Old 01-27-2016, 12:56 PM   #407
kch
Senior Misanthrope
kch's Avatar
Originally Posted by ort895 View Post
So i see this kinda died, updates?
It turns out the stock intake manifold is pretty good, so it seems most shops are deciding it isn't worth it to develop a new one. Sure, there are small gains to be had, but I don't think they're worth the predicted cost.
Old 01-27-2016, 04:25 PM   #408
ort895
ort895's Avatar
Damn, that really sucks. Im wondering if the FA20 is pretty maxed out or it just needs more time for R&D
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 01-31-2016, 09:23 AM   #409
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I should be done by spring
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 5 Users Say Thank You to spitfire481 For This Useful Post:
DocWalt (01-31-2016), Kiske (01-31-2016), Lonewolf (02-21-2016), raven1231 (01-31-2016), WhiteRose (04-13-2016)
Old 01-31-2016, 11:20 AM   #410
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Grind down the oil filter ring? Does it clear it or still hit?
Old 01-31-2016, 11:35 AM   #411
spitfire481
Drives: 2JZ FRS
Once the turbo is clocked the way it should it will have a small gap
MoTeC
Build Thread
@spitfire481
Old 02-21-2016, 06:44 AM   #412
Mike Brz
NA results please.
Would be nice to have a dyno comparison of stock vs powerblocks vs this manifold.
Keep up the good work
Mike Brz is offline   Reply With Quote
The Following User Says Thank You to Mike Brz For This Useful Post:
ort895 (02-21-2016)
Old 02-21-2016, 11:24 PM   #413
ort895
ort895's Avatar
Originally Posted by Mike Brz View Post
NA results please.
I would also be interested in the sound it would produce (if very noticeable at all)
Old 02-22-2016, 09:20 AM   #414
Kris86
Kris86's Avatar
Drives: RHD Gt86
cant wait to hear this monster
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 11-19-2016, 07:23 AM   #415
Bobster
Drives: GT86 GTS
Interested in NA result too
Bobster is offline   Reply With Quote
Old 11-19-2016, 10:53 AM   #416
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
You'll be wating a long time. The only ones buying this are people going after big power. The 2017 Manifold is 1/2 the cost. It is more of a blend of of the stock intake and this design. The reports people are getting from it in N/A form are tiny gains to top end and a tiny loss to the bottom end. This manifold will only make it worse without boost. If it wasn't I'm sure LJ would have posted a dyno or something by now as that would have been a huge selling point.
The Following User Says Thank You to Kiske For This Useful Post:
D_Thissen (11-19-2016)
Old 11-19-2016, 01:41 PM   #417
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Get BPB if you want manifold work. I have them, doesn't add a lot to the peak, but adds to the midrange and shifts the powerband left, giving you power earlier and reduces the torque dip a little. Because of the powerband shifting left, you won't make much power around 7k, but you'll get it around 6.5k instead.
"Chasing speed with patience"
MurderousPandas is offline   Reply With Quote
Old 01-25-2017, 12:15 PM   #418
rikixass
rikixass's Avatar
Has anyone picked this up?
rikixass is offline   Reply With Quote
Old 08-10-2017, 11:52 PM   #419
chazmuska
chazmuska's Avatar
Drives: 2014 Scion FR-S
bump
chazmuska is offline   Reply With Quote
Old 10-23-2017, 11:51 AM   #420
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
This looks very similar to '17 86 stock intake manifold.
Lakitu is offline   Reply With Quote
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold cover protpibe Engine, Exhaust, Transmission 16 02-28-2014 06:44 PM
Wanted intake manifold ciro Want-To-Buy Requests 0 09-27-2013 12:03 PM
Aluminium intake manifold? Hempo Engine, Exhaust, Transmission 18 06-27-2013 01:19 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
