Old 06-12-2012, 10:06 AM   #15
mark
Drives: Evo X GSR TC-SST + Raliart Colt
Originally Posted by Spaceywilly View Post
If the oil changes were a PITA I could see the point. The Civic Si for example requires you to remove the front wheel to change your oil. That did really turn me off of that car. But spark plugs are just not something you change often enough for me to see it as a problem at all, especially when you look at how easy and clean everything is in the engine bay. It won't be a problem at all. Any mechanic will tell you, Subarus are very easy cars to work on except for the spark plugs.
taking off a wheel on a civic annoys you? really? I would not want you to work on my car if youre too lazy to do it properly.
ive take R32 GTR turbos off with nothing but hand tools. in 6 hours thats an accomplishment. plugs on a MCVR36 camry is harder than EJ20/25 motors
mark is offline   Reply With Quote
Old 06-12-2012, 10:22 AM   #16
the_3d_man
Drives: 2007 Legacy GT
Originally Posted by eikond View Post
I have mixed feelings about this topic. The difficulty of changing the spark plugs wouldn't dissuade me from buy the car new.. but it would certainly make me think twice about buying one used in a few years.
I've had a long string of Nissan 240sx's.. I can't tell you how many times I needed to pull spark plugs as part of diagnosis as you're working on the car. Being able to swap plugs to find a misfire, check the color of the tips to see if it's rich or lean, do compression tests, and other stuff makes a used car or a modified car easy to live with. Having to lift a motor to do any of these things will make this an unfriendly car to own and modify when it's a bit older. I'm not a big fan of this.
My thoughts exactly as I was reading the procedure.
the_3d_man is offline   Reply With Quote
Old 06-12-2012, 10:30 AM   #17
Jayde
Jayde's Avatar
Originally Posted by n2oinferno View Post
That's not entirely true. When I was living in an apartment I had nowhere to work on my car. Wasn't even able to do my own oil changes. And I have the feeling that some people see "pull engine = ridiculous labor cost" which can factor into future planning. I'm just saying, it might be something to take into consideration for some people.
When I saw that it required lifting the engine, I thought, oh wow that'll be a pain.
And then I thought:
You, my friend, have just made my day with that picture.
Jayde is offline   Reply With Quote
Old 06-12-2012, 10:51 AM   #18
aethelwulf
Drives: 05 Sti 20g'd
Originally Posted by Ranatsu View Post
If its even remotely similiar to changing the plugs in the WRXs or STi I've owned.. It will be a cake job.
Yeah, the STi procedure says you need to lift the engine to do the plugs, but I did them myself without lifting it fairly easily. Now, who knows how much harder the BRZ is to do, but I think that there are plenty of people that work on subarus and have gotten past this issue and it won't be as bad as it seems.
aethelwulf is offline   Reply With Quote
Old 06-12-2012, 10:55 AM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
And then I thought:
Agree on the apt complex issue but hopefully most have a friend/family member whose garage/driveway they can use.
Well you don't really pull the engine if you are the dealership, and I bet you can jack it up instead too if you want to risk it. A hoist will be able to lift it just enough to do it also..
I also wonder if it's easier to drop the subframe with the engine mounted a few inchs.. time will tell. Not something I'm worried about looking into anytime soon
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-12-2012, 10:57 AM   #20
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by azian_advanced View Post
if you ARE going to replace your plugs, you might as well go with good ones. i recommend using denso iridium IK22's. not sure if you've got them over-the-counter but i had to get mine from a tuning shop. it's what the tuner recommended. also they are just rebadged TRD plugs
You mean the TRD plugs are just rebadged denso plugs.. I'm not sure if that's accurate but Denso definately doesn't rebadge "TRD" plugs regardless..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-12-2012, 11:05 AM   #21
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Just because the service manual saus you have to lift the engine, it does not mean you ACTUALLY have to. I'm pretty sure theres less room between the heads and frame rails on the STI and those plugs you can pull without lifting the engine.
Hell, I know a guy who can do head gaskets on a SOHC boxer without removing the engine.
Don't panic.
Old 06-12-2012, 11:10 AM   #22
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Cool story. Taking the wheel off is not what annoys me. What annoys me is that a job that should be simple and take 5 minutes now takes 30 minutes for no reason other than bad engineering.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 06-12-2012, 11:22 AM   #23
dsgerbc
Drives: BRZ(sold), STI
Originally Posted by Draco-REX View Post
Don't panic.
This. Quite a few Subaru service manuals had ass-backwards procedures to do relatively simple tasks, that could be gotten around by the DIY mechanic.
And, like I said in the other thread, nothing prevents Subaru from coming up with a special tool that will reach the plugs w/o lifting the engine .
Old 06-12-2012, 11:34 AM   #24
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
Wow! A lot of reply's on this. As some have said perhaps it won't be as bad as Subaru says it is.
We need someone that has a BRZ/FR-S to take a close look and see what it really looks like to remove the plugs.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 06-12-2012, 11:34 AM   #25
Mavrik
Drives: 2013 Subaru BRZ
Having worked/rebuilt several subaru engines in my past, both turbo duel overhead cam and single n/a engines... the spark plug placement doesn't bother me a bit. Its no different in placement then any of their other engines. Seems to have more room than an STi infact.
If anything I am more impressed with the BRZ that Subaru kept a lot of their tried and true stuff under the hood.
2013 SWP Subaru BRZ. First in Alaska
Mavrik is offline   Reply With Quote
Old 06-12-2012, 11:36 AM   #26
brzninja
brzninja's Avatar
Drives: 2015 WRB WRX Premium
I've only have to replace my spark plugs once...maybe twice in the past 10 years? I'm not worried about it.
2013 Subaru BRZ Limited WRB
brzninja is offline   Reply With Quote
Old 06-12-2012, 11:47 AM   #27
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
It's not any worse that what it takes to replace the plugs on my SC300 (intake manifold wraps over the head). I am not overly concerned about it. I would have bought a Camry if I wanted a pain free car.
FrX is offline   Reply With Quote
Old 06-12-2012, 12:59 PM   #28
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Yeah, the manual may say to lift the motor but if you find a good subie expert, I bet they can do it the same as the rest of the subies. If there is an air pump it may need to be removed as well. Not to mention most plugs are good for 60-100k miles these days.
-mike
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
csaba (06-12-2012)
Subaru or Toyota drain plug? yayforaddison Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 05-06-2020 10:59 PM
Exhaust tip removal Draco-REX Cosmetic Modification (Interior/Exterior/Lighting) 97 05-27-2017 05:50 PM
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 10:12 PM
Spark plug type and heat ft86-UAE Engine, Exhaust, Transmission 4 06-10-2012 10:21 AM
What do you wish was changed about the brz/frs? GirlyScions BRZ First-Gen (2012+) — General Topics 16 06-04-2012 03:26 AM
