Old 02-08-2016, 02:08 PM   #1
cesar9127
Drives: 2013 Scion Fr-s 10 series
Tire size help? XXR 530 18x8.75 +33mm
Hey guys,
I need some help. I am pretty dam smart when it comes to knowledge about cars. My weakness is definitely tire and wheel sizes, I think due to the lack of my experience with them. Anyways, I was in desperate want of wheels for my FR-S. I have coilovers already but wheels make a big difference in looks. I ordered XXR 530 18x8.75 +33mm. I want to get some pretty thin tires on them, nothing too crazy thin. I have an example of what I'm looking for as in size comparison. They are Enkei RPF 1's on a hot lava fr-s and i know they are different wheels and sizes, its only as a comparison of what i want my tires to look on my wheels. Any of you that could help, it would be GREATLY appreciated. THANK YOU!
cesar9127 is offline   Reply With Quote
Old 02-08-2016, 02:18 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The tires pictured are 245/35/18. I run this size tire on 18x8 +45 and 18x9 +42. It's outside diameter is equal to stock. I also would consider a 225/40/18. +33 will poke in the front (I am conservative) and you may want the narrower tire. They are also cheaper. Camber bolts should help a bunch. Inexpensive too.
Edit: I know alot of guys run a 235/40. I am just not a fan of how they look. I would rather have either size I mentioned...
Old 02-08-2016, 02:22 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by cesar9127 View Post
Hey guys,
Those ones you have in the picture are the wrong bolt pattern I hope you didnt order those ones?
Old 02-08-2016, 02:47 PM   #4
cesar9127
Those ones you have in the picture are the wrong bore I hope you didnt order those ones?
These are the ones I actually ordered
Old 02-08-2016, 02:54 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Okay good lol! I was worried
Old 02-08-2016, 03:05 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Do they come with hub rings? If not, I'd suggest getting some. Hub rings center the wheel on the hub.
Old 02-10-2016, 03:15 AM   #7
cesar9127
Decided to go with 225/40r18 after some research. I did order hubcentric rings. Thank you guys
Old 02-10-2016, 04:13 AM   #8
shadoken
shadoken's Avatar
Drives: FRS RS 1.0
Am trying to decide between these two sizes as well for my 8.5'' wheel width. Ideally I would go with 225/40 , but I am just scared of it being stretched and leaving a gap on the sides.
shadoken is offline   Reply With Quote
18x8.75, 530, size, tire, xxr
Tire size for square 18x8.5+38 lowered on coilovers? B$ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 10-07-2015 05:50 PM
Tire compound vs Tire size Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-22-2015 10:55 AM
Tire size help! brzee_vic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 04-09-2015 08:36 AM
ADVAN RGD - 18x8.5 +33mm 5x100 (GOLD) ** Limited Edition ** RavSpec Wheels and Tires 3 01-22-2015 05:04 PM
Tire size for 18x8 wheels?225/40 or 245/35 FT86RGV Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-06-2013 01:24 PM
