Old 01-21-2016, 10:12 AM   #3459
GT 86 Brah
u aware?
GT 86 Brah's Avatar
Drives: it like a turtle.
GT 86 Brah is offline   Reply With Quote
Old 01-21-2016, 02:45 PM   #3460
frznBRZ
Drives: 2015 BRZ Ltd
Hey guys, I am looking to run 18x10 in the front and 18x10.5 in the rear on my 2015 BRZ. I will be running BC ultra-low coilovers. I just have a few questions (specs and tire sizes I am considering are listed after the questions):
1. How difficult is it to fit a 10 inch wide wheel in the front? I daily my car, so I would like to able to turn my wheel to full lock. I am also not too interested in notching my coilovers. I know I can get about -3 degrees of camber in the front from my coilovers, but would adding camber bolts be enough to help me fit the 10 inch wide wheel without issues? Would I be better off sticking with a 9.5 inch wide wheel up front based off my concerns?
2. I like the fitment on the FRS below (it’s 18x10.5 all around, offset unknown by me). But I’m unsure of what offsets to run to achieve something around this look in 10 inch and 10.5 inch wide wheel. Any ideas?
Currently I was thinking of running somewhere around these specs, can you let me know if the look will be similar to the FRS in the picture below?
F: 18x10 +15 (thinking 225/40 tire)
R: 18x10.5 +20 (thinking 225/40 tire) (not sure if my offset is too high to achieve the look with this one…)
If the 10 inch wide wheel in the front isn’t doable, I was thinking of the specs below:
F: 18x9.5 +15 (thinking 205/40 tire)
R 18x10 +10 (thinking 225/40 tire)
frznBRZ is offline   Reply With Quote
Old 01-22-2016, 03:03 AM   #3461
636
636's Avatar
Drives: '23 CWP BRZ
If you plan on going low, you're going to need much more than 3 degrees of camber up front with those offsets. You'll probably need to notch the coils. I know I did. I also suggest dropping down to a 35 series tire, as I had no rubbing issues with 225/35.
I've ran a few different setups around those specs.
17x10 +15 with 215/45/17, had to run -6.2 degrees up front. Rubbed inside on full lock, and over bumps, but it was no problem.
I've also run 18x10 +25 with 225/35. Absolutely 0 rubbing issues up front, and only had to run around -4.5 degrees to fit nicely. I would still be on this setup if my rear tires didn't separate from rubbing on something on the inside, haha.
Currently setting up some 25mm spacers and going to be running 18x9.75 +11 all around, with 225/35, so we'll see how that turns out.
636 is offline   Reply With Quote
Old 01-22-2016, 04:36 AM   #3462
Futaba
Futaba's Avatar
Drives: GT86
With added passive aggressive store naming.
Futaba is offline   Reply With Quote
Old 01-22-2016, 11:09 AM   #3463
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Tried quoting you frznBRZ but it won't let me for some reason...
Im running 18x10 +25 on Extreme Lows with the camber plates maxed out
IG: @dustin_faulkner
Kuzuri is offline   Reply With Quote
Old 01-22-2016, 11:19 AM   #3464
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
Interesting look without the front grill. Loving it!
Kestrel is offline   Reply With Quote
Old 01-22-2016, 11:20 AM   #3465
frznBRZ
Hey @636 thanks for the response. Maybe I will run a 215/40 on the 10 up front. Do you have a picture of where exactly you notched your coilovers to fit the 10 upfront?
You don't think running the -3 degrees from the camber plates plus camber bolts will do the trick up front?
I'm going to order custom 3 piece wheels, so I don't want order them and be stuck with wheels I can't daily without issues. The reason why I would like to fit a 10 upfront is because I could run a bigger lip.
do you have anymore pictures of your car on that set up when it was white on the 18x10 +25?
Old 01-22-2016, 06:32 PM   #3466
636
636's Avatar
Drives: '23 CWP BRZ
It's all dependent on how low you wanna go.. If you wanna max out and be as low as possible, then nah, I don't think camber plates + bolts will be enough. All I did was notch the top hole of the strut so I could push the whole assembly in further. Same concept as running a smaller bolt in the top hole.
Old 01-24-2016, 02:45 AM   #3467
JDR86
JDR86's Avatar
Drives: FRs WhiteOut
Had a quick question I'm not sure if this is the right place to ask. But I'm looking at some nice wheels just to give my car a little bit a better look. They are 17x9 wheels on 215/45/17 Hankook Ventus HRII. They do look a little too stretch to my liking but will I have any problems if I do decide to get these wheels. The guy is selling them at a pretty good price so I kinda want to buy them and used them for a while then get a wider tire like a 225/45 or 245/40. Also I must add that my car is dropped on TRD springs. This car will just be my Daily so I won't be doing Autocross or anything in that matter. Sorry if this isn't the place for it. Just need some help.
JDR86 is offline   Reply With Quote
Old 01-24-2016, 12:20 PM   #3468
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Here's a pic of mine 17×9 on 235/40 still on stock suspension to give to an ideaName:  uploadfromtaptalk1453656051439.jpg
Size:  101.6 KBName:  uploadfromtaptalk1453656063617.jpg
Rican_D is offline   Reply With Quote
Old 01-24-2016, 05:56 PM   #3469
Brndn704
Brndn704's Avatar
Brndn704 is offline   Reply With Quote
Old 01-25-2016, 04:51 PM   #3470
frznBRZ
@Fancy, thanks for the response, your car is too fresh! do you have issues with rubbing? Is your set up square?
@636 thanks for the extra pics, That set up looks nice. i just took a look at my front coils and it doesn't seem like notching them would be too horrible of task. About how much bigger did you make the top hole?
Originally Posted by Brndn704 View Post
*pic*
@Brndn704 your car is so nice, love the wheels!
Old 01-26-2016, 12:16 PM   #3471
636
636's Avatar
Drives: '23 CWP BRZ
I wish I knew..I just started drilling until I felt both sides looked right, haha.
Turned out it was perfect, with both at -6.2.
Old 01-26-2016, 02:43 PM   #3472
frznBRZ
okay cool thanks!
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
