Old 02-12-2016, 03:48 PM   #1
gled21
gled21's Avatar
Drives: White brz 2015 / 93' s13
E85 vs 91?
I'm currently in the process of installing my Jackson c30 SC into my brz and all my buddies think I should run an e85 tune. So I've looked up pros and cons and so far the pros outweigh the cons. However specifically for our cars what are the obstacles other than the obvious to run e85? In other words car specific, what are the pros and cons?
gled21 is offline   Reply With Quote
Old 02-12-2016, 04:02 PM   #2
ryoma
ryoma's Avatar
if you live near e85 stations, and have the budget to do a flex fuel system (like the Delicious Tuning one), then 100% go for it. the only way I would do an e85 tune is with a flex fuel module so that I am not forced to use e85 only. unfortunately where I live, e85 is nonexistent unless you live in a metropolis like LA.
I guess a con of e85 is less gas mileage, but e85 is also cheaper than 91 so in the end I think it cancels each other out. of course, the main pro is that you get all that extra power and knock protection lol
Old 02-12-2016, 05:09 PM   #3
reeves
After you fork up the money to get a proper tune for it, not really any cons to E85 other than it being scarce in some regions, and your MPG's drop a bit. Personally, I just prefer the sweet smell of corn juice over gasoline fumes in my garage every morning when I start my car.
Old 02-12-2016, 05:21 PM   #4
klear
Drives: 2002 V7 Bugeye STI/2014 BRZ limited
E85 is like jetfuel for boosted cars...so much more knock free timing can be added. Just get tuned for both and flip when you like.
klear is offline   Reply With Quote
Old 02-13-2016, 01:58 PM   #5
Ashikabi
Ashikabi's Avatar
If you have a SC, there may be a, chance you will need fuel pump/injectors to keep up with e85+SC. Research this, and get flex fuel. Otherwise availability is really the only thing holding you back. Cost is negligible for fuel. I figured it out last year and I lost 1 mile per dollar spent on fuel
The Following User Says Thank You to Ashikabi For This Useful Post:
Tcoat (02-14-2016)
Old 02-14-2016, 01:43 AM   #6
Allch Chcar
Drives: N/A
E85 is the good stuff, brother. If you live near an E85 pump.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 02-14-2016, 08:23 AM   #7
serialk11r
Drives: '06 AM V8V Coupe
Good to see you again
Having an E85 pump around must be awesome. There's only a handful in the Bay Area, so I gave up seeking them out just to blend a gallon or two into the tank to raise the ethanol content. At ~20% ethanol my gas mileage was only barely impacted, but I'd like to think that the engine was more smooth and making some more power (it probably was). With boost, it's a no brainer. If it were me I'd keep a couple jugs around if there isn't a station super close to where you live and pour a gallon into every tank as octane booster.
The Following User Says Thank You to serialk11r For This Useful Post:
Allch Chcar (02-14-2016)
Old 02-15-2016, 12:57 AM   #8
Allch Chcar
Drives: N/A
It's good to be back. Some things happened and I moved back *home* in August. No degree to show for it, and I spent all my BRZ fund to get here. I started over from the beginning, except with car this time and a few years experience.
I thought they still had an E85 pump in Eureka. That turned out to be a lie. That's okay. Whenever I drive up to Medford there is a pump and there is a pump in Yuba City if I head south. I'm headed down to Sac tomorrow. Which I hope is my last trip south of Ukiah for awhile. It feels like I'm driving into a police state when I go down south. I have to have front license plates, only approved mods, and all cats installed. I kept my car factory stock just so I can drive down south. Up here, LEO don't care about that asinine stuff. They just care about drugs and alcohol. And I don't do either.
-Allch Chcar
