Old 01-27-2016, 03:41 PM   #15
ivtaku7
ivtaku7's Avatar
Drives: 2015 Ultramarine FRS
You'll have enough camber adjustment with the adjustable lower mount.
I generally recommend rear LCAs since I'm a little picky about alignment.
- Andrew
Thanks! Myles basically just answered the same question via email, I just didn't have the patience so I made a post
ivtaku7 is offline   Reply With Quote
The Following User Says Thank You to ivtaku7 For This Useful Post:
Racecomp Engineering (01-27-2016)
Old 01-27-2016, 04:43 PM   #16
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Originally Posted by Lynxis View Post
When you lower by more than an inch, bump steer/roll center correction kits become a good idea.
I don't mean to de-rail this thread, but could you give me your thoughts on bump/steer roll-center correction? I've been considering various bushing correction kits as I'm on tein flex Z coilovers, running 1.7" drop (-2.6 camber all around). Interested in gaining some steering weight back, as well as return-to-center.
ajcarson11 is offline   Reply With Quote
Old 01-27-2016, 05:43 PM   #17
ivtaku7
ivtaku7's Avatar
Derail away! I'm interested in the bump steer kit myself. Not sure it's worthwhile between 0-1" of lowering, but who knows I may go lower than 1"
Old 01-27-2016, 05:53 PM   #18
ajcarson11
Prior to coilovers I did have 1" lowering springs on stock struts. I can confirm that the steering still felt similar to stock weight, and the ability of the steering wheel to return to center after a turn felt nice. After coilovers, I almost have to 'guide' the steering wheel back to straight, presumably due to the drop.
I'm a research kind of guy, and I don't mind researching the correction (caster?) methods for this, but thought i'd ask here first.
Old 01-27-2016, 06:00 PM   #19
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Unfortunately, I'm not knowledgeable enough nor do I have any experience with the kits so I don't really know and am just parroting what others have said about it. Maybe more knowledgeable people can talk about it?
Lynxis is offline   Reply With Quote
Old 01-27-2016, 06:05 PM   #20
ansibe
Drives: White BRZ
It sounds like you lost caster. Did you have that checked? I wasn't aware caster is reduced with a drop. Anyone?
ansibe is offline   Reply With Quote
Old 01-27-2016, 06:18 PM   #21
ajcarson11
I've just had a motorsports shop align the car twice (steering wheel was off-center after first alignment for some reason). I've got the alignment specs... Will post when I get home.
The Following User Says Thank You to ajcarson11 For This Useful Post:
sam69 (01-27-2016)
Mighty Car Mods - Coilovers VS Tyres Mim FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 07-14-2015 07:47 AM
Tires or Coilovers Mighty Car Mods zman Off-Topic Lounge [WARNING: NO POLITICS] 4 07-09-2015 08:40 PM
Suspension Geometry einrejosh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 02-13-2015 07:16 PM
Questions on Suspension Geometry Zach3794 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-02-2013 10:53 PM
