Old 01-26-2016, 05:47 PM   #3473
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Originally Posted by 636 View Post
I wish I knew..I just started drilling until I felt both sides looked right, haha.
Turned out it was perfect, with both at -6.2.
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
The Following User Says Thank You to AznKirby For This Useful Post:
636 (01-26-2016)
Old 01-26-2016, 06:03 PM   #3474
636
636's Avatar
Drives: '23 CWP BRZ
Originally Posted by AznKirby View Post
yolo right? haha
636 is offline   Reply With Quote
Old 01-28-2016, 02:30 PM   #3475
Charky
Charky's Avatar
Drives: Fr-s 2013 Hot Lava
If you plan on going low, you're going to need much more than 3 degrees of camber up front with those offsets. You'll probably need to notch the coils. I know I did. I also suggest dropping down to a 35 series tire, as I had no rubbing issues with 225/35.
I've ran a few different setups around those specs.
17x10 +15 with 215/45/17, had to run -6.2 degrees up front. Rubbed inside on full lock, and over bumps, but it was no problem.
I've also run 18x10 +25 with 225/35. Absolutely 0 rubbing issues up front, and only had to run around -4.5 degrees to fit nicely. I would still be on this setup if my rear tires didn't separate from rubbing on something on the inside, haha.
Currently setting up some 25mm spacers and going to be running 18x9.75 +11 all around, with 225/35, so we'll see how that turns out.
Your car so sexy
Charky is offline   Reply With Quote
The Following User Says Thank You to Charky For This Useful Post:
636 (02-01-2016)
Old 01-28-2016, 05:13 PM   #3476
frznBRZ
Drives: 2015 BRZ Ltd
One more question! So I see a lot of RLCA for sale on FRS/BRZ parts sites, but not many RUCA for sale.
Which control arm is more recommended in order gain some extra camber in the back? I see the Stance LCA's can get you up to -6 degrees, but is an LCA "better" than an UCA for our cars? Or are both control arms sorta interchangeable?
I used UCA's on my last car to gain camber...but for the FRS/BRZ UCA's seem hard to find.
frznBRZ is offline   Reply With Quote
Old 01-29-2016, 01:20 AM   #3477
swarb
UCA take a lot of time to adjust and a alignment guy would also probably charge extra.
LCA is the way to go. Any brand will do if you don't need more than 4 degrees or so of correction.
Old 01-29-2016, 05:55 AM   #3478
gMit
Drives: Pearl BRZ
Hate to ask, what wheels and setup is that?
IMO that is the best setup I've ever seen and would love to replicate.
gMit is offline   Reply With Quote
Old 01-29-2016, 08:29 AM   #3479
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
http://www.nlmotoring.com/XXR-521-Wh...p/52180803.htm
Old 01-29-2016, 01:06 PM   #3480
Cole
Not a troll
Cole's Avatar
lol, worshiping replica wheels and wanting to bite that rep steeze.
Cole is offline   Reply With Quote
The Following 6 Users Say Thank You to Cole For This Useful Post:
AznKirby (02-12-2016), Chrisgalactic (05-03-2016), DavidBob (03-11-2016), dobbrz (02-02-2016), Josue Cafe FR-S (06-13-2016), Kuzuri (02-12-2016)
Old 01-29-2016, 01:45 PM   #3481
frznBRZ
@swarb thanks for the information!
Do you (or anyone) happen to know how many degrees we can get out of the rear suspension with just coilovers? I have BC "ultra low" coilovers that I'm going to be installing. (I know I have a million questions )
Old 01-29-2016, 02:07 PM   #3482
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Finally put some meat for the rears. 18x9.5 57xtremes with 255/35 MPSS
Instagram: trevor.parque
frznBRZ (02-10-2016)
Old 01-29-2016, 05:24 PM   #3483
gMit
Drives: Pearl BRZ
By all means, let me know the name of the real ones
Old 01-29-2016, 05:30 PM   #3484
NyC Zn6
NyC Zn6's Avatar
Mesh style so BBS LM or Work VS-XX
The Following User Says Thank You to NyC Zn6 For This Useful Post:
Kuzuri (02-12-2016)
Old 01-30-2016, 09:48 PM   #3485
DIM
Finally got some new shoes for it! Enkei RS05RR's wrapped in MSS 265/35.
DIM is offline   Reply With Quote
The Following 3 Users Say Thank You to DIM For This Useful Post:
Josue Cafe FR-S (06-04-2016), JRRIII (04-18-2016), number1Tango (01-31-2016)
Old 02-05-2016, 06:29 PM   #3486
pokemonphil
Drives: Boring
[IMG]http://img.photobucket.com/albums/v464/speedstarrps13/C***0056-9CC5-4FFE-9A65-395EFEC0F4BC_zpslealy1yw.jpg[/IMG]
instagram : pokemonphil
pokemonphil is offline   Reply With Quote
The Following 9 Users Say Thank You to pokemonphil For This Useful Post:
636 (02-05-2016), cfig21 (02-08-2016), danny_d19 (04-30-2016), GT 86 Brah (04-04-2016), JellyForSale (02-06-2016), Josue Cafe FR-S (06-04-2016), lukey86 (02-09-2016), RSKYBZ (06-25-2016), stancypants (02-29-2016)
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
