Old 02-02-2016, 12:01 PM   #15
PeterFRS
PeterFRS's Avatar
Drives: FRS
i had to sadly ? swap out the cool rays valves on my te37's to run TPMS in them..
i just can't stand the lights on the dash.. my personal preference..
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 02-02-2016, 12:02 PM   #16
Ashikabi
Ashikabi's Avatar
Take apart dash and cover that light with tape. Or somehow disconnect it
Old 02-02-2016, 12:39 PM   #17
avp1
Drives: Traded BRZ for Supra
they come on when your what 2 PSI low? thats not gona make your tire blow up. If you are a responsible car owner you will check your tires regularly. You will also feel a tire start to go low and if you cant you should not be going 100mph
You will not notice even 8 psi low on the road. At high speed or tight turn it can be enough to destroy tire or rip it off the wheel.
avp1 is offline   Reply With Quote
Old 02-02-2016, 12:45 PM   #18
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I don't know, 8 PSI is a lot but I guess if its just street driving it might be hard to tell. My only flat was a huge chunk of metal so I heard it but I have never drove with pressure that low. 8 PSI low is 22% lower so I would imagine it could be felt.
Old 02-02-2016, 12:46 PM   #19
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Its just a LED you can desolder
Old 02-02-2016, 12:57 PM   #20
EzyBrzy
Drives: 2015 WRB BRZ
After running with a CEL in my last car, I know this light would annoy me lol. How hard is it to take apart the cluster?
EzyBrzy is offline   Reply With Quote
Old 02-02-2016, 01:11 PM   #21
Ashikabi
Ashikabi's Avatar
I've never done it but I'm sure there is a diy. I did it on a 95 del sol and it wasn't too bad. Maybe an hour total labor
Old 02-02-2016, 02:44 PM   #22
avp1
You wll not feel -8 psi. Recently TPS light went on in my wife's truck. I checked pressure and all tires were between 20 and 22 psi. They had to be 30-32. Likely were low for some time but not enough to trigget TPM untill freezing night. I do not want 20 psi in tires when I get into turn at 50 mph (which I commonly do for some fun).
The Following User Says Thank You to avp1 For This Useful Post:
go_a_way1 (02-02-2016)
Old 02-02-2016, 02:49 PM   #23
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah thats a very good point haha, I hit some exit ramps rather fast and would hate to have a tire blow up on me. Atleast I will die doing what I love
Old 02-02-2016, 03:11 PM   #24
churchx
churchx's Avatar
Drives: 2014 GT86
Just 20 psi? Shouldn't tires with pressure that low be visually rather flattened and ride change be rather noticeable to one driving? I'd most probably would have checked pressures way before pressure going down that low. Hence again TPMS wouldn't have done for me anything if it is triggered at such pressure drops.
Old 02-02-2016, 06:28 PM   #25
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
So, PSI is set at 35PSI, so mine triggers around 30 and below but not above 35 PSI.
It's up to you, if you're lazy like me and check it once a week, or OCD or don't wanna take apart your dash for a light.
Do the TPMS if you can afford it, I would.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 02-03-2016, 02:02 AM   #26
avp1
Do not forget thay truck uses 33" tires. You hardly notice change until they are almost flat.
Sent from my GT-I9300 using Tapatalk
Old 02-03-2016, 02:59 AM   #27
SmartedPanda
Funny enough, mine off. Thanks for the jinx.
Went from 35 > 31
Old 02-03-2016, 03:32 AM   #28
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
None of the Twins come with TPMS in AU. Actually now that I think about it... I don't think even most of our Luxury Euro's come with them either.
Unless the system actually displayed the individual pressure in each wheel I don't see the point.
I can easily feel a difference of 2 PSI or so lower than the usual 35. I just make it a routine to check oil and tire pressure every two weeks when I fill up.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
TPMS Sensors kanundrum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 249 06-21-2019 05:22 AM
TPMS Sensors - What to Buy? Stang70Fastback Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-31-2016 02:01 PM
WTB: TPMS sensors raven1231 Want-To-Buy Requests 0 06-03-2015 05:28 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 09:25 AM
