| Software Tuning Discuss all software tuning topics. |
Drives: GT86
Help on OFT Missing tables
Need help about missing tables on OFT A01J roms including engine load limits A, B, and C; all tables on Per injector pulse width; Requested torque base (RPM) and others were mostly DTC tables on the A01J rom compared to G roms. What to do to have some of these tables?
#3 |
Drives: GT86
thanks steve. Would PM be enough?
#4 |
Drives: FT86
#5 | |
Drives: FT86
try this romraider def https://raw.githubusercontent.com/TD...R_ZA1JA01J.xml just be carefull if your editing an oft rom with this def as it wont have lc\ffs parameters. i belive that A01J is latest compatabe rom so the oft rom shoul be A01J internally , but carefully look at the tables if anything looks weird dont edit |
#6 |
Drives: GT86
steve, sorry im kinda new to definition... the link you gave me only showed a page with text showing address of the tables. What am I supposed to do bout it? or is there a software to use these address ?
#7 | |
Drives: FT86
in your browser click "save page as" I should then dowload and save a a file called RR_ZA1JA01J.xml that file is your definition file copy it from the download directory to where you store your romraider definitions point romraider to that definition file |
#8 |
Drives: GT86
thanks steve.. ive done it but still no load limits per RPM.. only maximum load limit which is set to 4g.
#9 | |
Drives: FT86
#10 | |
Drives: 86
- Requested torque base (RPM) for A01G - missing DTC tables for A01J - engine load limits for A01G - injector pulse width A01G |
#11 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
I've inserted the load tables, and the tables referenced above into the definitions on Github. aagun - which injector pulse width tables - the ECT comps? Those are in there.
#12 |
Drives: GT86
hello Td-d, im from asia and with cal id ZA1JA01J, using the only available definition which is RR_ZA1JA01J. compared to A01G about 40+ missing tables like :
I noticed all these tables are missing on A01J definition/OTS map but present on A01G definition/OTS map. Per injector pulse width compensation A to H Engine load limits B & C maximum (RPM) Idle speed target G MAF correction after start (in gear) & (neutral) Overrun fueling cut counter RPM threshold AF 3 CL Target compensation limits AF 3 correction limits CL delay maximum engine speed (Per Gear) others were DTC codes Is there a way to add these tables on A01J ? Last edited by j.boy; 01-30-2016 at 05:15 PM. |
#13 |
Hi j.boy - I've just checked my definitions on Github, and all those tables, except for CL delay maximum engine speed (Per Gear) and DTC codes are already defined.
Guys - please understand something - if you're using the OFT definitions, great - but it's not up to me to maintain those definitions, I don't work for OFT. I define these roms as part of the Romraider open source project for all to use - I have no issue with OFT using RR as the platform, but if they are missing tables, or have not been updated - it's up to you to check on Github for the latest versions - or to ask Shiv to update them. I'll update the missing DTCs on Github. |
#14 |
Actually, CL Delay Maximum Engine Speed Per Gear is also defined. So outside of the fact that the DTC list was updated (and expanded) some time after this definition was completed - it is complete.
| Pool Tables? | Nevermore | Off-Topic Lounge [WARNING: NO POLITICS] | 37 | 03-01-2016 01:03 PM |
| Misihimoto Intake Tables for Rom Raider | efactor84 | Software Tuning | 7 | 08-07-2015 05:39 PM |
| OFT E85 Tune w/ Modifed MAF tables | SpeedFromSwede | Software Tuning | 2 | 02-18-2015 09:25 AM |
| Coffee Tables? | ZionsWrath | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 10-20-2014 03:51 PM |
| Can DBW tables be changed via Ecutek tune??? | Norkoastal | Engine, Exhaust, Transmission | 1 | 09-11-2012 06:51 PM |
