#113 |
Drives: 2015 Alfa Romeo 4C
#114 | |
Still 17!
Drives: 2014 Silver BRZ Limited
You have a different driving car awaiting you when you put the right fuel in it!
'14 BRZ LIMITED-OFT (W.W. TUNED)-PERRIN-K&N-WHITELINE-DIODE DYNAMICS-GRIMMSPEED-REXSPEED-FT86-TAPTAP-OLM-GOODYEAR-OSRAM-WEIR-ENKEI-TOMEI EL
#115 | |
Drives: FT86
87\89 is below whats recomended by the manufacture (91 is minium recomended) below is log of stack car on stock tune on South Africian 95 RON fuel about your 91 USA fuel it knock pretty bad and IAM is 0.3 , this should be 1 for max performance and economy. ecu will pull timing and add fuel to try to combat knock on low quality fuels so you get less power and worse economy on poor fuels. 87\89 would be getting close to causing damage due excessive knock especially if you drive it hard or track car on such low quality fuel http://datazap.me/u/steve99/south-af...0-27-28&solo=2 |
#116 | |
Drives: 2014 Argento FRS
Would it be prudent to somehow bump USA 91 to 93 using E85/91 mixture in a way so not to offset fuel trims radically? Sent from my iPhone using Tapatalk |
#117 | |
Drives: FT86
The problem is going to be the ethanol % varies and the petrol they blend with E85 is not always high grade. |
#118 |
Drives: FR-S 10 series
came in here thinking there was an update :/
IG: @Lucky_FatPat
10 series // TRD x Turbo Build: http://www.ft86club.com/forums/showthread.php?t=79474 |
#119 |
I'd love to try these out, is it possible to apply as a beta tester for these tunes?
2013 6MT Firestom FR-S. invidia Q300, OpenFlash Tablet and Header, Eibach Sportline Springs, SPC LCA, Shift springs and bushings. Dashlinq4 Radio.
#120 | |
I'd like to see an update as well, I'd love to have this tune before the summer starts which is when I'm putting my UEL in. I'm assuming Shiv is just super busy with other model cars as well which is totally understandable for something that's open source and free like these tunes.
#121 |
Drives: Subaru BRZ Limited
Read through the thread but couldn't determine the changes that are being made to the E85 map and what the power changes will be, I did notice that it Shiv mentioned it wasn't a significant improvement but interested none the less
#122 |
Yup, all the gains are on 91 or 93 under 80 degrees Fahrenheit (26.67 celsius)
#123 |
Drives: 2014 WRB Bravo Romeo Zulu
All I can say is you guys won't be disappointed with the revised tune!
#124 | |
Drives: 2014 SWP BRZ Limited 6SP
Sent from my LG-H810 using Tapatalk
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now. |
#125 |
Drives: 2016 Raven FR-S
#126 |
Drives: GT86, 22 BRZ
| Just how noticeable is OFT+OFH and stage 2 tune? | BBYZILA | Software Tuning | 58 | 03-20-2018 11:56 AM |
| OFT 2.0 Stage 1 93 Tune | MurderRider | Software Tuning | 57 | 03-21-2016 12:30 AM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
| FA20club.com Turnaround Times On Modified Tune Files | FR-S Matt | Software Tuning | 103 | 11-13-2013 01:48 PM |
| So whate does stage 3 tune do? I already have 2 | Frsexxxy | Engine, Exhaust, Transmission | 17 | 05-14-2013 06:30 AM |
