Old 02-06-2016, 04:55 PM   #1
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
Tire Stickers
[ame="https://www.youtube.com/watch?v=wnXOVS5Ycow"]Tire Stickers Game Changer - YouTube[/ame]
Material
Towel
soap
Sand paper doesn't really matter the grit just not a heavy grit
(optional - brake cleaner or alcohol (acetone works well) cleaner.
Instructions:
-Clean surface with house hold degreaser, or what you maybe. Acetone works well as well.
-Clean the back side of the tire sticker as well. You can use acetone or brake cleaner
-Apply the FleXement adhesive to the back side of the decal. I personally went crazy with it.
-Firm press the decal on the tire. Note: you can use the lines that comes with every tires to help guild where you want to put them.
-Wait 1 hour for cure 24 hours @ room temperature. So, if it is colder wait longer.
-Remove the film and show off your decal.
Order here:https://www.tirestickers.com
IMO they are the most affordable in the market. It works well and looks good.
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 02-06-2016, 05:16 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
interesting
Old 02-07-2016, 03:02 AM   #3
ollie
ollie's Avatar
Drives: GT86
Know a few people that would be interested. What is the cost?
ollie is offline   Reply With Quote
Old 02-07-2016, 03:32 AM   #4
ryoma
ryoma's Avatar
I like the look of them and even considered it at one point, but their website shows that a set of 4 is around $100. that is definitely way more than I am willing to fork over lol
The Following User Says Thank You to ryoma For This Useful Post:
ollie (02-07-2016)
Old 02-07-2016, 03:34 AM   #5
ollie
ollie's Avatar
Drives: GT86
Cheers @ryoma
Old 02-07-2016, 03:42 AM   #6
ryoma
ryoma's Avatar
Originally Posted by ollie View Post
Cheers @ryoma
I picked the permanent letter option which is more expensive than the peel and stick. the peel and stick was like $40 for top and bottom letters. but it seems like the permanent option is the one you want I'm assuming
Old 02-07-2016, 03:43 AM   #7
ollie
ollie's Avatar
Drives: GT86
I was thinking of the permanent letters. $40 for temp seems ok if you have a show car thanks @ryoma
Old 02-07-2016, 04:37 AM   #8
zman
zman's Avatar
Drives: scion frs
Great review!
zman is offline   Reply With Quote
Old 02-09-2016, 04:21 PM   #9
8R6
8R6's Avatar
Drives: FRS
make sure to also drive around the block a few times after letting the glue cure. the sidewall will flex as the car drives obviously, and this can (and almost always will) cause some of the adhesive to come undone. not a big deal, but you'll need to redo some corners and whatnot with extra glue.
if you do the temporary ones, these are way cheaper at like 1/4 of the cost for a full set of tires (4) and easy to stick on smooth. but as tirestickers warn you, these really are temporary. mine lasted about a week before they completely lost color.
i had the permanent set on my previous wheel/tire setup, and once i got past the initial week of having some of the letters lift up, they really were permanent afterwards. too bad i lost a couple letters in the process lol
8R6 is offline   Reply With Quote
Old 02-11-2016, 01:31 PM   #10
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
https://tredwear.com/ i would go with these
Old 03-04-2016, 12:38 PM   #11
nastynate88
nastynate88's Avatar
Drives: 2014 BRZ
Thanks for the video! Could you specify which decal height you selected for the tire sticker in the video?
nastynate88 is offline   Reply With Quote
FS: 4U-GSE stickers, Toyota Emissions stickers and "86" stickers *SOLD OUT* trueno86power Interior Parts (Incl. Lighting) 23 07-10-2016 04:07 PM
What do you do with the stickers? Ramster Off-Topic Lounge [WARNING: NO POLITICS] 33 07-13-2015 12:50 PM
GT-86 Stickers nabil_frs CANADA 4 03-29-2013 02:14 AM
my new stickers jschendel Scion FR-S / Toyota 86 GT86 General Forum 5 08-01-2012 10:46 AM
Stickers ! SCIONMONTREAL CANADA 3 04-20-2012 02:44 PM
