please tell me which diameter of Swift springs I would need in order to swap?
#6 |
Drives: Evo
#7 |
SupaSter
Drives: 13' BRZ
Thank you! Also, would it be recommended to keep the same length spring as the ones already on the suspension? Thanks in advance
#8 |
Drives: Evo
| KW V3 Coilovers feel stiffer over time? | mkivalex | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 03-20-2015 08:28 AM |
| Spring Rates Discussion: Stiffer Front or Stiffer Rear or Even/Square all around??? | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 02-20-2014 03:50 AM |
| Fr-s on Fortune Auto 500s | Propaganda | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 02-10-2014 07:33 PM |
| stock height stiffer springs? | vgi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 10-06-2013 11:08 PM |
| Fortune Auto V4 500s W/ Roller bearings | FR-S86 | Brakes, Suspension, Chassis | 21 | 02-12-2013 03:30 PM |
