Old 02-13-2016, 06:23 PM   #1
Teseo
Drives: frs
Fog lights installation?
I went to my local autobody shop for a fog lights installation estimate, and im worried because he said, need to remove the front bumper to get it. Im afraid when he install back the bumper can be misaligned. Thoughts?
Old 02-13-2016, 06:42 PM   #2
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
That's the only way to hook up the fog lights. Should've had the dealer install it when you bought it.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 02-13-2016, 06:45 PM   #3
Teseo
Drives: frs
$400 out the door, no thanks
Old 02-13-2016, 06:51 PM   #4
86geek
86geek's Avatar
Yuh, but it comes with a warranty from the dealer. So if the front bumper is misaligned they'll warranty it by fixing it.
Old 02-13-2016, 07:31 PM   #5
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Eh you can technically do it without removing the bumper, however to properly route the harness and make it clean then yea it's best if you do. If there is enough slack then you could get creative with the routing without removing the bumper. I didn't do it on the Winjets at first but I eventually did just to fix the harness.
JonAvalon is offline   Reply With Quote
Old 02-13-2016, 08:15 PM   #6
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Your FRS didn't come with fog lights? I assumed that was standard equipment on all of them
RichardsFRS is offline   Reply With Quote
Old 02-13-2016, 08:19 PM   #7
zman
zman's Avatar
Drives: scion frs
Bumper removal is not necessary . You can access it from the side wheel wells. Really easy installation. Took me about an hour
zman is offline   Reply With Quote
Old 02-13-2016, 08:59 PM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I was gonna say, you literally can just get to those panels under the turn signals without the bumper off, just go through the wheel wells and undo on of the 10 mm bolts under the front tray.
[ame="https://www.youtube.com/watch?v=UtbQvZ1rbaw"]DIY: Install Fog Lights on 2013+ Scion FR-S (HD) - YouTube[/ame]
Don't follow the wiring stuff because I'm not sure what you have, but the access to those foglight locations is easy.
Old 02-13-2016, 09:23 PM   #9
NahumCC
Drives: 2013 FR-S 10 Series
There is no need to remove the front bumper. Removing the outer corners of the lower tray (a 10mm bolt and 3 push pin locking style tabs on each side) will give you all the access you need.
To makes it a little easier you can also remove the three locking push pins in each side of the fender and remove the front turn signal indicators (2 10mm nuts) and it'll make it even easier to do.
I found the hardest part was dealing with the confines of the grounding straps for the OEM kit and getting the plug for the OEM harness install out.
Other than that, its a cake walk.
NahumCC is offline   Reply With Quote
Old 02-16-2016, 08:42 PM   #10
golemslord
Drives: 2014 White FRS
Had mine installed from a shop without needing to remove bumper. Labor cost was $110 and took around an hr and half
golemslord is offline   Reply With Quote
WTB - Buddy Club tail Lights & Winjet Front Head Lights thehube2013brz Want-To-Buy Requests 0 12-22-2015 01:42 PM
DIY Fr-s Fog lights installation help? Thataznguy001 DIY (Do-It-Yourself) Guides 8 07-26-2015 03:09 AM
NEW EXCLUSIVE Valenti Tail lights, Winjet Headlights, Front Bumper lights and Mirrors Speed Element Northern California 34 01-14-2015 05:32 PM
LED fog/running lights installation bibo Cosmetic Modification (Interior/Exterior/Lighting) 1 08-24-2014 06:18 PM
tail lights and light light bar installation xdbuix Mid-Atlantic 6 03-21-2014 04:23 PM
