Old 01-19-2016, 09:30 PM   #1
Sw33tm1x
Sw33tm1x's Avatar
Drives: 2014 Subaru BRZ
Help! Coilovers squeaking
I've had Fortune Auto 500 coils with the radial bearing upgrade installed on my car for approx 8000kms and recently, I noticed that my passenger rear squeaks when it rebounds. Any thoughts? Is there some sort of maintenance I should be doing?
Sw33tm1x is offline   Reply With Quote
Old 01-19-2016, 10:49 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
You wont have radial bearings on the rears FYI. I would check to see that the dust boot isn't tore and dust isn't getting in. While your out there also check to be sure everything is tight. Best part about FA is you can actually reach them on the phone. Give them a call tomorrow and talk with them. You have a 1 year warranty on consumables and 5 years on hard parts. Worst case scenario you can send it in for a rebuild (but you should have warranty still)
Old 01-20-2016, 01:05 PM   #3
Sw33tm1x
Sw33tm1x's Avatar
Ok, thanks for the input. I can't check it out until the weekend due to work and such though. After listening to it again, it's actually when it's being compressed that it creaks.
The Following User Says Thank You to Sw33tm1x For This Useful Post:
go_a_way1 (01-20-2016)
Windows Squeaking Froylavin Issues | Warranty | Recalls / TSB 164 02-24-2018 02:41 PM
Squeaking noise from the steering ScionFR-S Issues | Warranty | Recalls / TSB 22 02-09-2018 06:37 PM
Window squeaking problem, really need help, how to fix? Mask621 Issues | Warranty | Recalls / TSB 7 07-02-2015 08:32 AM
Squeaking noise oinkoinkpig Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 12-25-2013 05:26 PM
Squeaking windows bdanisi Scion FR-S / Toyota 86 GT86 General Forum 29 02-10-2013 11:54 AM
