Old 02-04-2016, 05:25 AM   #15
steve99
Drives: FT86
Originally Posted by Dico View Post
Thanks for updating.
But I still wanna know when BRZ/86 in China could get FFS & Launch control. I will be very happy to test it here. Three of my friends had bought OFTs also, want FFS & LC badly
best to email shiv sales@openflashperformance.com
Old 02-04-2016, 05:28 AM   #16
Dico
Drives: SUBARU BRZ
Did it, thank you, steve
Dico is offline   Reply With Quote
Old 02-04-2016, 01:38 PM   #17
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Will there be any (planned) new updates for the ESC tunes @Shiv@Openflash?
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Old 02-04-2016, 02:31 PM   #18
Who8myrice
Drives: Ap2
Is ffs already enabled in default file of this new update ?
Who8myrice is offline   Reply With Quote
Old 02-04-2016, 05:00 PM   #19
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
@Shiv@Openflash After the recent OFM auto update, my OFT has been saving 2 copied of my logs.
Also, a error message pops up when I try to delete the log files. "error deleting file"
Intent > Content
Old 02-04-2016, 05:49 PM   #20
steve99
Drives: FT86
Also, a error mssage pops up when I try to delete the log files. "error deleting file"
Id try this
Connect oft to pc connected to internet and see if their are any more updates
Make sure your on latest Temlate File
Try deleting the second of the two files not the first one
Try the Delete All Files button
Still no go Try saving a short log file with same name as the file that wont delete, this should overwrite the offending file with a non corrupt log of same name allowing you to delete it.
If all else fails then last resort write back stock tune to car do a full OFT erase, remarry and reload tunes, hopefully that resets it.
Old 02-04-2016, 11:32 PM   #21
solidONE
solidONE's Avatar
Id try this
The logs that couldnt be deleted magically disappeared the next time i plugged into computer...
Intent > Content
Old 02-13-2017, 04:06 PM   #22
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Hello,
I'm not sure if this has been posted somewhere else....but here goes nothing.
So I am a complete noob to tuning and recently just bought the OFT and downloaded the new maps for stg 1 91 and 93 octane as I have 93/94 available locally. What differences will I notice over stock, I assume;
- better throttle response?
- more torque through the "dip zone"?
- softer redline cutoff?
- what is redline with the 91/93 tunes? can this be changed to a bit higher - i.e 7500-7600
- what is the cold start like?
and anything else I may have missed.....
and I've been told to start with the 91 map vs the 93, any particular reason for this as the engine was designed from factory to run 93.....I'm just trying to figure it out.
Thanks,
Gords_zenith is offline   Reply With Quote
Old 02-13-2017, 05:21 PM   #23
Lantana frs
Drives: 13 frs red
It'll be much more linear and enjoyable to drive. It may not feel stronger up top but that's because it won't be climbing out of a hole.
Lantana frs is offline   Reply With Quote
Off the shelf OFT Tune Tomei EL Header speeddemon Software Tuning 3 01-19-2015 08:56 AM
Which off-the-shelf Supercharger would you like to see CSG test? CSG Mike Forced Induction 91 12-20-2013 04:16 PM
Brake Fluid shelf life? VoiD Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-02-2013 06:17 PM
HKS SUPERCHARGERS ON THE SHELF! 3 AVAILABLE SCIONPRO D2BD Motorwerks Forced Induction 7 07-01-2013 01:45 PM
Greddy Intakes and EVo 3 Exhausts on the shelf! D2BD Motorwerks Engine, Exhaust, Bolt-Ons 1 01-31-2013 09:27 AM
