Old 01-22-2016, 12:14 AM   #267
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Originally Posted by sw20kosh View Post
It is not the same. A turbo wastegate vents exhaust gas slowing the rate of spin of the turbine/compressor. This in turn controls boost.
Venting the boost pressure in a supercharged setup doesn't control the spin of the compressor. The compressor spin is directly proportional to engine speed.
My bad, got confused with blow off valves.
Old 01-22-2016, 10:49 AM   #268
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Not the same, but similar results. More wasteful? Absolutely. Still effective though.
If you wanted to limit to 9 psi, you could achieve this with a wastegate. Your blower will still be spinning at the RPM for, say, 12 psi, but you'd only have 9 psi of manifold pressure. The remaining pressure would just be bled off.
xsnapshot is offline   Reply With Quote
Old 01-22-2016, 04:29 PM   #269
CSG Mike
CSG Mike's Avatar
Originally Posted by PandaSPUR View Post
So you're saying I'd be safe with HBP setup on stock engine (+ supporting mods listed in OP) running on 91-93 octane? Then if I want to go track it, I could just bring some fuel additive to achieve 100 octane and get more power safely?
My main concern is keeping the car safe and reliable on the streets, even when I decide to do some near redline passes on the highway >_>
Octane boosters DO NOT WORK.
You need real race fuel, or ethanol, to safely run the HBP.
DO NOT run it with 91. 93 is useable, if you have an excellent tuner, but again, we do not recommend it to be safe.
Old 01-22-2016, 11:31 PM   #270
PandaSPUR
PandaSPUR's Avatar
Hm I was looking around and even on these forums people seem to believe additive from Torco works.
But damn... No E85 thats easily accessible for me, and some gas stations dont even have 93 -.-
Looks like its best for me to stick with the stock pulley.
Old 01-23-2016, 12:17 AM   #271
CSG Mike
CSG Mike's Avatar
Torco Accelerator will prevent knock, yes, but using real race fuel is a cheaper solution in the long run.
Old 01-23-2016, 12:45 AM   #272
PandaSPUR
PandaSPUR's Avatar
I wish E85 was easily accessible in NYC T_T
Gotta trek out to long island or bronx (so like.. 20-30miles+ from my house) just to get it.
Real race fuel isnt any easier to get either. So I guess I'll stick to the normal pulley which will give me like.. 250-280WHP depending on other mods from what i understand.
Old 01-23-2016, 01:17 AM   #273
CSG Mike
CSG Mike's Avatar
You can always order 55gal drums
Old 01-23-2016, 01:39 AM   #274
PandaSPUR
PandaSPUR's Avatar
Lmao, the thought has crossed my mind, but keeping 55gal drums in my NYC apartment sounds like asking to be burned alive.
Old 01-23-2016, 08:39 AM   #275
LS1M
Drives: 2015 BRZ
Has anybody looked into making your own ethanol? Same process as moonshine, and I think you can get a permit for "alternative fuels" to stay legit. Might be a lot of work for not much fuel, though.
LS1M is offline   Reply With Quote
Old 01-23-2016, 04:53 PM   #276
Bykov
Drives: 2014 Monogram FR-S Whiteout
The yield on making your own is actually pretty good. I think one bushel of corn gets you a liter IIRC. The equipment just takes up a decent amount of space in your garage. When I retire I am planning to make it a hobby to grow my own fuel.
Bykov is offline   Reply With Quote
Old 01-23-2016, 05:14 PM   #277
juliog
juliog's Avatar
Drives: 86
juliog is offline   Reply With Quote
The Following 6 Users Say Thank You to juliog For This Useful Post:
Bykov (01-28-2016), CSG Mike (01-24-2016), Jackson Racing (01-25-2016), LS1M (01-23-2016), PandaSPUR (01-24-2016), ScionOfHorus (01-23-2016)
Old 01-23-2016, 05:27 PM   #278
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Of fuckin course the Simpsons did it first
Sent from my MotoE2(4G-LTE) using Tapatalk
ScionOfHorus is offline   Reply With Quote
The Following User Says Thank You to ScionOfHorus For This Useful Post:
Old 01-24-2016, 02:56 AM   #279
CSG Mike
CSG Mike's Avatar
E100 is very, very difficult to start a car on. E98 is common as a race fuel though.
I do, however, have access to lab grade E100, and it smells literally like corn.
Old 01-24-2016, 03:17 AM   #280
PandaSPUR
PandaSPUR's Avatar
Haha I think he photoshopped that :p
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 09:26 AM
Why no high rpm boost for Phantom ESC? stevo585 Forced Induction 11 02-11-2014 07:51 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
