Old 02-16-2016, 05:39 PM   #309
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by FRSBRZGT86FAN View Post
No it's ruined My original intent was to have this thread than mod accordingly back in 2013 but things changed. Instead it got hijacked with memes and useless info and one guy with an ego posting erroneous claims.
But here's what you do:
1)Intake- drop in will net the most power because the stock intake isn't a restriction
2)Headers- a proper uel, el or the super crazy ace header(this one has been proven to nearly touch 200 whp with a tune) will smooth out the torque dip and give nearly a 20 hp bump with a tune
3) Tune- custom ecutek tune or ots OFT tune will make a really big difference otherwise the mods just lag behind and don't make any power.
4) Possible pulleys- this is debatable as to whether or not there is a noticeable difference in power
Also you can go "faster" without more power, final drive gear upgrade to 4.56-4.67 if your manual will increase acceleration quite heavily when combined with a cf or aluminum drive shaft. For an auto in my case a 4.88 final drive set is more logical.
Honestly dont bother with pulleys, I am sure you have read all about the harmonics and the crank shaft and how light pulleys that are not damped all dont play well together. Do the FD though, I will going that route one of these days. I also do not think light drive shafts have any place on a street car as the gains are minimal at best and they are not safe (well the carbon fiber one is safe when it goes)
go_a_way1 is offline
Old 02-16-2016, 05:40 PM   #310
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
The cf or al driveshaft will not make the car noticeably faster than removing the same weight from elsewhere on the car. Taking the spare tire out between drag runs will make a bigger difference. It WILL feel different due to increased NVH.
justatroll is offline
The Following 2 Users Say Thank You to justatroll For This Useful Post:
FRSBRZGT86FAN (02-16-2016), go_a_way1 (02-16-2016)
Old 02-16-2016, 05:41 PM   #311
raven1231
221 or was it 223? Anyway that guy has the world record. Has a custom made one off intake as well. Dudes a LEGEND!
raven1231 is offline
The Following 2 Users Say Thank You to raven1231 For This Useful Post:
Cole (02-16-2016), go_a_way1 (02-16-2016)
Old 02-16-2016, 05:42 PM   #312
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
221WHP
raven1231 (02-16-2016)
Old 02-16-2016, 05:44 PM   #313
Cole
Not a troll
Cole's Avatar
I'm with you on everything except the drop in. It's been shown that some intakes (such as the GS intake) do outperform drop in filters. The issue is price vs performance.
I spent 50 bucks on a filter, instead of 400+ on an intake and gained (maybe, who knows. I haven't dyno'd) 5ish HP vs the 10hp I'd gain by getting the GS intake. 50% of the performance for 1/8th of the price.
Really though, this is all semantics. It's been shown that there are no solid NA offerings compared to FI. If I wanted to make substantial power, I'd go with the SBD base turbo kit and call it a day.
Cole is offline
The Following User Says Thank You to Cole For This Useful Post:
MisterSheep (02-16-2016)
Old 02-16-2016, 05:45 PM   #314
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I'm not sure I would totally do the accessory pulley for the alternator and water pumps however, crank one is debatable, also there is a notorious pin that comes out and pulls the crank seal out, I don't want to deal with that.
My logic with the driveshaft upgrade and flywheel upgrade (if he/she has a manual transmission) is just lowering parsitic loss if you have the money and the time to deal with a proper professional install.
FRSBRZGT86FAN is offline
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Old 02-16-2016, 05:48 PM   #315
FRSBRZGT86FAN
STAYING NA!!!
Old 02-16-2016, 05:49 PM   #316
FRSBRZGT86FAN
I had my spare removed for quite some time and it was noticeably quicker this makes more sense, but my logic is cutting parasitic loss with more mods would be a good idea.
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
justatroll (02-16-2016), MisterSheep (02-16-2016)
Old 02-16-2016, 05:51 PM   #317
raven1231
STAYING NA!!!
LS swap?
The Following 3 Users Say Thank You to raven1231 For This Useful Post:
FRSBRZGT86FAN (02-16-2016), go_a_way1 (02-16-2016), MisterSheep (02-16-2016)
Old 02-16-2016, 05:54 PM   #318
raven1231
221WHP
Thanks man! It's been awhile, I just remember his reputation around the streets.
Also you can go "faster" without more power, final drive gear upgrade to 4.56-4.67 if your manual will increase acceleration quite heavily when combined with a cf or aluminum drive shaft (has been proven to me to not be the best route by people), also cutting out extraneous weight, rear seats and seatbelts, spare tire and tools etc. For an auto in my case a 4.88 final drive set is more logical.
If you have some serious coin he might make one of his intakes for you. I know he has talked about producing them, and becoming a vendor but is hesitant to give away in secret. Doesn't want others to take his reign as champ away.
Old 02-16-2016, 05:55 PM   #319
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Old 02-16-2016, 05:56 PM   #320
GhostRai
Rice Monkey
GhostRai's Avatar
Drives: 2017 Subaru BRZ Sport-Tech WRB
Originally Posted by Tectoniic View Post
Custom 87 octane tune, that's where the real power "lies"
No that's wrong!!! The REAL power lies with mixing 100 octane racing fuel and Mountain Dew! See I know the science behind this so I can back up the claim. You may have heard that you can make Mountain Dew glow in the dark right? Well what else glows in the dark? That's right, StreetGlow under-body neons, and we all know that underglow helps contribute to that 10 second car!
"Why must everything that is broken be fixed?"
GhostRai is offline
The Following 2 Users Say Thank You to GhostRai For This Useful Post:
go_a_way1 (02-16-2016), Tectoniic (02-16-2016)
Old 02-16-2016, 05:56 PM   #321
FRSBRZGT86FAN
http://www.ft86club.com/forums/showt...=40931&page=17
Go down to my post, he was selling it on facebook.
Old 02-16-2016, 06:04 PM   #322
kch
Senior Misanthrope
kch's Avatar
221.3, if i remember correctly.
kch is offline
The Following 2 Users Say Thank You to kch For This Useful Post:
go_a_way1 (02-16-2016), raven1231 (02-16-2016)
#a proven bolt on 221whp, #crackhead, #yolomcswaggins, brz series.poo, fake it till u make it, faster than your brz, gold, home depot mods, imaginarypower, memes are gone, my intake makes boooooost, putuporshutup
P&L Motorsports BRZ / FR-S 4:1 Equal Length Header - Naturally Aspirated P&L Motorsports Engine, Exhaust, Bolt-Ons 244 09-24-2015 04:44 PM
Naturally Aspirated - Backpressure phenom86 Engine, Exhaust, Transmission 16 03-19-2014 12:07 AM
Naturally aspirated and 87 octane... zooki Engine, Exhaust, Transmission 46 09-11-2013 11:25 AM
Who is happy the engine will be Naturally Aspirated? Ryephile Engine, Exhaust, Transmission 491 05-02-2012 10:10 PM
