Old 01-17-2016, 09:24 PM   #15
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Go read the second link that @soulreapersteve posted. I started that thead cuz you really only find negative posts on here no one posts the positive hahaha.
I have have 0 issue with my 13' FRS and still love it.
soulreapersteve (01-17-2016)
Old 01-17-2016, 09:44 PM   #16
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
The Following User Says Thank You to KR-S For This Useful Post:
go_a_way1 (01-17-2016)
Old 01-17-2016, 09:47 PM   #17
Yoda
Drives: Crystal Black BRZ(Sophia)
2013 Brz manual 36k miles. I had some ecu issue with the steering where it would just lock the steering wheel while driving fixed under warranty. I still have the crickets even after the dealer replaced the fuel pump and now I have the clicking noise from the rear axle. Took it to the dealer but they did not hear it then so could not help. So I might have to fix it myself.
Yoda is offline   Reply With Quote
Old 01-17-2016, 09:49 PM   #18
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Haha nah man, I treat mine like a racecar so I cant wait to start breaking things so I can replace them with better aftermarket goodies
KR-S (01-17-2016)
Old 01-18-2016, 01:08 AM   #19
doggieboy09
S่nior Member
doggieboy09's Avatar
Drives: '22 BRZ |'13 BRZ SSC (formerly)
I have about 80k miles on the car since I bought in May 2013. Over 75 launches due to autoX. I have replaced about 5 sets of tires. Around 76k miles I replaced the clutch due to a blown throw out bearing. Granted this most likely happened due to the fact I launch the car all the time in, driving in San Francisco's hills is a bitch, and the clutch failed the day after my first track day at Laguna Seca. The engine leaks some oil, but that's likely due to the abuse of just being a daily driver and high mileage. I only know of one other person who is more abuse than me in his car, and he has over 125k mile on his car but with a new motor.
One of the most common problems I don't like about this car is the windshield. It is more easily crackable from debris on the highway vs other cars due to the fact there is no gasket covering the outside edges of the window.
doggieboy09 is offline   Reply With Quote
Old 01-18-2016, 11:08 AM   #20
rookie
rookie's Avatar
Drives: 1991 Formula Red NSX
Originally Posted by KennethJohnson View Post
So I'm looking into picking up a newish 2014-2016 model and I'm just wondering how's everyone's car holding up?
Could you guys let me know? Post your mileage, and if any.. problems you've encountered.
And perhaps a review? Or rating in which you'd give the car?
Appreciate it fellas!
2014 with just over 2k miles as she sits in my garage for the winter. Only mods are stickier tires and new wheels. No issues whatsoever.
My quick review is it's a great little car, more quick than it's fast. The torque dip is noticeable and is this car's biggest flaw IMO but easily remedied. The driving experience is like non other in this price range. I came from an RSX-S with I/H/E cams & Hondata so obviously the BRZ is not as fast but is significantly more nimble and hugs curves/corners like the RSX wishes it could.
rookie is offline   Reply With Quote
Old 01-18-2016, 11:33 AM   #21
radroach
Drives: car
2013 at 60k+ miles.
I need the bumper, hood, and headlight realigned after a minor (10mph) run in with a deer.
Also a couple dings I need to get removed with a PDR. Front bumper has a ton of tiny road chips that I hide with wax. I've buffed the stock wheels against a few curbs. If you don't pay attention to these details, then the car looks great still.
The stock radio stopped working for me after reset (I didn't have an SD card), so I replaced the radio. My dome light has gone out and I need to find out how to replace it.
Other things I need to get fixed are the shifter rattle, rear deck rattle, and I need new shifter bushings.
I have replaced the MT fluid twice and changed the clutch, and had the spark plugs done at 55k. And kept up with the interval maintenance pretty closely. I probably need to get the diff fluid changed again, I get a whine in 3rd and 6th gear somewhere in the drivetrain.
Old 01-18-2016, 12:19 PM   #22
No1der
No1der
No1der's Avatar
Drives: BRZ Limited Satin White
2014 BRZ Limited at 18K miles so far, top part of steering wheel starting to peel
No1der is offline   Reply With Quote
Old 01-18-2016, 12:20 PM   #23
DrunkBandit
Drives: 2016 Pure Red BRZ
2016 at about 400 miles, doing great.
Have not been able to go hard with it, so I don't know how well its going to handle it.
The only thing I have done to it is to put some rain-x rain repellent on the windshield since water likes to stick to it.
DrunkBandit is offline   Reply With Quote
Old 01-18-2016, 04:25 PM   #24
Side
Side's Avatar
Drives: 2018 BRZ tS
2016, automatic transmission, 3000 miles.
No issues as of yet. Pretty much always in sport mode unless there's snow on the ground, and drive it in manual mode about 20% of the time (only when I really need to throw it around). Otherwise sport automatic does the job just fine.
Side is offline   Reply With Quote
Old 01-18-2016, 04:29 PM   #25
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
LOL soon you will end up like the rest of us... always in manual mode
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
new2subaru (01-18-2016), Side (01-18-2016)
Old 01-18-2016, 08:31 PM   #26
scottbrz
Drives: 2017 BRZ Limited PP
2016 BRZ. Just over 3K miles. No issues, a lot of fun.
I have noticed the engine hiccups on cold start. I've seen some other threads on this. They sound and feel like misfires. But, I am thinking this is likely a side effect of the cold start tuning.
The hiccups go away as soon as the high rpm cold start ends, and there are no codes. The car drives fine otherwise.
scottbrz is offline   Reply With Quote
Old 01-18-2016, 08:37 PM   #27
lionbacker54
lionbacker54's Avatar
Drives: 2013 WR Blue 6MT BRZ
2013 Limited BRZ 6MT. 24K miles. No issues, no crickets, no condensation.
lionbacker54 is offline   Reply With Quote
Old 01-18-2016, 08:42 PM   #28
Romanov
Just another BRZ owner
Romanov's Avatar
Drives: 2014 Subaru BRZ Limited MT
14 limited brz MT, 13k miles, bought it at 4k in February of 2015. No issues so far. Currently in hibernation for the Minnesota winter
Romanov is offline   Reply With Quote
