Old 02-03-2016, 02:13 AM   #267
brz11b
Drives: United States
Originally Posted by tyler_win_photo View Post
Yup maxed out front and rear. Just did some quick research and v1 lowers about 20mm and v2 is supposed to lower 60mm. Having that large range of adjustment is always nice to have. On top of that you'll also get more shock travel, something that is especially valuable if you plan to go low.
Awesome brother thank you for you help and information.
brz11b is offline   Reply With Quote
Old 03-02-2016, 12:34 PM   #268
Aev
Drives: 2015 Scion FR-S
Originally Posted by Stance86 View Post
Hi guys, here is my setup.
Enkei RPF1 18x9.5 +38 5x100 SBC lowered on Eibach Sportlines.. no coilovers, was surprised it fit.
Front tyres are 235/40/18
Rear tyres are 255/35/18
No rubbing.... could be lower I know but I do 1,000kms a week..
Are you running any spacers or just the eibach sportline Springs?
Aev is offline   Reply With Quote
Old 04-12-2016, 08:47 AM   #269
aznek888
Drives: 86
Hi guys, so wheel the 18x9.5 enkei epf1s clear sti brembos? Front and rear? Thanks
aznek888 is offline   Reply With Quote
Old 07-10-2016, 07:32 PM   #270
phatroksek
Drives: 2014 Subaru BRZ
black enkei rpf1 18x9.5 wearing bridgestone s-04 pole position 245/35R18
just finished fitting these and went for a test ride; still need to get a balance and alignment.
lowered on Hotchkis springs 1 inch all around, stock brakes.
square set up 245/35 Bridgestone S-04 Pole Positions.
they just cleared the spring perch (<10mm) and fenders seem fine; full lock seems to be ok too
-0.2/-0.5 camber up front assuming things haven't moved since my last alignment
phatroksek is offline   Reply With Quote
Old 07-20-2016, 03:09 PM   #271
Baris
Drives: 2015
Same setup of mine Sometimes want to paint the rims to white but cant decide which one is better...
Baris is offline   Reply With Quote
Old 07-23-2016, 11:38 PM   #272
machewcoy
machewcoy's Avatar
Drives: 2014 Raven FRS
Stance coilovers and SPL lower control arms with 245/35/18 tires
machewcoy is offline   Reply With Quote
The Following 2 Users Say Thank You to machewcoy For This Useful Post:
Hicklinc (02-18-2018), pgranberg11 (02-22-2018)
Old 07-27-2016, 02:23 AM   #273
Baris
Drives: 2015
Kw v3 Coilovers...245 35 18 Pirelli PZero
Old 08-08-2016, 07:23 PM   #274
Jaydemm
Drives: 13' SWP Voltech Supercharged BRZ
I'm running RSR Superdown springs right now and want to pickup some RPF1s
Am i able to run 18x9.5+38 w/ 245/40/18 tires? Or will i be having clearance issues with the stock struts?
I've been told to do 17x9 +35 w/245/40-17 and that would fit perfectly.
Thanks in advance!
Jaydemm is offline   Reply With Quote
Old 08-13-2016, 08:26 PM   #275
brz11b
The Following User Says Thank You to brz11b For This Useful Post:
OAKOS Automotive (09-15-2016)
Old 09-11-2016, 08:21 PM   #276
Maddumpling
Drives: 2016 Subaru BRZ
Thanks in advance!
BUMP
Maddumpling is offline   Reply With Quote
Old 09-11-2016, 09:13 PM   #277
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Originally Posted by Maddumpling View Post
BUMP
For what its worth -- I ran 18x9.5 +38 with 245x35x18 hankook ventus v12 tires and i had to remove ALL negative camber to mount the wheels/tires. With zero camber you could still barely fit a credit card between the struck and the tire.
I wouldn't recommend anything larger than 245x35 on stock struts with a 9.5" wheel. And even then, tire sizes vary by make even for the same size.
ajcarson11 is offline   Reply With Quote
Old 09-11-2016, 10:22 PM   #278
HachiRo
Drives: 2013 White-Out FRS
Thanks in advance!
245 would rub on full lock. It would have to be a bit more stretched than that. If anything, a couple mm or for spacers.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 09-15-2016, 01:11 PM   #279
ModBargains.com
ModBargains.com's Avatar
This looks super dialed, good photo quality too!
ModBargains.com is offline   Reply With Quote
The Following User Says Thank You to ModBargains.com For This Useful Post:
machewcoy (09-18-2016)
Old 09-18-2016, 04:23 AM   #280
machewcoy
machewcoy's Avatar
Thanks!
ft-86 speedfactory
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
