Old 07-06-2015, 01:44 PM   #1
IBill4You
Drives: 2015 Subaru BRZ
Developing an ideal intake for a turbo setup
So I am struggling with building an intake for a turbo application. Without having the resources to design, build, and test different options, I am hoping to get some feedback from the community before I move forward. I have obtained aluminum mandrel bent piping for a cold air intake. I was hoping to place the filter behind an air duct located behind the fog light bezel area.
I am curious whether this cold air induction design would be more or less effective than attaching the filter directly the the compressor housing and ducting cold air to a box around the filter that would not be completely enclosed.
The cold air intake design would ensure lower temperatures on the front mount turbo setup, but would be more restrictive than the a filter mounted directly on the compressor housing. Not wanting to compromise I am left wondering if minimizing restriction by mounting the filter directly to the compressor housing and plumbing cold air would be more efficient.
Any takers here? I'm interested in theory and application. Should I be more interested in fitting a larger intercooler? Yes, but I am getting hung up with wanting the most correct answer here.
@Sportsguy83
IBill4You is offline   Reply With Quote
Old 07-07-2015, 08:49 PM   #2
mrk1
Drives: Sterling BRZ Ltd
Filter on the turbo works fine, I was seeing 2 degrees above ambient intake Temps with that. I like the simplicity of filter on turbo. Putting a filter down in the fender works nicely but takes more parts. I do think your over thinking it a bit.
Get ready for "hot air intake" or "cold water intake" comments.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 3 Users Say Thank You to mrk1 For This Useful Post:
Dream20b (07-09-2015), IBill4You (07-08-2015), Xero-Limit (07-09-2015)
Old 07-07-2015, 09:40 PM   #3
protpibe
protpibe's Avatar
@Sportsguy83
That sounds like a ton of work for some "maybes" lol. Just put a filter on the compressor and run meth if you're concerned about IATs.
The Following User Says Thank You to protpibe For This Useful Post:
Old 07-07-2015, 09:57 PM   #4
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
i'd recommend having a bit of piping off the turbo inlet. it allows you a place to pull constant vacuum from, if you so desire.
Sammakko is offline   Reply With Quote
The Following User Says Thank You to Sammakko For This Useful Post:
Old 07-07-2015, 10:20 PM   #5
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I like how everyone tags sportsguy lol
The Following 3 Users Say Thank You to cdrazic93 For This Useful Post:
IBill4You (07-08-2015), Kiske (07-09-2015), Sportsguy83 (07-07-2015)
Old 07-07-2015, 10:43 PM   #6
mrk1
Here is my 3" intake down behind the headlight. No more washer bottle though.
The Build Thread
The Following 4 Users Say Thank You to mrk1 For This Useful Post:
Cessblood (07-09-2015), DustinS (07-08-2015), IBill4You (07-08-2015), raven1231 (07-08-2015)
Old 07-07-2015, 11:29 PM   #7
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I did the same as you. Never used the washer fluid anyway.
We used to see E.T drops on our VW drag car between open turbo (no filter, turbo back against firewall), and a 4" inlet pipe routed to the headlight opening. Car always ran better with the inlet pipe than without. I'm also talking 40psi of boost and 8 second passes though.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 07-07-2015, 11:38 PM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I have filter right on turbo.
Jamesm (HRI Tuning) did some tests to see if it was significant, noticeable and worth it to have the filter relocated for cold air. The results were that it made negligible difference, so filter on turbo for simplicity it is.
I did not get the mention btw
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
cdrazic93 (07-07-2015), IBill4You (07-08-2015)
Old 07-07-2015, 11:51 PM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@Sportsguy83, there's your mention.
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
IBill4You (07-08-2015), Sportsguy83 (07-08-2015)
Old 07-08-2015, 12:28 AM   #10
IBill4You
LOL Thanks for all the replies guys. I'm going to go ahead and throw together a CAI and log with Ecutek before and after. Hopefully this weekend. I'd love to throw a larger intercooler in there, but I have to figure out a new way to mount my oil cooler etc. I'm not sure if the lines are long enough to push it behind the passenger fog light bezel or not.
Old 07-08-2015, 10:17 AM   #11
puma
crew chief
puma's Avatar
Drives: Race car FR-S
For a couple of pull on the highway or the dyno, i doubt it makes a difference but running 30+ minutes intense on a race track is worth getting every single bit of fresh air you can because it because hot under the hood. We usually build a box around the filter with air pick up right from the front to make sure we pick up the air as fresh from the outside as possible and make a ram air effect to it. (more effective for NA but still)
On our RSX race car our box was opened towards the transmission and we were seeing 55 degC IAT. When we closed the box and picked up air out front we started seeing IAT only 5-10 degC higher than outside temp, it was a reduction of almost 20 degC with just the air pick up location!
puma is offline   Reply With Quote
The Following User Says Thank You to puma For This Useful Post:
Old 07-08-2015, 10:43 AM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I'm just here for a mention. I remember reading an article back in my Honda B series days where the difference between filter on turbo and an intake routing the filter to where the OEM airbox sat made a very noticeable difference.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
cdrazic93 (07-09-2015), IBill4You (07-08-2015)
Old 07-08-2015, 10:46 AM   #13
raven1231
@Sportsguy83
The Following 2 Users Say Thank You to raven1231 For This Useful Post:
Dream20b (07-09-2015), Sportsguy83 (07-08-2015)
Old 07-08-2015, 11:19 AM   #14
STV3
Señor Member
STV3's Avatar
If your intercooler is doing its job, then the intake should not matter at all on a turbo charged car.
STV3 is offline   Reply With Quote
The Following 2 Users Say Thank You to STV3 For This Useful Post:
Ideal Suspension Setup for DD and Mild Track Use? Lust Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-22-2022 09:37 AM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
Ideal Exhaust setup cjcoupe AUSTRALIA 4 02-07-2014 07:40 AM
New Rumor: Subaru Developing Turbo 4 2.0T for BRZ Hachiroku BRZ First-Gen (2012+) — General Topics 350 02-02-2013 01:52 PM
