Old 07-10-2015, 01:54 AM   #99
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
If this wasn't meant to be a 4th brake light then why is there a "lock and unlock" indicator right above the 4th brake light just like the reverse lights ?
Young_makaveli is offline   Reply With Quote
Old 08-09-2015, 04:14 PM   #100
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by ZILLA View Post
I ran the (+) wire from each 194 bulb to the driver side tail light harness. The green wire is the regular tail light. The red wire is the brake light. The ground wires went to the OEM ground location in the trunk.
FWIW, I just redid the wiring for the rear fog on my car, and the green was the brake, and red was the parking light.
Old 08-12-2015, 03:03 PM   #101
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Attachment 114665
Because it's meant to be a fog light.
headlikeahole is offline   Reply With Quote
Old 01-31-2016, 08:55 PM   #102
PresiO.
Drives: 2013 Scion Fr-s
Can anyone tell me the wiring for the frs? it seems to be different.
PresiO. is offline   Reply With Quote
Old 01-31-2016, 09:03 PM   #103
NahumCC
Drives: 2013 FR-S 10 Series
I know it doesn't make sense when you look at the wiring colors and what you would expect them to represent but trust me. I stopped during the project I took this in and had to keep reorienting my self to the pages in the repair manual referenced (which you can download from the DIY section).
NahumCC is offline   Reply With Quote
Old 01-31-2016, 11:52 PM   #104
PresiO.
Is it the same with the jdmtoy one? or whatever its called? @NahumCC
Old 02-01-2016, 12:12 AM   #105
NahumCC
Should be if your referring to the JDMtoy version of the Valenti rear light bar.
Old 02-02-2016, 10:45 AM   #106
frslee
Just drive it
Drives: 13' FR-S
Make sure to spray penetrating oil on the 2 10mm bolts holding the light housing. Mine was rusted badly and it broke.
frslee is offline   Reply With Quote
Old 02-03-2016, 02:18 AM   #107
PresiO.
what kind of sealant dd you guys use? if you did seal it up?
Old 02-20-2016, 10:55 AM   #108
eggncheese
Drives: 2013 Ultramarine Scion FRS MT
Silicone RTV adhesive sealant. Gonna be a bitch to get off, but I can be damned sure no moisture is getting in.
Anyone try this with an 1157 socket and bulb?
eggncheese is offline   Reply With Quote
Old 02-21-2016, 10:57 AM   #109
twag4
Drives: frs
Look at post number 4 on first page of this thread. I just happened to go back to original post to see how this has evolved and saw that, after having just read your post.
twag4 is offline   Reply With Quote
Old 02-21-2016, 06:13 PM   #110
eggncheese
Yes, I saw that. I should've specified more. Has anyone tried this with an 1157 LED bulb? I've got parts on order. Just seeing if anyone else has opinions or views on this route.
The Following User Says Thank You to eggncheese For This Useful Post:
twag4 (02-21-2016)
Old 03-01-2016, 03:34 PM   #111
eggncheese
Just wired mine up
Wired mine up using an 1157 red LED, I think it came out pretty nice.
Here's the LED in the socket I purchased.
And a poorly lit picture of the assembly
And finally, the result!
[ame="https://www.youtube.com/watch?v=1Ly49mnnjSg"]4th Brake light LED test - Scion FRS - YouTube[/ame]
I like it and I think it will look good. When the signal for brake signal comes in the light becomes brighter as expected (the camera had to readjust its exposure to compensate for the increased light output). I'm running the diode dynamics tail-as-turn module so I dont even think I'll need brake signal wire, but I'm going to leave it there in case I decide to switch it up.
For those worried about an 1157 getting hot:
Primarily, I used an LED... so it's only going to get but so hot. I did use a pretty beefy LED though. I used a 7W Cree LED that has a pretty big heat sink near the top of the bulb. To make sure this was going to be safe to run for a long period of time I ran a test. I took the temperature of the LED before it went in the assembly, and then I periodically checked the temperature of the heat sink over the course of 30 minutes.
Starting Temperature: 73F
After 10 minutes: 101F
After 20 minutes: 115F
After 25 minutes: 120F
After 30 minutes: 118F
It seemed to reach a max of 120F and stay close to that number. I could pick it up with my hand and handle it normally after 30 minutes. It wasn't very hot at all, just warm. For reference, I measured the temperature of a finger I didn't use to handle the LED and it read 89F. All in all, no need to worry about a melting housing
Old 05-22-2016, 01:41 PM   #112
Hi_Psi
GotBoost?
Drives: 2013 Raven Pearl (D4S) GT86
Did it, took about 2hrs to do, simple write up, for those who have a frs if i remember correctly red wire is for light to be on and green wire is for brake light
Hi_Psi is offline   Reply With Quote
custom, fog, fog light, foglight, rear fog light
How-To: Remove Rear Deck & Third Brake Light Moshpit37 DIY (Do-It-Yourself) Guides 63 08-01-2020 09:48 PM
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 02:47 PM
Third brake light out? Longhorn248 BRZ First-Gen (2012+) — General Topics 21 11-23-2015 03:23 PM
The third brake light looks like a car! Longhorn248 BRZ First-Gen (2012+) — General Topics 12 06-06-2012 07:14 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
