Old 01-28-2016, 03:02 PM   #1
jay07631
Drives: 2016 Subaru BRZ Limited Black M/T
New 2016 Limited M/T questions
You guys were pretty helpful on my last question. After some searching, I'm hoping some 2016 owners can help again.
So I got a Black limited 2016 M/T after trading my 2013 DGM M/T. And there are some nice changes, but I am have some issues/questions/problems.
The footwell light are cool, but is there a way to turn them off.
Wanted to get a front offset license plate holder. any suggestions?
Cant seem to get bluetooth audio to work. phone works. some of the apps work, like starlink and aha.
Is it worth it to get a K&N drop in filter ?
Thanks.
jay07631 is offline   Reply With Quote
The Following User Says Thank You to jay07631 For This Useful Post:
2013GTRNate (02-04-2016)
Old 01-28-2016, 03:13 PM   #2
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
I dont know about the footweel lights, those are optionals so not everybody has them.
Perrin front plate re locator is a great choice
Yes, the k&n drop in filter is great. That was my first 'mod'.
Jfheisenberg is offline   Reply With Quote
Old 01-28-2016, 04:00 PM   #3
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
I have the Perrin plate relocate. The GrimmSpeed is good too... I honestly think the GS looks more solid.
Bluetooth audio is as easy as hitting the source selection and selecting Bluetooth Audio. If it isn't working, it's either your phone or your head unit fucking up. Maybe try deleting the phone in Bluetooth and pairing it again.
If I remember right, a drop in filter is the best intake mod you can do to these.
Luftwaffel is offline   Reply With Quote
Old 01-28-2016, 04:15 PM   #4
ed_423
ed_423's Avatar
Drives: 2016 BRZ Limited
I can take care of your footwell light problem by taking it off your hands
ed_423 is offline   Reply With Quote
Old 01-28-2016, 04:28 PM   #5
Mmmankey
Mmmankey's Avatar
Drives: Subaru BRZ Series.HyperBlue
I will chime in about the Bluetooth Audio. Its slow and sometimes inconsistent. For me it takes about 30 seconds after the car starts up to finally pair with my phone. It will also cut out sometimes for maybe half a second then come back in. It also only shows the first song that was played and does not update after that. As Luftwaffel said try restarting the syncing process and maybe that will fix the issue. The rest of the "infotainment" system works well it just seems a tad slower than some of the other systems out there.
Mmmankey is offline   Reply With Quote
Old 01-28-2016, 04:59 PM   #6
kch
Senior Misanthrope
kch's Avatar
If you're just looking to avoid drilling the front bumper, I can recommend the below DIY:
http://www.ft86club.com/forums/showthread.php?t=35261
Old 01-28-2016, 05:42 PM   #7
menikmati
Drives: 2015 BRZ, 2005 STI
Thanks.
Footwell lights cannot be fully shut off, they are connected to the brightness dial of the interior gauges. You can disconnect them at the LED bulb. The main wiring harness for them is behind the head unit.
I use the Grimmspeed license plate relocation without any problems.
Once you go through the initial Bluetooth setup with your device, it should auto-connect if you have that setting enabled.
menikmati is offline   Reply With Quote
Old 01-29-2016, 04:54 PM   #8
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
I know how you feel about the footwell light! My car came with blue ones, and I didn't even know I had it till I got home after I picked it up. To make my eyes comfortable at night, I had to turn down the brightness of the gauges, but then I couldn't really see the gauges! I tried to live with it for a while, but I ended up taking them off after a week or so. They're plugged into a harness behind the radio, I ended up completely removing the wires, but the plugs were still there.
PERRIN_Chris is offline   Reply With Quote
Old 01-29-2016, 05:04 PM   #9
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
some phone audio players have an option under the menu for strict mode 'to help with some car audio systems'. If you have that option try it.
if you are having trouble pairing; welcome to the club.
Aftermarket head unit seems the only answer.
I gave up and I use an aux cable.
GeorgeJFrick is offline   Reply With Quote
Old 01-29-2016, 07:28 PM   #10
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Just get the Perrin filter and plate locate at the same time.
Instagram: stimson
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
PERRIN_Chris (01-29-2016)
Old 01-29-2016, 11:15 PM   #11
purearsenal
purearsenal's Avatar
Yup for sure this, annoying as hell.
purearsenal is offline   Reply With Quote
The Following User Says Thank You to purearsenal For This Useful Post:
Mmmankey (01-30-2016)
Old 02-02-2016, 11:50 AM   #12
jay07631
Thanks for the feedback. Was looking at the Perrin License Plate Relocation Kit, how is this thing in a car wash ? Also, I finally got the radio bluetooth to work. thx.
Old 02-02-2016, 12:33 PM   #13
tobin
tobin's Avatar
Drives: '13 BRZ
The easiest way to turn off the footwell lights is to unplug the connectors by the lights themselves. The connectors are a few inches of wire away from the lights and wrapped in adhesive foam tape. Peel the tape off and unplug the connection. I have blue ones in my '13 and hated them.
tobin is offline   Reply With Quote
Old 02-02-2016, 12:39 PM   #14
PERRIN_Chris
Just like any plate relocate, I wouldn't recommend going through a car wash with our kit. I've seen a few mangled after going through a car wash!
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
acetothermus (02-02-2016)
2016 Limited vs Premium ADRNLNE BRZ First-Gen (2012+) — General Topics 48 01-31-2016 10:03 PM
2016 BRZ LIMITED A/T QUOTE bobka7914 BRZ First-Gen (2012+) — General Topics 30 10-10-2015 09:54 PM
Brand new 2016 BRZ and first manual car -- some questions and concerns SamuelDev BRZ First-Gen (2012+) — General Topics 35 09-11-2015 09:41 AM
2016 BRZ (Premium, Limited, HyperBlue) Pricing Announced Veloist BRZ First-Gen (2012+) — General Topics 40 09-03-2015 03:42 PM
I have so many questions about the BRZ Limited sound system TouchMyHonda Electronics | Audio | NAV | Infotainment 26 02-20-2014 12:49 PM
