Old 02-15-2016, 05:12 PM   #15
raven1231
I paid 22k brand new for my 2013 in 2014. Definitely wouldn't buy that...
Old 02-15-2016, 05:55 PM   #16
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by ZDan View Post
I am thinking about buying a 2014 BRZ limited at nearby dealership that sells a lot of lemon-law buyback cars (including this one). They gave me the service history on this car, from which:
1/22/2015 4480 miles: CEL, P0011 camshaft bank 1. Tech replaced right intake oil control valve
2/27/2015 4684 miles: CEL and car sputters, codes P000A and P0011, checked VVT angles 4* difference betweeen L R banks, replaced ECM and right intake cam sprocket
3/25/2015 4696 miles: CEL on, P0011. Checked intake advance angles 75* difference from left to right bank. Replaced cam sprocket and ECM ACVS solenoid is from good lot per tech line. Advance angles are still off cam timing is go
The dealership the car is at now says it is fixed, but the above is the last note in its service history and doesn't exactly suggest that: "Advance angles are still off".
I drove the car and it seemed perfectly fine. Dealer says if it hadn't been fixed it would be tripping the CEL and not running right.
Has anyone had similar issues to these, and were they ultimately fixed?
Thanks for any words of wisdom!
Old 02-15-2016, 06:50 PM   #17
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Oh wow, I didn't see that they wanted 22 for it. That seems way too high for a lemon car to me, maybe there's tons of room built in to come down though.
Gear_One_Performance is offline   Reply With Quote
Old 02-15-2016, 07:16 PM   #18
ka-t_240
Yeah, only way I'd do it was if:
1) I could assure myself the engine is fine
and
2) the discount relative to a pristine-title no-problem-history Limited was a lot more than ~$1500
I figure the best deal I could get on a new Limited would be ~$27k, izzat about right? Wouldn't mind letting someone else take the initial depreciation hit, but might go that route. Or just keep S2k...
I bought my limited for 22.6 with 5k on it and no issues.
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
Summerwolf (02-19-2016)
Old 02-15-2016, 07:19 PM   #19
DAEMANO
Time Traveller
$22k!
The rent is too damn high!
There will be tons of FR-S/BRZ coming off 2013 3 year leases this year. You will have no problem finding a sub $20k car with a clean repair history. I'd wait.
Old 02-19-2016, 10:26 AM   #20
jegglz
Drives: 2013 frs
Wow i figured i would be seeing the car around 18k at best, That is not worth it at all. There are tons coming up now used for great prices. Picked up my 2013 a little over a year ago for 21k with 1800 miles on it.
jegglz is offline   Reply With Quote
Old 02-19-2016, 10:28 AM   #21
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Like others have said. You can find great condition low mileage used ones for less or right around the same.
I have seen multiple 15K mileage BRZ Limited in the high 17's lately.... just keep looking and avoid a problem child.
Old 02-19-2016, 03:51 PM   #22
raptorhunter89
Drives: 2013 Subaru BRZ
Lemon for 22k?
RUN!
maybe if it was 11k with a warranty..
raptorhunter89 is offline   Reply With Quote
Cylinder Head Assemblies causing P000A & P000C? SoundsOfTheUniverse Issues | Warranty | Recalls / TSB 3 01-23-2017 06:37 PM
P000A AVCS check engline light? cookiesowns Issues | Warranty | Recalls / TSB 4 10-24-2015 02:48 AM
BRZ- Lemon? laxfogo Issues | Warranty | Recalls / TSB 24 04-05-2013 06:15 PM
Lease/BuyBack and upgrades Chinadian Scion FR-S / Toyota 86 GT86 General Forum 15 01-08-2013 09:35 AM
