Old 02-10-2016, 04:44 PM   #29
DAEMANO
Time Traveller
Well engineered drop kunckles for the OEM suspension.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
8686 (02-14-2016), nickmerronesucks (02-10-2016)
Old 02-10-2016, 05:24 PM   #30
FRS Justin
Drives: 2013 Asphalt FRS
I assume for a air strut setup? Good God how low do you go!!!! I have seen some stance FRS cars dragging the ground they were so low. Drop spindles would turn the car into a submarine...... Just saw the OEM part of your post. lol I saw drop knuckles and was like wow and had to reread the post.....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
DAEMANO (02-14-2016), go_a_way1 (02-10-2016)
Old 02-10-2016, 05:31 PM   #31
Ashikabi
Ashikabi's Avatar
So these would give you drop without further suspension mods?
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 02-10-2016, 07:57 PM   #32
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I want GMG to make a bolt-in 4 point roll bar with cross brace and harness bar. As similar to the 997 GT3 RS or club-sport bar as possible. aka FIA legal w/o destroying my car.
I always used Autopower in all my Rx7s, but I want something a little better fitting for the BRZ with no cutting or drilling required.
Hyper4mance2k is offline   Reply With Quote
The Following 7 Users Say Thank You to Hyper4mance2k For This Useful Post:
15limited (03-08-2016), 8686 (02-14-2016), Doozer (02-13-2016), MaximeT (02-11-2016), Silent_Dan (02-10-2016), Takumi788 (02-13-2016), TRAKRAVN (02-10-2016)
Old 02-12-2016, 10:31 PM   #33
Ashikabi
Ashikabi's Avatar
I would like to +1 the under body tray for smoother air flow
Old 02-12-2016, 10:42 PM   #34
D_Thissen
D_Thissen's Avatar
I'd be interested in functional side vents that look OEM, and a quiet single exit exhaust that doesn't drone.
The Following User Says Thank You to D_Thissen For This Useful Post:
Drambeenie (02-23-2018)
Old 02-12-2016, 11:24 PM   #35
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Another vote for quiet light single exit exhaust and proper integrated diffuser.
Dry sump oiling system
Decay107 is offline   Reply With Quote
Old 02-12-2016, 11:47 PM   #36
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
I would also love more options for a proper functional diffuser and not just extra bits that make just drag. Another vote for the vented fender inserts too.
Sent from my Glade Air Freshener
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following User Says Thank You to yelsew For This Useful Post:
Bonburner (02-13-2016)
Old 02-13-2016, 12:47 AM   #37
churchx
churchx's Avatar
Drives: 2014 GT86
Fender inserts have two big caveats. It's a part which desirability is very individual taste dependent and that already has lot of aftermarket options available, including vented ones.
As for extra small ideas .. from different center console for fitting OEM-ish looks i preferred (&installed) PZ435-10340-00 (RHD PZ435-10341-00) armrest. Didn't like one bit for it though, that it opens to passenger side, not to back. Would love to see some hinges kit to convert it opening to back.
Old 02-13-2016, 02:28 AM   #38
Irace86
Drives: BRZ + Ducati M796
1) universal badges that are quality
2) quality weighted leather shift knob
3) oem armrest with a cup hole(s)
4) stock shiftknob upper and lower replacement inserts cnc machined
5) rear diffuser
6) replacement single exhaust hole rear bumper
7) something to make the engine bay look nice
Irace86 is offline   Reply With Quote
Old 02-13-2016, 03:05 AM   #39
FRS Justin
What sound are you looking for, is their anyway to compare it too something. I assume a 2-1/4 to 2.5 inch piping. I will use my stock auto frs for fitment and sound clips. I might even spring for the dyno.
710whp
Old 02-13-2016, 03:08 AM   #40
FRS Justin
Can someone sketch up a diffuser design so I have something to take to the table.
710whp
Old 02-13-2016, 03:20 AM   #41
FRS Justin
I will try this week to take some of ideas to manufactures to see what we can come up with as soon as I have some sketches and ideas that everyone agrees too. We will probably have to group buy a lot of 10 to get this started. If your all in I will try to keep quantities as low as possible for group buys. Lets get some ideas locked in and agreed on I'm pumped to get this off the ground.
PS anyone's help to get this rolling would be appreciated. Like posting sound clips, designs ect. to get a design finalized.
710whp
Old 02-13-2016, 03:22 AM   #42
churchx
churchx's Avatar
Drives: 2014 GT86
FRS: imho something of simplest minimum without any sketching would be something 1:1 to stock rear lower black unpainted part, just with exhaust cutouts closed (but readied for cutting out where as needed depending on exhaust configuration). Step above - same as above, but with rear light cluster moved above a bit, for more space for potential centered single cutout. That's if one decides on single piece part that can be easily DIY customized for any exhaust combination. I wouldn't incorporate diffuser right away in this design, for those that simply want OEM-ish but neater looking single exhaust rear bumper, and don't want to have bumper lowered than it is (for example i use fact that rear bumper is higher, to go over curb) except maybe some mounting points/bolt holes to bolt on extra diffuser additional part. There are already many body kits/rear bumpers/diffusers that make car/rear bumper lower. Would be nice to have one that is OEM practical for daily driving.
MaximeT (02-13-2016)
Selling BRZ, parting out parts (STI, Toms, TRD parts) ucsmfu Canada Classifieds 32 09-16-2015 12:17 PM
Edirb racing seats (manufactured by Bride racing) DavidBob Other Vehicles & General Automotive Discussions 7 08-21-2014 01:25 PM
Buying computer parts compared to suspension parts Anomie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-09-2013 11:56 AM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
