Old 01-19-2016, 03:44 PM   #15
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Originally Posted by ハチロク View Post
Yeah I am really about 1" lower (actually I think a little less). I'll try adding some clicks of rebound and try to see if I feel any difference. should I try adding front or rear or both do you think?
I'd do both, for now. You can fine tune the balance of front/rear rebound based on driving style, and what your desired outcomes are.
You'll know you've added too much rebound if your car feels too stiff/skittish, so start with small adjustments.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
ハチロク (01-19-2016)
Old 01-19-2016, 03:45 PM   #16
Tor
Tor's Avatar
Drives: Toyota GT86
Rear toe adjustment:
Tor is offline   Reply With Quote
The Following 2 Users Say Thank You to Tor For This Useful Post:
ハチロク (01-19-2016), 86Tony (01-19-2016)
Old 01-19-2016, 03:55 PM   #17
jawn
jawn's Avatar
Originally Posted by Tor View Post
P.s.
I don't think you'll get enough front camber without camber bolts. They are only a few bucks anyway and you can let the alignment shop put them in if you don't want to take the wheels off again, they have to losen the stock bolt anyway.
KWs are slotted. You should be able to get past -2.5 with an OEM crash bolt.
Old 01-19-2016, 04:35 PM   #18
Racecomp Engineering
One note, I'd recommend taking your car to AZP Installs in New Jersey for your performance alignment.
- Andrew
CSG Mike (01-19-2016), jawn (01-19-2016)
Old 01-19-2016, 04:45 PM   #19
Tor
Tor's Avatar
Drives: Toyota GT86
That's possible, but the crash bolt is a replacement too and not the standard bolt. So in any case "ハチロク" will have to get another bolt.
Old 01-19-2016, 05:58 PM   #20
CSG Mike
CSG Mike's Avatar
Also have AZP corner balance your car to get a little bit more out of it
Old 01-19-2016, 07:12 PM   #21
ハチロク
ハチロク's Avatar
Drives: 2014 Ultramarine FR-S
- Andrew
Thanks. I've only heard good things about AZP on the forums.
ハチロク is offline   Reply With Quote
Old 01-26-2016, 07:09 PM   #22
ハチロク
ハチロク's Avatar
I added 3 clicks or rebound on all 4 corners. I can definitely feel a big difference over bumps. feels like I get a little more feel on direction changes too. Problem is it's still bouncy. I didn't really feel any difference in how bouncy it is after I made the rebound adjustment. I also noticed even when I close the door I am seeing the car shake back and forth way more than I used to on stock suspension. What should I do?
Old 02-04-2016, 01:16 AM   #23
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
i put rebound to 10 and feel more comfortable, and when i go to track last time is stock setting and i feel it is a little soft, and than i go to autocross and put it to 5 and feel great on track!
ZHoward is offline   Reply With Quote
Old 02-04-2016, 01:58 AM   #24
Northwest86
Drives: Velocity Orange 86 GT
I set the ride height just slightly shy of fully extended (as specified in the manual) I believe it is about 1" drop all the way around.
I've never understood this. You used the bottom lock nut and extended the whole assembly? Why not set ride height with the Spring Perches Properly?
Northwest86 is offline   Reply With Quote
Old 02-04-2016, 10:15 AM   #25
ハチロク
ハチロク's Avatar
The KW v3 only has 1 adjustment ring to adjust ride height. Some coilovers have two adjustments one to adjust "spring pre-load" and one to adjust ride height. The KW v3s as seen below don't really need this. The kw coilovers ship with two springs per coilover. You can see there is a "helper spring" the flat spring on top and the "main spring" the larger looser wound spring on bottom. With the KW coilovers when you adjust the ride height you are compressing or loosening the helper spring when the coil isn't mounted. I have my coilovers set up to max height. this means that at fully extended the helper spring is already compressed (in normal driving conditions once the coilovers are mounted and the car is lowered the helper spring will always be compressed anyway). KW gives specific instructions as to how much you can adjust the adjustment ring so that you don't add "spring pre-load" to the main spring.
Old 02-04-2016, 03:29 PM   #26
Northwest86
Ah Ok. I thought like so many you had the threaded body and were actually extending the body of the suspension to be longer. You should pretty much always adjust ride height with the "preload". Even though thats a heavily misunderstood topic. Good to see that the KW's do it the correct way.
Old 02-05-2016, 12:54 PM   #27
ハチロク
ハチロク's Avatar
- Andrew
Just got an alignment at AZP Installs. They got me about -2 camber front and rear (with stock crash bolt). These guys did a great job and were very fast and helpful. Thank you for the recommendation!
Since I started this thread I have been messing around with the coilover settings. right now my settings are:
Front:
Rebound 6
compression 4
Rear:
Rebound 6
compression 3
The rebound adjustment did way more to make the ride feel harsh. I think I'll take it back a click or two. Compression adjustment was a bit harder to feel. It comes across more to me in fast corners and a bit on turn in.
Not much really helped the bouncy feel until I put more air in the tires.... I think a lot of the bounce was in the tires themselves not the suspension.... Has anyone else experienced this?
The Following User Says Thank You to ハチロク For This Useful Post:
Racecomp Engineering (02-05-2016)
Old 02-05-2016, 02:07 PM   #28
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Front:
Rebound 6
compression 4
Rear:
Rebound 6
compression 3
Yes. My current tires feel VERY weird over bumps now that I have stiffer suspension.
Ideal Suspension Setup for DD and Mild Track Use? Lust Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-22-2022 09:37 AM
Developing an ideal intake for a turbo setup IBill4You Forced Induction 34 07-14-2015 12:29 AM
Coilover Settings Database / Thread glamcem Tracking / Autocross / HPDE / Drifting 10 08-11-2014 09:01 PM
Ideal Exhaust setup cjcoupe AUSTRALIA 4 02-07-2014 07:40 AM
Stance SS coilover settings Dispect Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-05-2013 04:43 AM
