Old 10-26-2015, 10:18 AM   #3067
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Originally Posted by humpre View Post
Must be nice, its been 3 weeks since paul has gotten back to me, after already waiting 3 weeks for a reply
I ordered my gaskets since 9th July but have not receive any replies either even after multiple emails sent.
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Old 01-17-2016, 12:13 AM   #3068
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by cdrazic93 View Post
The 3rd point is referring to the codes for P0018 and 19 for the cam sensor, the loose sprocket is the cause of the engine stalling at a stop, or P0016 and 17 according to AVO.
Two different codes, or is one the cause of the other?
It seems that the if the cam sensor goes AWOL then the cam sprocket will pop out from the bad timing.
I recently got p0018. Replaced the cam sensor on upper left hand side and nothing. Check engine light and traction control light came back on. I'm pissed
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 01-17-2016, 01:28 AM   #3069
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Not sure if its bank 2 position A, but which one did you switch?
Old 01-17-2016, 12:27 PM   #3070
Astroboy
Astroboy's Avatar
Drives: None
Bank 2 position A. Upper left side. Next to the battery. This code sucks...
Old 01-17-2016, 12:29 PM   #3071
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Has anyone else done this?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 01-17-2016, 02:27 PM   #3072
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
da faq man
Old 01-17-2016, 02:31 PM   #3073
Astroboy
Astroboy's Avatar
Drives: None
da faq man
What? Did you get the same code?
Old 01-17-2016, 07:15 PM   #3074
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
No haha Ive run out of ideas that it might be though
Old 03-07-2016, 01:08 PM   #3075
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Quick question, can anybody confirm placement of where the oil breather line goes that connects to the reservoir if you are not running a AOS or anything?
@Sportsguy83 @AVOturboworld
Cockatoo is offline   Reply With Quote
Old 04-04-2016, 09:11 PM   #3076
TestaRD86
TestaRD86's Avatar
Drives: 2013 Scion FR-S 10 Series
AVO Turbo Alternate Intake
I am installing my AVO Turbo soon and I was was curious if there is anyway to get say a AFE Intake modified to use instead of the OEM. I really like the cone intake from my AFE and would rather modify it than go back the the OEM intake box. Drawbacks I just realized were that the AFE doesn't have a direct MAP sensor like some other intakes. I have only seen one guy using a Perrin Intake as an alternative when using an AVO. Is there any others that may work as well? Thoughts?
TestaRD86 is offline   Reply With Quote
Old 04-04-2016, 09:21 PM   #3077
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I used the Perrin. Needed a little modification on the bracket that holds the intake to make it straight. Pretty straightforward. Don't know of any else that would work.
Old 04-04-2016, 09:23 PM   #3078
TestaRD86
TestaRD86's Avatar
I agree I've been looking for something else. I'm thinking the blitz intake might work as well but I'm not as fond of them as I am of some other companies.
What did you have to modify on the bracket to make it fit?
Old 04-04-2016, 09:26 PM   #3079
Sportsguy83
Drives: Limited BRZ
It's held by a bolt to the radiator top support, needed to make a custom aluminum bracket to move the bolt to bolt to a diffferent location so that the intake sits straight. IT was really easy, just making two holes on an aluminum small piece.
Old 04-04-2016, 09:29 PM   #3080
TestaRD86
TestaRD86's Avatar
Hmm doesn't seem too bad. Does the Perrrin have a good sound as well. I hated the oem and like my afe. I had a trd at one time I sold I liked as well.
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
