Old 02-16-2016, 10:51 PM   #379
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by Atticus808 View Post
sooooooo when you guys got headers did you get them ceramic coated to reduce heat?
I don't have a header on my BRZ, but I had my header and downpipe coated by Swain on my Jeep. Pricey, but I think it was worth it. Swain's coating is about twice as thick as Jet Hot.
I did it more for the effect of the heat on the speed of the exhaust than for heat control under the hood. When the BRZ is out of warranty I intend to buy a header, and I'll probably send it to Swain as well.
Originally Posted by FRSBRZGT86FAN View Post
You can do that, or you can wrap them.
I don't know how the headers for the twins hold up, but there are a lot of stories on the Jeep boards of people ruining I6 and V8 headers by wrapping them. Because the wraps are not perfect, they have pockets where moisture can condense and rust the shit out of everything (yes, even on stainless). They are also not as consistent as the ceramic coatings, so that the heat isn't retained evenly. Wrapping a 4.0L I6 header pretty much guarantees cracks at the collector. I would expect the same kind of problems on the twins.
I personally wouldn't waste my time with a wrap, when the ceramic coating is going to outperform, outlast and outprotect.
extrashaky is offline
The Following User Says Thank You to extrashaky For This Useful Post:
FRSBRZGT86FAN (02-16-2016)
Old 02-16-2016, 11:00 PM   #380
Mike Brz
Originally Posted by D_Thissen View Post
On the Dyno you're using, what kind of numbers does a stock 86 lay down ?
Sent from my Nexus 6P using Tapatalk
I believe around 165whp. Also back in late 2013 or early 2014 i was tuned there on 93 and made around 186whp with cheap header ,stock op, 2.75 catback, and injen intake
Mike Brz is offline
Old 02-16-2016, 11:02 PM   #381
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Apoc View Post
The simulated vehicle weight setting on the dyno is 4250? That's definately the weight record for a twin.
I know it's got issues but I gave him two possible choices the cheap way and the expensive way
If you wrap it properly with stainless steel ties and such it should be fine, I'm more worried about something getting on them and starting a fire.
FRSBRZGT86FAN is offline
Old 02-16-2016, 11:03 PM   #382
Mike Brz
All that painters tape and plasti dip must weigh it down?
The pics you are referring to is pics of the box when it was being built. The tape was there to hold it in place while the fiberglass mounting tabs dryed. The box was bolted in after lol. There is no plasti dip on the car. Its all vinyl wrap
Mike Brz is offline
Old 02-16-2016, 11:07 PM   #383
Mike Brz
Originally Posted by [YOYO] View Post
No .... but SERIOUSLY! What is wrong with you!?!?! Who does that to a car?!? It's like Pep Boys, but gone wrong (if that's even a thing).
No pepboys parts on this car haha.almost everything was custom made. And i dont see how its "gone wrong" if it runs a 13.75 and makes 221whp.
Mike Brz is offline
Old 02-16-2016, 11:08 PM   #384
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
lol it was a great pic! Mhe vinyl wraps and plasti dips all fall under the same category if you ask me, but legit question why was the car 4250 pounds or whatever for the dyno run data?
go_a_way1 is offline
MrFisty (02-16-2016)
Old 02-16-2016, 11:15 PM   #385
Mike Brz
So he delivered:
See how much better the quality is?
Also the dyno chart glimpse at the end:
I say he's telling the truth, however it is definitely not the bolt on record it's impossible to prove that.
You are kind of right, its hard to compare since all dynos read a bit different. I plan on eventually putting it on a dyno jet to get a more accurate number, but it is not such a major concern. But this does prove that i am the one of the highest whp na brz/frs out there if not the highest. Im setting my sites on the 1/4 mile record now because id rather be a quarter mile king than a dyno queen. Only .43 sec i need to shave off to beat it
Mike Brz is offline
Old 02-16-2016, 11:17 PM   #386
Mike Brz
No idea. I just took the vid i dont work there
Mike Brz is offline
Old 02-16-2016, 11:18 PM   #387
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Not to mention our headers are protected by a shield, and probably won't see as much water as an off-road vehicle. Either way, coat them or wrap them...they hug the oil pan and you don't want that excess heat in your oil.
killboy is offline
Old 02-16-2016, 11:20 PM   #388
Mike Brz
Watch "naturally aspirated brz 13.750 1/4 mile run" on YouTube
naturally aspirated brz 13.750 1/4 mile run: [ame]http://youtu.be/AxBH_i2bws4[/ame]
Mike Brz is offline
Old 02-16-2016, 11:33 PM   #389
FRSBRZGT86FAN
See how easy it was? I helped you prove your point.
But could please stop putting up recordings of videos? Like seriously, you have it playing on VLC, so obviously you've got a rear cam setup recording and saving in some sort of loss less video format why not just upload that to youtube, instead of uploading a video of a video.
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
brandonblt2 (02-17-2016), killboy (02-16-2016)
Old 02-16-2016, 11:35 PM   #390
FRSBRZGT86FAN
Gruppe-s is selling a heatshield for the oil pan if you're interestd but yea wrap or coat, also we have a splash shield that cuts down on a lot.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Old 02-16-2016, 11:37 PM   #391
Mike Brz
Lol yea its shitty. But i cant upload that format. Id need to get a video converter
Mike Brz is offline
Old 02-16-2016, 11:39 PM   #392
Mike Brz
So who thinks i can take the 1/4mile record? Place your bets.... only .43 sec to shave off
Mike Brz is offline
#a proven bolt on 221whp, #crackhead, #yolomcswaggins, brz series.poo, fake it till u make it, faster than your brz, gold, home depot mods, imaginarypower, memes are gone, my intake makes boooooost, putuporshutup
P&L Motorsports BRZ / FR-S 4:1 Equal Length Header - Naturally Aspirated P&L Motorsports Engine, Exhaust, Bolt-Ons 244 09-24-2015 04:44 PM
Naturally Aspirated - Backpressure phenom86 Engine, Exhaust, Transmission 16 03-19-2014 12:07 AM
Naturally aspirated and 87 octane... zooki Engine, Exhaust, Transmission 46 09-11-2013 11:25 AM
Who is happy the engine will be Naturally Aspirated? Ryephile Engine, Exhaust, Transmission 491 05-02-2012 10:10 PM
